do you know a powerful zoomie with dual control, tail switch and mode button?
I am looking for a powerful led (most lumens) zoomie that has 2 switches: one for mode control with memory and one tailswitch for on/off… i intend to swap the tailswitch with a pressure pad so i can select strobe or turbo from the mode button and use the pressure pad to power up the flashlight in that mode. Budget: 50$ or less…
i found this: No Name Chinese Flashlight and it ships from Eu too, so that is a big plus… but there is no brand, the led is a chinese made “XHP99” so it offers me no guarantee that it is better then a SK 68 replica… Also, both of the buttons are on the side of the flashlight, so i do ont know if replacing the tailcap with a tail switch with a pressure pad will solve the issue…
Can you please suggest something better, i really have no $$ to spend on trial and error… Also, do you know a spare driver that has this functionality?
not really, that is an odd combination of features
The Fenix FD41 appears to meet all your requirements except $budget.
Perhaps you can post a “Want to Buy” and find a used one.
then what about a really powerful zoomie with a simple driver and on of tail switch? i will make a custom press pad with dedicated strobe integrated and PCB .
i found this driver, is it any good?
https://www.aliexpress.com/item/32995732567.html?spm=a2g0s.8937460.0.0.30b92e0eBbfghq
if so, i could integrate this in a flashlight you would recommend.
or something like this, and just use a flashlight head for the build… where i intend to mount it, i have room for 2 external 10-650 and just use a wire to the head.
https://www.aliexpress.com/item/32893575502.html?spm=a2g0o.detail.1000014.15.771c2446cKpaLn&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.13338.170518.0&scm_id=1007.13338.170518.0&scm-url=1007.13338.170518.0&pvid=33444cb3-a0bb-446b-87d5-9037abb43988&\_t=gps-id:pcDetailBottomMoreOtherSeller,scm-url:1007.13338.170518.0,pvid:33444cb3-a0bb-446b-87d5-9037abb43988,tpp_buckets:668%230%23177981%236_668%23808%237756%23221_668%23888%233325%2313_3338%230%23170518%230_3338%233142%239890%238_668%232846%238116%23994_668%232717%237561%23327_668%233164%239976%23358
what i need is for it to be blinding at 10-100m in the dark if pointed at you and force th oponent to look elseware.
i will mount it on my airsoft weaapon and use it like in this video: Airsoft noobs join airsoft kill house with with ex soldier - YouTube
please help me out in my project!
nobody has any idea?
Sorry, no help from me.
Why not throw out the zoomie and get a Osram CSLNM1.TG led and install it into the Convoy C8+. Very narrow beam but 950 meters throw with a really intense hotspot. Even a Osram CSLPM1.TG for less throw but more lumens using Convoy’s 5A driver
A budget zoomy is quite difficult to find that’s bright and well made and not forgetting small enough to mount
Post your question on this thread
