10Klm or the advertised 13Klm, it does not matter, if there are more lumens more plummeting. Same host but more amount of dissipated heat produced by the LEDs.
But then again, someone might say they want to use only the 5000lm function, the 10k is not compulsory which of course is just fine. Problem is if something has the same host and only claims 5000lm and might handle that just fine no one gets excited as much as Utopian claims excite.
Well worded Hikelite.
Will do some lumen measurements soon, if it didn’t had the dreadful proprietary cell, now i constantly need to charge it after doing a small test
It is actually quite convenient and standardized, saves a ton of trouble if a charging function is in such high demand.
The conflict comes at the moment when the manufacturer has fundamental issues understanding how to deliver what it wants or it could be that it is their deliberate choice to claim something then make it in such way it can’t deliver.
You need a very long spring to try that. Not recommended though.
T.b.h. a KR4 with xpl hi is probably a better choice, since the output plummets immediately.
it looks like the bezel should come off, it’s seems it’s screwed into the head, it is slightly protruding.
Get a rubber or other flat grippy surface and try to open it holding it down firmly while turning it
Got mine few minutes ago. Unprotected batteries work well If you add some coins to the negative end.
Do not use crappy batteries from bangood or etc. Flashlight works for 10 seconds in turbo then Red led flashes due to voltage drop. You will have to reinstall the battery If this happens.
Estou tentando um reembolso da Imalent sobre essa luz, apesar de todos os esforços a luz insiste em não funcionar como deveria…. mesmo com tantos videos e postagens dos problemas desse projeto a Imalent insiste em não admitir o erro nessa luz…. lamentável… Apartir de agora, Imalent nunca mais! Ganaciosos!!!
I am trying to get a refund from Imalent on this light, despite everyone who is suffering a light insist on not working as it should…. even with so many videos and posts of the problems of this project in a last case, not admitting the error in that light…. unfortunate… From now on, Imalent never again! Greedy !!!
