Do you think I should tell him about the ambien? It made me sleep well and no sleepwalking. That’s what I am afraid of is the sleepwalking.
I take antipsychotic meds that make me sleepy, and it is a lot worse now that I sit around home everyday twiddling my thumbs. I do most of my posts after taking meds, so I have productive things to do to stay awake and not sleep my life away from being inactive. I hope my posts make sense and are on topic, seriously. If I am making mistakes on here, the community has been nice enough not to grill me for it.
Lately, I wake up all over the house and backyard, but this is all new since the lock down started. At work I was always busy physically and mentally, and functioned great, but now I am a zombie and feel like junk. Funny how that works. I don’t dare drive these days. I get a ride from family when I really need to go somewhere.
Ambien does some nasty things to the brain, as the military found out.
Sounds almost a bit too obvious to ask if you’ve ever tried it, but for the rare times I can’t fall asleep, melatonin puts me out, and niacin keeps me out.
But for me, melatonin can be kinda weird. Pop it, maybe 20min later I’ll feel Mr Sandman coming, but if I force myself to stay awake (eg, to finish something) and miss that opportunity, forget it, game over. Mr Sandman goes home. Not even another hit will work.
NicOH puts you into a deeper sleep. 500mg is fine, but I tend to double-up to 1g being that I rarely take it. Bonus if you get a nice tingly “niacin burn”.
Man, I’m really sorry to hear that. That sounds like no fun at all. As far as this post it is totally cogent and coherent.
I will give this a try. Thanks man.
Ambien is a common longer-term usage sleep medicine. The other one you’re taking is in a class of medications called benzodiazepines I believer meant to calm you down (a nervous system depressant). They can be addicting (xanax, Ativan are two well known drugs of this type) and have side effects like mood disturbances, hallucinations, or at worst suicidal thoughts or even behavioral issues and are more commonly used for things like anxiety disorders or panic disorders.
You might also try a natural way and take melatonin or tryptophan supplements. Those are naturally occurring and can help you fall asleep.
Or pop open a can of Ribs Sleep-Aid…
Thank you everyone for advice. This will give me a lot of options that I was unaware of.
As far as melatonin, you don’t have to (and probably shouldn’t) overdo it, but it might take a while to dial in the “right” dose for you personally. I’d get the biggest dose then split into halves or even quarters (cheaper vs smaller-dose pills).
NicOH, just pop a gram and be done with it. You can get the “extended release” (“hex”) version if you want, but for me the straight-up version works fine. And I like the burn.
Oh, if this is a necessarily daily thing, don’t go over 1g/day of NicOH.
Zaleplon is a hypnotic, not a benzo AFAIK but that’s not much better.
If you don’t want to mention trying the ambien just tell your doc about the side effects of what you were prescribed and that you’re looking for something different.
It’s not recommended for long-term use but on occasion I’ll use diphenhydramine (Benadryl) when I really need to sleep and am not tired yet.
I have never been on any meds in 60 years, because for me, the cure for this life is soon and elsewhere. Please be careful with sleep meds, due to tolerance and withdrawal. Tolerance means that more and more is needed to get the same result. The initial dosage soon does not produce the result that it used to produce. Withdrawal means that stopping or reducing the med will cause rebound effect: The initial problem comes back, but not just that, but even worse. Sleep meds are best for very short term use. For ten years, before I retired, I participated in clinical staffings twice a week at JCAHO health facilities. Net result: The reasonable thought comes: Possibility of being mindful to avoid prescription sleep meds to avoid making the situation worse.
The only thing I take to sleep is Melatonin.
I like the time release version, though it's pricier.
Some of my meds might make me somewhat sleepy, but I take most of my meds before bedtime so it works out fine for me.
By the way, I wouldn't touch any sleep medication other than Melatonin.
They're not supposed to be used in the long run, and can have serious side effects.
It sounds like you’ve already been diagnosed with significant difficulty sleeping, and Ambien reportedly works for your mother-in-law, so there should be no suspicion why you would ask about it, especially after you explain your sleep-walking.
It will be up to the doctor to counsel on this matter, but I don’t know whether Ambien is the right solution. As far as I can tell, it seems to be closely related, which makes me wonder if the effect could be intermittent to you.
I’m unclear from reading this thread - have you already tried limiting your light levels for 1-2 hours before bed, and did you already try melatonin? I would think the doctor would have suggested it before going with a prescription drug, but just in case, it seems worth mentioning.
If your kids are waking you because they sleep in your bedroom, then that seems like a compelling reason to start planning how to transition them to their own room, but I’d imagine you want relief faster than that would take, and to get caught up on sleep before attempting it.
It’s a hypnotic. It’s prescribed here as Zopiclone and I had the same effects as you. Basically it puts you in a sleepy but hypnotic state, so if you’re not actually asleep you are in a state of hypnosis, hence doing things you’re unaware of. I’ve also been prescribed amitriptyline, but it has a long half life and left me feeling half asleep and fatigued through the next day. I didn’t get on with either of them. My wife had a hard time persuading me the spare bedroom wasn’t the bathroom one night and trying to stop me peeing in the laundry basket.
If I’ve had two or three nights of no sleep or a waking kind of anxious sleep I take an over the counter sleep aid, diphenhydramine. It’s an anti histamine that causes drowsiness. Having read the thread I think I’ll try melatonin for the rare occasions I need something. It’s often an anxiety thing, a fear of not being able to go to sleep, creating a vicious circle of worrying about not getting enough and clock watching during the night. Best of luck, insomnia is a pain in the backside.
we had a set of crying twins and that was rough on getting any sleep. You might try something that worked for me: Take 2 foam earplugs and squeeze them into your ear holes.
No advice, just sympathy. I’ve been through it. On the far side of it at the moment and it was always tied to heavy stuff going on (death in the family etc.) I needed the sleep so I medicated. The wife told me I was sleepwalking but I was just stoned on whatever drug was supposed to have me asleep. I had a scare a few years ago. A guy in my neighborhood was run down with a car like mine. I was afraid it might have been me but I couldn’t remember. I got a hold of cam pix of the incident and saw that it clearly wasn’t my car and the person driving was twice my size. I was relieved but concerned because I knew it was possible. I don’t touch anything like that anymore. Be careful, if you can’t live without the meds give your wife the keys, lock up the guns etc. before bed.
I remember seeing a TV spot years ago that had a story about Ambien.
It recounted - accounts of Sleep Eating.
People getting up, raiding the Fridg, and not remembering anything.
They or their house mates setup kid-cams to catch action.
I can believe Sleep Posting could be a thing.
I’m going to claim it next time I act like a jerk in a thread.
I took Ambien for a while. Worked like a champ.
I did have bouts of sleep reading.
I’d take a pill, then read.
Next nigh I’d pick up the book and wonder how the heck I got where I was.
Didn’t remember reading most of the stuff from the previous night.
The good part, I didn’t go through books as fast!
All the Best,
Jeff
Your drug is called Zaleplon. Commonly known as Sonata.
Certainly sounds like you need to change your medication. See you doctor. None of us on are are qualified. We can share our experience.
Years ago I got my Mom off of Ambien. a nasty drug with many side effects,especially memory loss.
I have had sleep issues for 25 plus years[60 now]. I do not like drugs/taking sleep medicine. But I have found one that works for me[that is the key, we are all different] that I take sporadically and it has very little side effects on me. It is called Temazepam.
Good luck
I avoid prescription medication. A pill may put you ‘out cold’ but it is not sleep.
No, soporifics are exactly that - pills that help you get to sleep (or make not falling asleep basically impossible depending on dosage and strength). Not all of them are prescription/controlled either.
