What do you mean exactly by change the AUX lights?
At this point if it's somewhat an involved change for NarsilM, I'd rather change Anduril to remove options. I've been modding Anduril to my own prefs for a while now.
Right now, for a simple single AUX (usually switch) LED, Anduril can control 2 output levels while NarsilM only does one level. For the more complex TIR optic multi-color AUX LED's, Anduril must be running on a more advance MCU that has more I/O pins and code space like the Atttiny 1634 which NarsilM does not support.
So for this FT03 mini, I don't see any info anywhere posted about the AUX LED design.
To add 1634 NarsilM support is a relatively big project - not at all planned or in the works. Even adding the simpler-to-do option of supporting 2 levels may not be that easy because I might not have the available code space with the limit of 8 KB the Atmel ATtiny85 has.
NarsilM and Anduril previously required the ATtiny85, first came out in 2005, then TK added supported for the 1634 (and possibly other variants). The 1634 first came out in 2011.
Our goal should be, maybe is right now, to support the ATtiny1616 or ATtiny3216 (out in 2018) because mainly of the feature listed in the far right column: UPDI, plus they have 16 KB and 32 KB of code space (ATtiny85 has 8 KB). UPDI allows 1 pin flashing. The advantages of UPDI have been discussed here in the tech threads, but maybe not a 1 pin, but I think 3 pins can be used for a pogo pin flash kit.
Our ideal MCU right now would be a 20 pin flat pack (called QFN-20 in the chart), and having UPDI. The 4 mm x 4 mm size is nice and compact for our drivers, and relatviely easy to design in. The "1-series" MCU's on the chart are preferred. See gchart's thread: https://budgetlightforum.com/t/-/55911
I don’t know either. Wasn’t aware the FT03 Mini existed until a few minutes ago.
I haven’t really worked with Mateminco for a while, because they’ve got a few products being distributed without source code, in violation of the license. Have tried to resolve it with Ben (Survivor), and sent all the info necessary for that six months ago, but nothing has happened yet. Sent another message just now, so maybe it can get fixed.
Anduril definitely isn’t for everyone.
However, getting Anduril to work on a light mostly means getting FSM to work on that hardware. And if FSM works, it means a variety of other interfaces should work too.
Ideally, vendors should be able to offer any FSM-based UI. It could even be an option at time of purchase. It could use Anduril, or a ZebraLight UI, or an Olight UI, or a simplified ramping UI, or even a ported version of NarsilM (though neither Tom nor I has ported it to FSM yet). As long as the driver has flashing pads in a standard layout, it’s easy to change the UI — before or after purchase.
The idea is: people write UI apps on top of FSM, and then FSM handles all the differences in hardware. It’s like how people can run their favorite programs on almost any computer, mixing and matching hardware and software as they please.
The idea isn’t fully realized yet, but it’s at least sort of close… it makes portability a lot easier.
Yup, it seems like a good step forward, and gchart has already done most of the work. I need to get the code merged in… have just been a bit distracted with all the other stuff happening lately.
I agree TK - not sure that I'd port NarsilM as-is to FSM - there's too many similarities with Anduril. For example, I don't like the Werner style UI for set mode levels and would rather go with Anduril style mode levels - makes more sense, more powerful custom settings, etc.
Also would want to use/leverage the more advanced thermal mgt, multi-MCU, AUX LED support, etc. I can see minor changes, and a simpler UI as being suggested, but I need a lot more specific details of what to change, eliminate, etc.
Question, is the 18350 tube part of the FT03 Mini package or separately available?
In BG, there is the option of “FT03 Mini flashlight” or the “FT03 Mini + Samsung 30Q” — Are the 18350 tubes included for both version of the item in BG’s listing?
Can someone tell me exactly what to purchase for flashing firmware? I’ve flashed phones a lot so the computer side is easy, just need to know what to buy
Would be happy ditching the aux and using a simplified UI on the AstroluxFT03 Mini, MF01, EC03 etc if it has the pads
