I have both Emisar D18 and Emisar D4V2 with deep red SST-20-DR emitters. They are fun to use, and quite bright!
For a small fee, Hank from intl-outdoor can build a flashlight for you with custom emitters. I emailed him and asked for SST-20-DR-B120-V660.
Note that the human eye is significantly less sensitive to deep red light, so if you get a flashlight with only 1 deep red LED it won’t be very bright.
Now, that's some real good news! What driver did Hank use for the Emisar D4V2? I can't imagine that SST-20-DR will like high currents with FET. Did he use the 5A driver from KR4 or is the maximum current limited by software (Andúril)?
There is nothing different about it, it uses the standard D4V2 driver.
I don’t think Hank used limited FET firmware (typically used for Nichia 219) in mine. I assume he would have told me if he did, so that I would know to use the limited FET firmware when I flash a new version.
SST-20-DR is rated up to 3A, which is the same as SST-20 4000K. It seems to heat up less than my D4V2 with SST-20 4000K, so I assume it is not pulling too much current. Maybe it is more efficient? It does have a low Vf, so I wonder how much current it is actually pulling, and if it could be an issue.
While I don't know the fine details of what you are discussing concerning that D4V2, I will just say that driving deep red emitters in parallel with an unregulated driver is just bollocks. Even a linear driver is inadequate, because the large voltage difference between input and emitters Vf needs to be dissipated at the regulators, being very inefficient and causing massive heat dissipation.
The right answer is a buck driver, or a boost driver with emitters in series (or boost-buck if 2S2P). Maybe its time to develop some :???: new driver, because every time I look for buck drivers in the chinese market it either makes me want to cry or kick someone else's arse let's say I just don't like what I see. O:)
I’ve seen the same press coverage regarding this. I’ve got eye issues and I support myself and my family doing graphic design and it’s a great worry as I get older. I want to look into this to support my eye function going forward.
There’s not much info about how to make a 670nm red light source, though you can buy them for upwards of 100 EUR. I’m certainly no technical whiz, but any tips gratefully received.
It's hard to extract any conclusions concerning how good such emitter is without any further information, i.e. manufacturer & model, datasheet and/or some real-world test(s).
The format of the emitter looks unenticing for flashlight usage.
Hi,
We are already taking here about 10W LEDs like SST-20-DR. Does anyone know what power is actually needed? Maybe couple 5mm LEDs is enough?
Red and IR LEDs are already used in all kinds of therapy. See sample description here.
I have seen a device for that myself. Have a fried who used it to help healing a wound (not very deep but large scratch after falling from a mountain bike) and he says it helped, don’t know about that (he is a doctor)
This thing was using an IR laser diode with some optics on it to make wider beam plus some additional red and IR diodes (hard to tell what they were because of some cloudy convex lenses on them).
It was using them at relatively high power I guess and PWM to adjust average power by changing duty cycle, it could also change frequency from few to few hundred Hz – no idea what the purpose of that.
I guess because it was designed to also help with muscle stimulation it has to reach deep, so high power, but not to burn skin so PWM to keep average low.
It was old device and laser diode could be needed to get required power, maybe current IR LEDs are good enough.
With eyes I would think you don’t need much power to get where needed but I didn’t see in any of these articles anything about power they used. Did I miss it? Anybody knows?
I’ve just found that RS componentes in Spain has a whole list of LED products, from reputable manufacturers with datasheets and so on. Then there’s no crazy delivery costs for me as I’m based here.
I still think a flashlight based solution would be the most practical one though. Does anyone have any good info about making custom flashlights for a beginner like me?
I’ve just got my hands on the paper that the scientists published… The only thing they say about the light they used is this:
“670nm light devices were based on simple commercial DC torches with ten 670nm LEDs mounted behind a light diffuser embedded in a tube that was 4cm in diameter.”
Sofirn is producing a limited run of a AAA-powered 660nm red light.
That’s really close in wavelength. As I posted further upthread, the study leaves a lot of questions open. One that I didn’t bring up is if this effect is corroborated by future research, whether there is anything special about exactly 670nm, or does it apply to a range of deep red wavelengths?
This is another one of the questions raised by the reporting on the study.
I checked the academic journals that my local library has access to, but this paper did not appear in a search, so I can’t see if they detailed what intensity they used.
For a 10 GBP light, I doubt they’re driving it at 10W.
Ah, thanks for finding that. I’m betting they’re 5mm LED’s swapped into a 3xAAA light.
A 660nm red led still has enough emission at 670nm as to be considered a valid 670nm source, too.
As an example, according to the Cree XP-E datasheet peak wavelenght range for deep or photo red emitters ranges from 650nm (P2 group) to 670nm (P5 group). If frequency is so important careful emitter selection and testing is mandatory, or sourcing some precise group emitter batch.
In any case, let me tell you that deep red frequencies won't damage your eyes. Well, maybe if you do something :???: :facepalm: @#$%. For example, many years ago I did the “exercise” of directly staring at the sun with my naked eyes, for 1 - 2 minutes maybe, 2 - 3 times in a few weeks. Yes, my eyes got damaged. Macular degeneration, in fact. But I never doubted it would heal, and refused to go to any @#$% doctor. Just took a crapload of meso-zeaxanthin, zeaxanthin and lutein supplements for a few months. And my eyes healed. Period. Oh! How and why did I did that? I was drugged, and despite it was a very spiritual thing for me at the time, that couldn't impede subtle negative entities from impairing my judgement.
Yep, my thought too. You wouldn’t need ten high-power emitters to get an eyeball-safe level of light, even with the diffuser.
The diffuser is crucial. You should never stare directly into a modern LED, even if it’s “only” a 5mm one.
A 1mW laser is enough to do permanent damage to the retina. 10mW of LED light from the tiny chip you get in a 5mm LED is intense enough to be pushing your luck when combined with the focusing effect of the 5mm LED package.
If you experiment with this stuff, please play it safe with your eyes.
Having said all that, it occurs to me that using high power emitters with a diffuser to light up a whole room might be a safer way of getting a similar light exposure without having to look directly into anything.
Yes considering the lower sensitivity of human eyes to Deep Red light, I’m curious see how will be the output of the C01R .
I hope the boost driver would be very efficient and optimized for this Red Led
but I don’t expect miracles from an AAA light
Some of you seem to be taking this too seriously, don't you? The eye care thing, I mean. Some people here speak about “permanent damage”, but there's no such a thing unless you are a jinx or just chose to learn from the wrong person. I know what I am speaking of.
Everyone around here has had hair in the crotch for enough time already. Be responsible for what you do, and deal with its consequences. It's that easy.
Your experiment with staring directly at the sun seems quite extreme, I would love to know more. What exactly did you see? How did it progress as you kept doing it, and what happened when you stopped? Why did you stop?
Don’t forget about the eye safety. Higher power is not necessary the best and can harm eyes because we can’t see it well and can’t react appropriately.
Just make sure it’s intrinsically eye safe even at the minimal distance.
