Samsung LH351D 5000k LED output test by Texas_Ace - Amazing output, low thermal resistance but high Vf
Ahh, sorry! I understood it wrongly. My brain processed “dome” instead of die! Ok, so if they fit will, I guess I won’t have problems with that! Also, I will probably use some optics such as 10511 or 10508 (floodier) so it will be a “wall of light” per se!
Thanks for the clarification!
And also for the info on the small SMO reflectors ! I may have a winner then :wink: I do like the Luxeon Leds, but after seeing what these do…I definitely wanna try them in other lights :wink:
Thanks once again for the information!! :beer:
Yup, I’ve put LH351D’s in a few Tool AAs with great results. They make a nice combination.
The last emitter swap I did was in a tool ti AAA. Turned out pretty good. I then swapped one in the brass tool AAA and shaved the LH351D.
I liked the shaved version better, actually I haven’t found anything yet that shaving this led didn’t look better in. I also built a triple in a RRT-01 and used the KD triple optic with shaved LH351D’s, turned out very nice. Wasn’t as nice with a carclo, too floody and the KD optic seemed to make the tint more pleasent.
FWIW (and question),
I knew the Samsung from the TLF Wuben E05-I and found it to be ugly greenish.
Recently, I ordered a couple of 2700K and 5000K LH351D from Sofirn and today implanted one of the 5000K LEDs in a C8 (BLF A6 driver, OPR, Manker MCPCB). What a difference! Those 5000K Samsungs from Sofirn are mostly neutral.
Do they have multiple bins at this color temperature, are there production specific variations or was there an update? I’d like to order more to equip a BLF Q8 with them, but would like to ensure they are still of this quality.
page 12
Can’t read those diagrams. Means: If I get R1 or R2, I’m around BBL, right?
If you prefer pink over greenish, you need to stay under BBL.
Contactcr tested a few LH351D’s from Digikey here. LH351D 90CRI Spectrum Tests
Shaving the dome lowers the cct and gets them even closer to the bbl.
Does the Samsung LH351D fit optics made for XP-G2’s (in my case it’s a quad optic bike light) without any modding?
Thanks!
-Garry
In most cases yes but the dome is larger on the 351D IIRC so it can have issues with some optics.
It will be MUCH floodier then an XP-G2 as well in the same optic.
Basically it is a case of try it and see how you like it.
Worse case, you could probably shave the dome off the LH351D. This will not only aid fitment if there is interference with the optic, but it will drop about 500K in CCT (5000K becomes 4500K), lowers DUV, and makes it less floody. You’d loose a few lumens though.
Thanks for the responses! I like the idea of plenty of flood, but I still need some throw.
-Garry
From this test…“The dome started to burn around 5A…”
Has anyone tried this the LH351D with Convoy’s 6A driver?
I am running it in S21A for few months now without issues
Good to know!
Cheers!
I’ve two pieces of Convoy S2+ on the 12-mode 5A driver and Samsung LH351D 4000k LED. Both LEDs seem to have developed burn/black spots on the dome.
the lights themselves work fine and the black spots don’t affect the beam pattern. But this is the first time I’ve seen this happen.
That didn’t happened to my s2+ 5000k, but my batteries only provide 3.5A.
Are you sure that isn’t any dust?
It’s not dust. I’ve tried to clean it off with lighter fluid and cotton swab, but it’s still there.
That’s weird. It shouldn’t happen with less than 5A. Anyway you can slice the dome like I did :blush:
The S2+ with LH351D is 5A.
