I tried to tweak the UI a little bit, put a bit more emphasis on accessing Moonlight and Turbo mode more easily as well as keeping strobe modes available but hidden. I hope this chart is easy to follow. Any feedback is welcome. THX.
Can the light be locked out with a quick half-twist of the tailcap? If so, just put the battery-check on first-connection, just like my MH20. Why waste a 3click or 4click for that?
My GTmicro, ’mini, Q8, etc., all doubleblink on first connection to power. Just swap that with blinking out the cell voltage instead. Like with my MH20, a quick untwist-then-retwist blinks out the voltage and it’s done. No wasted clickyslots.
Frankly, I wish that would’ve been done on all my doubleblink lights…
I guess so, as I assume the threads are anodized as usual in Sofirn‘s/Wurkkos’s products. I also agree that it would be nice if the battery status is being indicated when the tailcap is tightened. This should be feasible for Sofirn to manage but it depends on their engineer‘s and Mark‘s decision.
HD20 will not blink out the voltage. It is meant to indicate its battery status by a colorful illuminated switch button (as many of Sofirn‘s lights). Personally, I would not want a flashlight to blink out the voltage automatically. There might be certain situations where starting a flashlight needs to be unobtrusive (e.g. during night and you just want to check something by using moonlight mode without waking up your spouse). Most people here will probably know what I mean. :-D
Thank you for all your efforts. They are greatly appreciated as I have learned from your posts and studied the manuals (even for lights I do not own) which you have provided at:
Below are my personal opinions, but please take them as advisement only and make your own final decision, as I am not aware of everything you took into consideration before making your decisions.
"1x click" could be more clearly be stated as "1 click"
"2x click" could be more clearly be stated as "2 clicks"
"3x click" could be more clearly be stated as "3 clicks"
"4x click" could be more clearly be stated as "4 clicks"
"Cycle to standard strobe mode" could be more simply be stated as "Cycle to Strobe mode"
"Cycle to SOS strobe mode" could be more simply be stated as"Cycle to SOS mode"
"Cycle to Beacon strobe mode" could be more simply be stated as"Cycle to Beacon mode"
In the section "When the headlamp is OFF", after using "2x click" to Strobe, SOS, or Beacon mode I am assuming it is "1x click" to "Turn OFF" but this was not clearly stated for those modes. Maybe to be more clear the"1x click" "Turn OFF" line in the chart should be the bottom line of that section and state "1 click" "Turn OFF from any of these modes" and use a similar type wording ("1 click" "Return to previous standard mode from any of these modes") in the "When the headlamp is ON" section. Or have both the original "1x click" line and also a bottom "1x click" line in the chart so it is very clear (but that would be more words which is not always best). But it is OK as is, it just was not as obvious to me as your instructions for the rest of the chart were.
It was not clear if both LEDs are on at full power in Strobe, SOS, and Beacon mode like they are in the Turbo mode.
It would not be a true "Electronic Lockout" if moonlight remains on after a "Long press" while in "4x click" lockout mode. I would not want my headlamp to discharge unexpectedly while in my backpack. I would have it locked out mechanically by un-twisting the tail cap or head but others may not. The mechanical un-twist lockout method should also be mentioned in the manual as some may not know about that.
Your choice for the sequential order of "Strobe, SOS, and Beacon" is the best compromise. Strobe is the mode most people expect first. SOS would be the most important emergency mode. Beacon is the mode probably used the most but the order you have chosen is easy to remember and what most people would probably expect.
"Click" or "Long Press" to change brightness levels is the most difficult decision as there are pros and cons for each method. With a flashlight I can live with either but with a headlamp I would probably prefer "Click" to change brightness levels because (in the most difficult situations where I may be using a headlamp) I have an easier time getting to the correct level I want when doing it this way while wearing a headlamp which is moving around on my head while I "Click" or "Long Press". But if you use "Click" for brightness level changes then you must also use "Long Press" for OFF. It is probably best to choose the most common method as you have done because that is what most people expect and would want.
I do not know the specific mechanism as to how the proposed "3x click" "Check battery function" will operate (maybe different colors and/or blink patterns on the switch's internal LEDs to indicate the voltage) but In addition to that I would also like to have a low voltage battery warning that occurs automatically while the headlamp is on and is also very noticeable while I am wearing the headlamp on my head (as I will not be able to see the switch). Maybe something like a blink sequence that occurs occasionally as low voltage is approached and then more frequently and finally almost continuously right before the headlamp light cuts out due to low voltage (and I hope this headlamp will have true built-in low voltage protection besides just a low voltage warning).
I do like lights that have a way to keep the switch's internal LED illuminated while the light is off because it helps me find the light in the dark. But please provide an option to turn this feature on and off and do not make it too bright or breathing.
I also agree with forum member AEDe that Turbo should not be in the standard mode cycle (unless is it sustainable for more than a few minutes) and agree with AEDe that it would be innovative to have a more convenient way to very easily change between "Spotlight and Floodlight on" "Spotlight only", or "Floodlight only".
Thank you AEDe and roostre for your valuable feedback. I take your suggestions seriously as you probably have much more experience with headlamps than I do. AEDe for instance, you provided us with some great on-site pictures using your Panda headlamp some months ago. So, to make a long story short: I have tried to simplify the UI according to your input as well as to make HD20 more convenient to operate.
I had the idea to include an "off mode" for each LED in the standard mode order. The benefit is that we can spare the triple click to adjust between spotlight, floodlight or both. Each LED can be accessed and controlled easily in its brightness by two commands: Hold or Click'n Hold. What do you guys think of that? Would that be convenient and easy to memorize at the same time without losing too much functionality that a dual emitter light can provide?
I also agree that an accidentally triggered moonlight from lockout is not what we want. So, I would change that to a temporary or momentary moonlight as long as someone keeps the button pressed.
@Mark (Wurkkos):
I hope you and Sofirn will be able to wait things out until we have a decent UI that most customers will feel happy with. I think we are very close to saying "Yep, that's what we want." :-) Without meaning to be nitpicking I think that some former lights were launched a bit too early in the first place and fortunately became much better afterwards due to reasonable UI changes, e.g. Wurkkos FC11. I would like HD20 to start with a great UI from the very beginning.
For the UI why not use anduril? It has a verry nice way of handeling 2 led channels, and would be a selling point to everyone familiar with it. putting anduril on it would probably tip me personally into buying it.
My concern is that if both LEDs are cycled to the “Off” mode, will the light itself technically still be on? How will that be handled in mode memory - for example will turning it “On” not activate either emitter then?
Not an official answer at all but my personal interpretation:
Andúril would probably need to be configured to the driver's characteristics (e.g. it needs to fit to the corresponding MCU, NTP sensor), its thermal calibration needs to be properly carried out from factory in order to work as intended.
Moreover, Sofirn/Wurkkos would need someone with in-depth expertise to have Andúril tailored to HD20. I don't know how much time someone like ToyKeeper or anyone else familiar with FSM is able and willing to spend for this important task. Lately, my impression on BLF is that more and more manufacturers - small or big ones - get interested in selling their lights with Andúril UI. This trend will inevitably lead to a situation of delays in UI development with only a handful of coders/programmers experienced with FSM.
Last but not least, you already named a quite important term..."a selling point to everyone familiar with it". As much as I like Andúril and all of its features, it takes a considerable learning curve to understand and memorize all of its great features. Now, let's just switch for a moment from the customer's point of view to the seller's point of view. If your customer service team gets a ton of questions asked from inexperienced users who just refuse to read the manual (for whatever reasons), you need to have well-trained employees familiar with Andúril and probably a significantly higher headcount. If customers return their lights in large amounts due to misinterpretation of the UI (e.g. being trapped somewhere in the UI), sales managers may reconsider using a complex UI for a light targed for the masses. Please do not confuse an OEM manufacturer like Sofirn with someone like Hank Wang (Noctigon/Emisar) who has clearly focused more or less on one UI only for all of his lights and who has a smaller variety of lights for sale. Sofirn's or Wurkkos's largest target group is the "standard customer" who apparently needs a short and concise manual with a foolproof UI. Taking these circumstances into account, I'm even more impressed that they still have two open ears for a considerably smaller target group of us flashoholics/nerds and that they continuously try to fulfill our special wishes, too. I think they would like to combine the best of both worlds to reach every potential customer - who wouldn't?
Personally, I would like to see a stripped version of Andúril with less complexity (no floor/ceiling configuration, no blinky modes, no AUX support, but with simple stepped modes and ramping as well as with a good thermal configuration) that could be adopted more easily in large scale. To be honest, I really like the FC11 UI which IMHO only lacks a manually configurable thermal stepdown.
Very good observation and an even more intriguing question, too. If someone cycles both LEDs to OFF I would consider the light to be in OFF-mode the same way if someone just clicks it to OFF. With mode memory in charge, I would suggest Wurkkos to use the battery status indicator in the switch to light up for 5s (likewise to most of Sofirn's lights that light up the indicator when being turned on) to indicate that the OFF modes are set to both LEDs. But maybe there are more, better ideas how to deal with this?
Ramping UI may be also interesting. Hold - change only output, click+hold - change throw\flood ratio with constant output. (E-zoom:)
Lux-Perpetua, I think Hold - for change output of current Led(or both) , and click+hold for changing throw-flood-both is more convinient. You can save 3 combinations and change it fast. It is similar to Panda 3 UI.
IF25 had tint-ramping and although it may have been coded independent of Anduril had some very similar functions.
Personally I would go with “Hold” for brightness adjustment and “Click+hold” for cycling spot/flood/both emitters. Leaves double-click open for turbo/blinky modes and doesn’t run into the problem with both emitters being set to “Off”.
Having the indicator LED light up (maybe even with a flashing pattern specifically for the scenario?) when both are set to “Off” does seem to be the best solution if the separate output selection UI is used though.
Dual-channel ramping could be cool, but the UI would be similar to the IF25 and I agree completely that you can’t bloat/complicate the UI too much for the market/niche Wurkkos is targeting.
I have discussed the latest approach of HD20's UI with Mark (Wurkkos) today. We came to following conclusion:
I will incorporate the latest input from you guys into the new draft UI. Special thanks to AEDe and BurningPlayd0h for their helpful feedback.
This final draft UI will then be discussed with the manufacturer in the next days.
Ramping mode will still remain on Wurkkos's schedule for HD20 but it might be implemented in a later revision, depending on many factors like market launch schedule, increase in UI complexity etc.. I will try to post an enhanced UI with ramping mode here but I cannot tell for sure if this will be adopted by the manufacturer in revision 1 already or later on in revision 2.
I have urged Wurkkos to put extra care on a good and reliable headstrap/headband to properly support the weight of this light. A magnetic tailcap would surely be a nice add on but it will also increase HD20's weight. So, maybe they can sell a magnetic tailcap individually or put both versions (magnetic/non-magnetic) in the retail box. A big benefit would be a tailcap design that fits to more Sofirn/Wurkkos 21700 lights.
Another update:
Wurkkos is about to decide whether they should sell HD20 with 4.000K for floodlight and 5.000K for spotlight or with both LEDs in 5.000K CCT. I told Mark that 5.000K for both LEDs cannot be wrong. However, when using two different tints in one flashlight the beam should hopefully look nice when both CCTs will be mixed.
From off
1 Click - memory mode
2 Click -> Turbo
3 Click - Strobs modes
Click+Hold - Batt Check.
4 Click+ Hold - lock|unlock
Hold - moon light (memory type of light .) 6 Click+Hold - changing steped/ramping UI
From Strobes mode
1 Click - off
2 Click - Turbo
3 Click - Return to previous mode
Hold - Changing SoS-strob1-strob2…
From Turbo mode
1 Click - off
2 Click - Return to previous mode
Hold - Change in circle Throw turbo - Both turbo - Flood turbo (may be memory ?)
Steped UI
From on
1 Click - off
2 Click - Turbo
Hold - Changing output in circle Low-Med-Hi.
Click+Hold - Changing type of light in circle Flood-Throw-Both. (output is remembered)
Ramping UI
From on
1 Click - off
2 Click - Turbo
Hold - Increasing output then decreasing it.
Click+Hold - Changing ratio throw|flood with constant output.
