I have replaced the previous outdoor beamshots with new ones that show the actual turbo. I noticed that the turbo is hidden and can be activated only with a fast double click. The NI40 gets hot faster and throws further with turbo.
I would not risk it because the springs in the NI40 are very stiff and made of thick wire.
The 21700 battery sticks out and would pretty sure be crushed because with the anodized threads on both sides you have to screw on the head and tailcap fully to make contact. Here are two pictures, 21700 Samsung 30T and 26650 Liitokala. Mind that the tailcap spring has almost no tolerance as it is 1.6mm thick.
I’m not too sure how battery protections work but I saw you mention that the Stalker has a built-in PCB, does that mean the battery does not have to be protected? I see you barely fit the unprotected and mention that the spring has very little flex. I assumed a protected battery in such a beast was a no brainer but now I’m not sure what I need and it seems it wouldn’t even fit. Am I correct to assume that with a PCB built-in, that a flat-top unprotected is the correct battery and likely the one the manufacturer intended to be used?.
I have one on the way and want to make sure I don’t order the wrong cells. Thank you for the great review.
The Nightwatch NI40 Stalker claims to have a low voltage protection. I did not test it but most flashlights have it, meaning that they turn off when the battery voltage goes below 3.0V.
I tried a protected battery and it looks much like the 21700 cell above. I don’t think it will fit as protected 26650 cells easily reach 70mm in length. The NI40 seems to be designed for 65mm long cells. Also, protected cells have certain currents when the protection trips. With the current getting over 10-15A (depends on the cell, maybe even 5A) the flashlight will simply turn off. The 3V XHP50 draws around 18A and you will not get a Turbo mode with a protected cell.
I would recommend you to use a flat-top unprotected 26650 from well-known reputable brands. If you use a flashlight with low voltage protection and a decent charger you will not have problems even with unprotected cells. If you are not sure how to handle Li-Ion batteries adequately look for Lithium Ion battery guides here on BLF.
Thank you so much for the info, I guess I’m going with the Shockli. Actually, what brand do you like for this light?
In the flashlight description it only asks for a 26650 Battery and thats it. So is it safe to assume generally speaking that if a manufacturer just gives a battery size without mentioning button top or protected that means a regular unprotected flat top is ok?
I’m waiting on the Sofirn Sp36 to arrive and that one says it needs 3x18650’s only so I’m guessing any flats will be fine. Then I’m waiting for the Haikelite MT09R and that manual says 18650 Button tops with anti-reverse & anti-discharge protection. So that light likely has no protections built in and I MUST use protected buttontops at all times?
Sorry, don’t mean to veer you off course too much, you just seem knowledgable about this.
Edit: Actually I just checked Amazon’s listing of the Sp36 BLF and it says button tops are required and flat tops cannot be used. Sofirn doesn’t say tht at all but Amazon make this very clear. Does that mean I could also use the protected buttontops I’m buying for the Haikelite? Or can protected batteries be used only on flashlights that explicitly say Protected?
You’re welcome. Most of my knowledge about flashlights and batteries comes from reading a lot on BLF. I’ll try to explain you a few things about batteries.
Flat top unprotected batteries will fit almost all single cell flashlights. It depends on how long the battery tube is and on the spring tolerances if a protected cell is suitable or not. Sometimes the description tells to use batteries with more than 10A continious discharge. Then they mean unprotected high drain cells.
The Emisar D4 or the Lumintop FW3A for example fit only unprotected flat top batteries. Flat top is how they are sold by the manufacturer.
Other sellers will add a protection or a button top. A protected battery is not the same as a button top battery. Most protected batteries have a button top but not all button top batteries are protected. Many flashlights with 3 or 4 batteries and battery carriers require unprotected button top cells.
In the SP36 there are 3 18650 batteries. They need to be unprotected because protected cells would be too long. They also have to be button top because there is a brass ring at the head where flat tips would not make contact because usually the positive pole is slightly lower than the surrounding shell of the battery.
You should use unprotected button tops also in the Haikelite MT09R. It has plastic rings around the positive button that prevent contact on flat tops and are a mechanical reverse polarity protection. The MT09R is a high power flashlight with 3 XHP70.2 that need a lot of current in direct drive. With protected cells it would flicker and simply turn off in turbo mode. It has all necessary protections because it uses the NarsilM firmware and the BLF members who developed this firmware and the corresponding drivers are true experts.
Generally speaking, all high power flashlights that use the XHP70, XHP50, SBT90.2 and multiple emitters need unprotected batteries These flashlights also have low voltage and reverse polarity protection. If you see lumen values over 3000 lumen you can be certain that these flashlights use unprotected cells. You can find out if flat top or button top by reading the description or reviews.
For more information about batteries, leds, drivers and flashlights in general check out this reference guide: LEDs & Other Stuff - (Reference Guide)
There are the battery tests by HKJ, the safety guide and links to useful information about batteries.
Hope I could help you. The Sofirn SP36 and the Haikelite MT09R are two great choices.
You helped me tremendously. I was really confused about all this and now I feel far more informed so I thank you sincerely.
If you don’t mind, allow me to give it one crack to see if I’m learning. I’ll very likely be buying the Nightwatch NSX3 NS53A. Since it’s over 3k Lumen, def no protection, and since it’s not in a battery carrier, a flat top is correct. So for that one I’d buy a 21700 unprotected flat top. Is that correct?
Thank you again so much for taking the time to help me with this.
Yes, that is correct. The Nightwatch NSX3 NS53A uses 3x Xhp50 3V which is a very current hungry led. For the maximum brightness the best high discharge 21700 is the Samsung 30T. It will heat and stepdown fast. If it doesn’t matter for you to reach the declared 9900 lumens a Samsung 40T or a Molicel P42A should be enough and give more runtime.
Let me remind you to treat these high discharge batteries well. Never risk to short circuit them, store and transport them in plastic cases, use a good charger and be careful not to heat or puncture the cells.
There are only these few basic rules to follow and your unprotected batteries will work fine. In the category of the 3x Xhp50 3V flashlights there are also the new Lumintop FW21 Pro and the about to come out Astrolux EC03.
Have fun with your flashlights! May BLF always be a source of knowledge and inspiration for you.
Thank you once again… Following the battery rules is very important from what I see in all the websites that sell them. They have hefty warnings and even require acknowledgments to make sure you understand. I appreciate the quick rundown.
I sure wish I would waited for your response. I bought 3 40T’s thinking those would be the better ones. I should have researched first. Live and learn.
Anyway, I did consider the FW21 Pro but ultimately didn’t like all the complaints others had about possible quality concerns. I also liked that Nightwatch took heat dispersion a bit more seriously than Lumintop did on such beasts. Ultimately since the lumens were similar, I chose my preferred host which was easily to me the NSX3. I will be checking out the AstroluxEC03, hadn’t heard about it.
I absolutely have received inspiration and have been bestowed a tremendous amount of knowledge in my short time here at BLF, I can’t imagine how that would be changing anytime soon.
Yes, lithium ion batteries have a high energy density, a low internal resistance and can release high current in short time. That is why short circuit would be dangerous. However, you have lithium ion batteries in almost any device today, notebook, smartphone, e-bike …
The 40T’s are a good choice. They are rated for 30A discharge, the 30T’s are rated for 35A. You will not notice any difference in startup turbo brightness because a difference of 10000 lumens to 8000 - 9000 lumens can only be measured but not seen. After a few seconds the 30T’s voltage will sag and the current will be reduced anyway. Also, a flashlight of this size will get scorching hot in less than a minute. Additionally, the 40T gives you more runtime.
You are starting a nice flashlight collection I see.
Thank you good sir. I do like to think I’m starting a nice collection and am pretty happy about it. I love my KR4 so much. The MT09R and Sp36 are super exciting and I can’t wait til they arrive. But I do have to say that something about the 2 Nightwatch’s on their way seem like some pretty special lights. I’m actually in love with both of them.
I say I’ll be good after I get these lights, but the more I read here at BLF, the more I realize how absurdly foolish that sounds and how everyone at some point here thought the exact same thing.
I was hoping you could give me a suggestion or two. Minus the SP36, MT09R, KR4, NSX3 and Stalker, are there any lights you’d recommend that round out a flashlight collection nicely? I know people really love the Zebralights for efficiency but I also hear tons of complaints about their tints. As an impulse purchase, I bought the new 95 CRI Sofirn IF25A as well so I don’t think I need another small light, much less one with so so tint. I thought BLF Q8 but figured it’s an overlapper with what I will have. Are there any must-haves that you would recommend? Thank you.
Yes, sure I can suggest you ONE OR TWO flashlights but it would be too difficult to choose. Let’s say I’ll give you a few flashlights to check out.
I don’t know Zebralights well but I have also heard they are using very efficient drivers. They use some high-CRI emitters and especially the XHP50 and XHP70 are a bit green in high CRI. Generally, I prefer the cheaper flashlights though.
I like flashlights with optics because they allow to use many leds in a relatively small space, especially SST20 4000K 95CRI, and most have lovely aux leds. The Emisar D4S uses a bigger and throwier quad optic than the KR4 or Sofirn IF25A.
The Fireflies E07 uses 7 leds, the Fireflies ROT66 G2 12 leds. There complaints around about Fireflies quality control but I like all my Fireflies flashlights. The E07 with XPL HI has been the brightest single cell flashlight (replaced by the new 3xXHP50 flashlights I guess) and the output on Turbo is short but astonishing. The ROT66 G2 comes with a floody and a throwy optic to change and has nice aux leds.
I can’t really recommend you the Astrolux MF01 mini because it has a fast thermal stepdown problem that can be fully resolved only with the ManOfLight copper heatsink. Three recommendable flashlights from Astrolux are the Astrolux MF01S, the Astrolux FT03 and the Astrolux MF02. The MF04 is a monster thrower and maybe not suitable for all but it is a mighty feeling to hold it in your hands.
Convoy is a brand that makes great flashlights, two classic ones are the Convoy S2+ and the Convoy C8+. The owner is also a member on BLF and is always open for suggestions or ideas. Basically you can buy any flashlight or host from him and be almost sure you will like it. Every collection needs a Convoy.
Two smaller flashlights are the Sofirn C01S and the SP10S. Well known also the Sofirn C8F, with a thinner battery tube than the SP36 and triple reflector. The BLF Q8 is a great allround flashlight but if you want something different you better wait for the Q8 Pro with 10000 lumens from 4 XHP50.2 3V, expected in July.
Other brands that have nice budget flashlights are Wuben, Skilhunt, Lumintop, Manker and Amutorch.
That should do for now. Let me warn you, keep looking for good flashlights and you will soon end up with over 50 great and absolute must-have flashlights.
Wow Skylight, I don’t know how I missed this post but thank you so much. I appreciate all the recommendations.
I actually just picked up the Fireflies PL47G2 with Nichia 219b’s. I just got it today and I like it a ton. I also like your other Fireflies recommendations, they are extremely tempting.
The Sofirn Q8 Pro sounds amazing. I don’t know how you know that that’s coming out but that’s awesome to know. I would love to have my pulse on future offerings too, guess I’ll have to do some searching.
I appreciate you and the time you took to write this. It was quite helpful. My sincerest gratitude to you good sir.
I just got my nightstalker sbt90. 2 and it is my first real light. Mine came with no Xtra goodies and a strange black jumper wire soldered on the tail cap spring anybody else experience this?
The black jumper wire is a spring bypass so that the spring can handle the 20A+ current well. Thin springs can collapse with high current and no bypass. A bypass improves the performance also with thick springs.
Thank you I really appreciate that insight. I read somewhere that the wire reduces resistance so that is nice… just didn’t see this wire in any other post/pics so I was unsure it looked kinda modded… so all good thank you! Also I have ordered 2 Astrolux mf01s minis 1 is the copper/aluminum the other is a green Mateminco. I also ordered 1 Astrolux Mf01 with Nichia and 2 sand colored 1 is Mf01s the other is MT18s so 2 of the same light just 1 Astrolux and 1 Mateminco. I just couldn’t help myselfand Neal’s is lagging so I ordered the second from bangood which seems to be running things faster with shipping also my nightstalker came from Neal’s with no extra lens or lanyards or O-rings.
