I think they switched to a one piece plastic lens about a year ago. It works well. If you want to swap in a Carclo then you need to buy the glass lens seperate. I believe Neil was selling them.
JasonWW, thanks for the info, Lucky i sent for 2 Carclo 10507 and 2x glass lens last week, one for my EDC18 and one was for backup but ill fit it on the FW3A.
Last night I left my LM-10 on until the head got quite hot (this required me double-clicking to re-activate turbo after rampdown).
After several minutes of this I noticed the light was no longer shutting off completely. All the controls worked fine, but in the “off” position, all 3 LEDs were still lit at a very low level. Lower than the moonlight setting.
My first thought was a bad 7135 chip. I swapped the driver for one from an FW3A, but it still wasn’t working properly. The light was still on when it should be off, except now it was brighter than before. It turns out the driver was fine. The problem was the star.
The problem was this:
- When I ran the light until it got really hot, excess solder under one or more of the LEDs melted.
- Pressure from the optic, then pressed the LEDs into the star. This caused some of the solder under at least one of the LEDs to spread sideways and bridge to the center ground pad. Initially, this bridging was tiny so the light output was very low. After the driver reinstall, things moved again and the bridging was more severe. This explained why it was brighter after the first attempt.
The solution: - Removed the star and LEDs. Used a vacuum suction pump to remove all excess solder from the LED pads on the star, then reflowed the LEDs.
- During reassembly I also removed the stock thermal compound and replaced it with Arctic Silver 5. Not sure it will help, but it is my standard practice to apply fresh thermal grease any time I remove a star. And it’s especially important with a hot-rod like these lights.
Now the light is fixed and works fine. But one caution is it probably isn’t a good idea to constantly override the temperature rampdown on the lights with a titanium head. These lights look and feel great … and I like them much better than lights with a copper head, but titanium isn’t the most practical material for removing heat from the star.
Take a super thin/light, super small light with max super output and then to make it even better, make it out of titanium :FACEPALM:
We are rolling the dice.
Any information where can I get spare switchboard or blank driver board?
Trying my luck searching at Oshpark but none the result.
Dunno if anyone cloned it. I don't know if it's been public who designed the driver, yet alone, made the design public, shared. Of course Lumintop could offer them here somewhere: http://www.lumintop.com/flashlight/lumintop-wholesale-led-flashlights-accessories, but I don't see any spare parts offered, like Sofirn does.
Lumintop will sell you parts if you email them service@lumintop.com
Unfortunately the shipping from China made it impractical. If you’re ordering another light, though, you might be able to get them to include some parts.
Thanks Tom & treellama, I will try to reach them
Quick question. What is the better battery for this light between Samsung 30Q vs 35E?
Samsung 30Q
This flashlight doesn't pull a lot of amps, so the 35E is better.
Are you talking about the FW3A? It does pull a lot of amps. Either type of battery is fine. A 35E will pull less amps than the 30Q which means slightly less output on Turbo, but you can run Turbo a bit longer before it heats up. I would just use whatever cell you have or whichever is cheapest.
The FW3A pulls a moderate amount of amps, and the 35E can handle that amount of amps just fine.
You're not going to see much of a difference between using a 30Q and a 35E, except in runtime.
The FW21 Pro, for example, pulls a lot of amps, in comparison.
It is still more run time and less peak amps, or less run time and more peak amps? Or has that changed any?
Yes, if you want maximum brightness, go with 30Q.
You'll also get more heat.
If you want maximum runtime, go with 35E.
If you plan to get flashlights in the future that pull more amps, go with 30Q.
What is supposed to happen:
when off, hold on button for moon mode and let go and it stays on moon mode. Then you press and hold again and it ramps up. This doesn’t happen with mine.
The issue is I hold down the button to go to moon mode and as soon as I let go, it jumps up to the level above moon mode. As a result it won’t stay in moon mode.
Anyone else?
Any fix?
Any fix?
Have you done all of the standard fixes already? They’re all written somewhere above.
Tell us what you tried that didn’thelp.
It’s not easy to find any fix above as this is a rather large thread. Can you point me to the fixes?
What are your floor levels set to? Are you still able to ramp down to moonlight?
I recently installed a 18350 tube on my FW3A, running an ICR 900mAh 18350 cell. Seems fine, but I’m wondering if there’s a recommended 18350 cell to use with this light. Any suggestions?
