I'm counting mine gone. I never did receive it and I gave up. Don't think I'm gonna get it at this point.
Only one parcel from twenty sent to States after 15th March have been delivered.
I don’t believe 19 other have been lost.
Anyway, I agree that 2.5 month are overkill.
I can make refund, resent item tomorrow or resent it after airline industry is back to normal life. By your choice.
Today I contacted my national post office service about the parcel coming from you (that arrived to the country 10 days ago) and another one from Simon (that arrived 20 days ago).
I’ll be looking for their reply and I really hope they can locate both of them soon!
I’ll post again when I receive the parcels
PM incoming.
I appreciate everyone who is waiting for his parcel for a long time.
There is some probability that international flights will get back to more often schedule after July, 1st.
If your country had many limitations for an incoming post (easy to recognize by an unusual tiny amount of small parcels laying on the shelves in your local post office), please be ready to wait for an extra month or so after the parcel has been imported. This local delay doesn’t really correlate with the country’s size or population.
Package received in Croatia after 34days of traveling.
Hey, my package arrived today
It was shipped on the 20th April, and arrived on 5th June.
Since the 21st May it was sitting in Lisbon after “national reception” state. [With this I also received my package from Convoy that was sitting there since the 12th May… ]
Everything is as it should Thanks kiriba-ru for your work and patience you also had with this
Modding time now
Interesting heatsinks you have there, MascaratumB. Would you mind telling me what flashlight they are for?
Sure!!
The one in the left is for a Convoy S2/S6.
The other are for some zoomie lights I have, bought in Lidl (reviewed here: “REVIEW”: Livarnolux 314791 – Push-Pull Zoomie Flashlight – 2xAA – Cheap – From LIDL!!! =)), and a SK68 clone.
They have hollow alu pills and…I wannt transform them in hot rods :smiling_imp:
“REVIEW”: Livarnolux 314791 – Push-Pull Zoomie Flashlight – 2xAA – Cheap – From LIDL!!! =) - #6 by MascaratumB
My copper pill and spacer finally arrived. Shipped February 28, arrived May 19 in the post but just got it today due to the pandemic. Orders do tend to take a while to get here in south east asia so I would consider this just about normal really. If there was no pandemic it would’ve probably just shaved a few days off.
Thanks, MascaratumB. Those heatsinks for the hollow alu pills look very neat. Good idea to order them from kiriba-ru. Usually I make my own heatsinks with a copper rod, a hand saw and a file. Of course they never look as nice as your professionally machined ones.
Yeah, recently I’ve spent a lot of time manufacturing a Skywolfeye B16 heatsink and I’m not very happy with the outcome. I’ve been thinking about pinging kiriba-ru about making one…and I may do it after all.
At Skylight and Agro,
After doing the bead for the OL Contest, I realized that my lack of tools would be a serious constraint to make this kind of piece. Also, getting, the right size of copper tubes would be a PITA and much more expensive, because the stores around don’t have many materials and they are not cheap in these kind of things.
So, I decided to call for the help of kiriba-ru and the pieces are great
They have different diameters, to fit different pills as I requested! Of course, some will need adjustments to fit better, but they are top quality! So, thanks again kiriba-ru
BTW, this is the first use of one of the heatsinks. It is on the Aluminium pill of the second Livarnolux zoomie flashlight I showed above.
It will take 2x14500 batteries, a 15mm driver with Bistro HD OTSM and an XHP50.2 (it will not be the one in the photo as I already damage it yes, again! ).
I had to file the copper and the alu a little bit, and then I had to hammer it to press fit!
Nice mod MascaratumB!
I soldered a number of copper shims to get the rigt thickness and then dremeled it to the right diameter.
The effect could be fine but I just didn’t do it well.
Well done, MascaratumB. Neat idea to fit a XHP50 in a small zoomie.
As I often have heard that the XHP50.2 6V is sensitive to direct drive and tends to burn will it work with two 14500? Just asking because it could turn out useful for my own builds.
Thanks NeutralFan
Hum, that must have been hard work :zipper_mouth_face: But I guess in the end a solid piece will probably end up working better!
Well done, MascaratumB. :+1: Neat idea to fit a XHP50 in a small zoomie.
Thanks Skylight :+1:
Not to hijack kiriba’s thread, I’ll say that so far I only succeded with an XHP50.2 on my recently modded BlitzWolf BW-ET1, where I put an XHP50.2 with a 15mm driver with Anduril for 2x14500 cells. I only tested it with non high-drain cells (Sofirn 900mAh), so I can’t tell how good it will behave when I start using higher drain cells.
But I guess the problem with the flaws has been due to bad soldering/reflowing of the emitter and not the relation cells / driver / LED. I will need to get some more leds to complete the mods I want to do with similar configurations, and I need to get high-drain cells to see how they resist to higher currents.
About the XHP50.2 on the zoomie, it would probably be better if it was dedomed, but…It will do the trick ! I hope
Unfortunately, more information I get about this situation, I get less sure that it will end well.
From the beginning of this year, the contract between Russianpost and air cargo company has ended and most international dispatches were supposed to fly in passenger airplanes. It worked well when countries had open borders and each airport received hundreds of planes every single day. Then something went wrong.
Overseas shipments that I’ve made between March 15th and May 15th have not left Russia with an airplane (the way they should went). Now they can:
a) be on the slow boat
b) laying in heap, waiting until the heap is big enough to fulfill next slow boat
c) laying in heap, waiting until airlanes get back to work
More recent shipments should go faster (I hope so), some of them have left Russia on June 6-7 and should be imported soon (I hope so).
I do expect pyramid-type sorting delays on both ends (parcels that are laying close to the bottom will be sorted at last, both when exporting and importing), so as soon as I will get delivery confirmation from more recent shipments (again, I HOPE SO), I will be able to offer the reshipment as a go-to way when it is possible.
I will ask everyone to post a message here if you have recently received a parcel from me. This is necessary for other waiting BLFers.
P.S.
This is local meme. In russian net this sculpture is called “the waiting guy”.
For French speakers: https://www.lemonde.fr/europe/article/2017/03/02/jdoun-mascotte-de-la-patience-et-symbole-d-une-russie-qui-n-en-peut-plus-d-attendre_5087856_3214.html
For Dutch speakers: Eindeloos wachten ligt de Russen wel » Mare Online
Update:
I’ve got the confirmation from Russian post that orders shipped to States in May and April have fulfilled the slowboat and should be delivered by middle of July. Later shipments should go by air.
Update 2:
I’ve got the confirmation from Russian post that orders shipped to Australia in May and April have fulfilled the slowboat and should be delivered by end of July. Still no air connection with Australia, so later shipments will wait until air is open or next slowboat.
I like it...
Nice explanation, kiriba-ru, thank you.
This must be the reason why some of my parcels from China take ages while your parcel from Russia didn’t need much more time than usual.
