[RD tech] RD6006 updated version RD6012 60V/12A NEW power supply released
51 posts / 0 new
RD tech
RD tech's picture
Last seen: 10 hours 8 min ago
RD6012 Released
Hello, everyone, how are you recently?
we release the second power supply of RD series, it is RD6012, 60V, 12A, 720W power supply, we redesign the circuit, compared with RD6006(60V,6A,360W), it has higher current output.
because the new product promotion ends now, so the price returned to normal standard
Here is the product link:
RD6012($63.5)/RD6012W($67.5)(some area may have extra shipping fee):
https://www.aliexpress.com/item/4001053200176.html
S12A/S12D/switch power supply:
https://www.aliexpress.com/item/4001068050317.html
if you don't know what RD6006 is , you can have a look at this topic:
http://budgetlightforum.com/node/69632
You can also have a look at the product video, assembly video and actual test video on YouTube:
basic introduction:
case assembly:
actual test:
RD series share the same PC software and  same APP(APP has been updated to a new version, more functions)
of course they have same functions and same operation ways, so it is still so easy to use
here is the comparison chart (RD6012 and RD6006)
Model
RD6006
RD6006-W
RD6012
RD6012-W
Input voltage range
6-70.00V
Output voltage range
0-60.00V
Output current range
0-6.000A
0-12.00A
Output power range
0-360W
0-720W
Input voltage measurement resolution
0.01V
Output voltage setting measurement resolution
0.01V
Output current setting measurement resolution
0.001A
0.01A
Battery voltage measurement resolution
0.01V
Input voltage measurement accuracy
±(1%+5 digits)
Output voltage accuracy between setting and measurement
±(0.3%+3 digits)
Output current accuracy between setting and measurement
±(0.5%+5 digits)
Battery voltage measurement accuracy
±(0.5%+3 digits)
Automatic cut off current value when charging
10mA
100mA
Output ripple typical
100mV VPP
250mV VPP@6A
Working temperature range
-10℃~40℃
External sensor Temperature detection range:
-10℃~100℃/0℉~200℉
External sensor Temperature detection accuracy:
±3℃/±6℉
Constant voltage mode response time
2ms(0.1A-5A Load)
2ms(0.1A-5A Load)
Constant voltage mode load regulation
±(0.1%+2 digits)
Constant current mode load regulation
±(0.1%+3 digits)
Capacity measurement range
0-9999.99Ah
Energy measurement range
0-9999.99Wh
Capacity and energy statistical error
±2%
Buck working mode
Voltage drop >1V and >10%
Cooling fan start condition
Output voltage>40V or Output current>4A or
System temperature>45℃
Output current>8A or
Cooling fan shut down condition when working
Output voltage <40V and Output current <3.9A and System temperature <45℃
Output current <7.9A and System temperature <45℃
Over temperature protection
System temperature >80℃
Screen brightness setting
0-5(6 level in total)
Screen
2.4 inch color HD display
Weight(with package)
About 607g
About 642g
Product dimension
167*81*65mm
Support USB communication
yes
Support WiFi communication
No
yes
No
yes
If you have any interest in USB tester or power supply, please contact me
this is my shop on Aliexpress: https://rdtech.aliexpress.com/store/923042
Edited by: RD tech on 06/04/2020 - 21:45
icpart
Last seen: 1 week 2 days ago
Finally great news RDTECH. I waiting long time for that version. Can you post any waveform diagrams of the power supply if there overshoot or undershoot when you power on or connect electronic load.
RD tech
RD tech's picture
hello, thank you for your comment, you can check the third youtube video in this link, it is about 250mV VPP at 6A and about 400mV VPP at 12A
vulpes
vulpes's picture
I’ll be buying one after shipping to my country resumes. I only wish it was USB-C for PC connection.
HKJ
HKJ's picture
Last seen: 5 days 11 hours ago
My TestController software supports the RD6006 and can also support RD6012 with a minor change in a definition file (As long as the protocol is the same).
That software do not look like a control panel, but it can control the supply and it can log and process data from the supply, together with a couple of other devices simultaneous.
It will run on Windows, Mac and Linux.
My website: https://lygte-info.dk/project/TestControllerIntro%20UK.html
BLF: http://budgetlightforum.com/node/72218
EEVBlog (Main discussion thread): https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/
RD tech
RD tech's picture
hello, thank you for your support, you know we can do that, but is that necessary bucause if I replace micro usb with typc c, the cost will increase, and for function, no difference, usb-c cables has many functions like supporting PD charging and other things, using such a good port to achieve a single function is wasteful, we just use this port for pc software, so micro-usb is enough and cheap
RD
Last seen: 9 min ago
Hello RDTECH.
Congratulations on the release a new version of the power supply.
I have a question.
You have many different power supplies, but you do not have a powerful electronic load. Do you plan to produce an electronic load similar to the design of the RD60 ** ?
Sorry for my bad English.
Yokiamy
Yokiamy's picture
Last seen: 3 min 49 sec ago
USB C is the new standard for a couple of years, micro USB is obsolete by now.
Still, nice power supply, wish i had one, but i am frugal.
Thats why i’m on BLF
Do you do samples or discounts?
RD tech
RD tech's picture
thank you so much for your suggestion, I will consider and tell our engineer
for discount , now it is very lower, because of first time publish , the price is very lower , it is less 10 usd than normal price
RD6012 will be more than 63 usd ,. now it is only 52 usd
if you like it , you can buy one to pay
RD tech
RD tech's picture
thank you so much for your message , you are great , I like that
Yokiamy
Yokiamy's picture
Does that include the RD6012 with case and psu?
Cant choose that combination on AE.
RD tech
RD tech's picture
that price is only RD6012 price , for case and PSU , you need to make order seperately
where are you from ? it depends your country, I can decide to send them together even you make order together or not
RD tech
RD tech's picture
RD6012 customer review
I made a case for RD6012, no so big but it can output full power, it can take the place of my DPS3012
RD tech
RD tech's picture
As always, super fast shipping and delivery. A reliable seller. I recommend !!
(the shipping speed is not stable now, it may take more time than before)
KIOFB
works with a 24V source at 14 A?. thanks
¿funciona con una fuente 24V a 14 A?.gracias
RD tech
RD tech's picture
hello, just make sure the input voltage is between 6-70V DC, the input current of RD6012 has no limit, but it is a buck power supply, if you use 24V input, you can only get 22V max output
Agro
Agro's picture
Last seen: 1 min 43 sec ago
RD tech, you’re violating the BLF Rule that states:
Quote:
Please make only a few threads in the Commercial Sellers’ Spot category.
I count 25 of your threads already.
Agro
Agro's picture
On a separate note, I recommend BLFers to not buy RD tech products.
The reason is that I did, once. Then they started spamming me on Aliexpress.
I asked them to stop, they apologized but spam kept coming from them.
RD tech
RD tech's picture
I already reduced the post. I already know the rule… don’t need you to remind me
we have good quality products, they have their own chioce , why did they listen what you said ?
and for post on aliexpress, please tell me your order number , I will block all things for you
RD tech
RD tech's picture
as usual, everything is super, arrived quickly(it depends on the shipping company), packed at least in space
RD tech
RD tech's picture
rd6012 customer review
1. The seller's description is correct. 2. The seller shipped quickly. I arrived 10 days after payment. 3. The product is packed with styrofoam. 4. Works great. 5. The seller is reliable. ... great product
RD tech
RD tech's picture
RD6006 customer review
The product is well packaged. Consistent with the description.
RD tech
RD tech's picture
Good packed. awaiting for more test
RD tech
RD tech's picture
RD6012 review article in Russian
if you have time, you can have a look
https://mysku.ru/blog/aliexpress/80912.html
RD6012 link:www.aliexpress.com/item/4001053200176.html
RD tech
RD tech's picture
Delivery to the door and on time. The quality is excellent, the package is satisfied. Thanks seller
RD tech
RD tech's picture
Delivery is fast, packing is very reliable (a polyfoam box in which the box with the module is placed). Quality of assembly and soldering at height. Really steep step-down module RD6012 for assembly of the laboratory power supply unit. The RD6012 has a 2.4 inch color LCD display, really big and comfortable. Convenient controls (keyboard and pen encoder), push-button encoder works as a confirmation button. When connecting via a WIFI module to a smartphone, you can see more settings. The module can be connected to a PC via a USB cable, which further expands the ease of use. This makes it easier to track processes on a computer monitor, as well as store statistics. In reality, the RD6012 can output up to 60V. and 12A., which is equal to 720W. power. The RD6012 also has an additional output for charging batteries, which increases its functionality. Output voltage range: 0-60V (tested) Output current range: 0-12A (tested). I recommend !
RD tech
RD tech's picture
Very pleased with the purchase. Everything is at its best, both the manufacture and the operation of the device. good luck !!!
RD tech
RD tech's picture
RD6012 product review
Quality packaging! I thought the case would be damaged .... rd is good and accurate. I replenished myself with a toy :) I recommend it for purchase!
RD tech
RD tech's picture
hello, we have prepared some RD6006W+S06A+400W PSU/RD6012W+S12A+800W PSU to our US warehouse, if you live in US and have interest in this, you can order it in this link, it will be much faster than ship from China
RD tech
RD tech's picture
RD6012 customers review
Delivery of China to Ukraine 18days
(for the package we send to Ukraine, we don't use aliexpress standard shipping because it is slow and unstable, we use Meest shipping, it takes about 20 days to be delivered)
RD tech
RD tech's picture
It came very well packaged and 100% good quality.
