it looks like the bezel should come off, it’s seems it’s screwed into the head, it is slightly protruding.
Get a rubber or other flat grippy surface and try to open it holding it down firmly while turning it
Got mine few minutes ago. Unprotected batteries work well If you add some coins to the negative end.
Do not use crappy batteries from bangood or etc. Flashlight works for 10 seconds in turbo then Red led flashes due to voltage drop. You will have to reinstall the battery If this happens.
Estou tentando um reembolso da Imalent sobre essa luz, apesar de todos os esforços a luz insiste em não funcionar como deveria…. mesmo com tantos videos e postagens dos problemas desse projeto a Imalent insiste em não admitir o erro nessa luz…. lamentável… Apartir de agora, Imalent nunca mais! Ganaciosos!!!
I am trying to get a refund from Imalent on this light, despite everyone who is suffering a light insist on not working as it should…. even with so many videos and posts of the problems of this project in a last case, not admitting the error in that light…. unfortunate… From now on, Imalent never again! Greedy !!!
The 3000lm “Medium II” mode throttles too (as well as High and Turbo)
From turbo, you have to go through off to get to low modes
The 21700 cell doesn’t fit in an XTAR VC4 or PBS2
The Haikelite MT09R is a triple XHP70.2 light and managed to get 25,000lm from 4 18650s. This should technically be achievable with a single 40A 21700 cell.
Hey I just got mine yesterday and I have to say, it’s pretty sweet. The UI is really intuitive, it’s tiny, and the light output is absolutely incredible. Makes my old
Nitecore TM26 look like a keychain light
Only thing I’m stumped on is how to attach the wrist lanyard. Unlike every flashlight on the planet it doesn’t seem to have a tiny hole of anything on the Back end cap To thread the lanyard cord through
There are two holes on the radiator fins near the front but the lanyard they included isn’t long enough to go around my hand and wrist and still hold the light normally
I have some bigger lanyards that I got from amazon (awesome… can send info if anyone cares) but I feel like I’m missing something on attaching this
Found an extra 21700 cell on eBay for $25. Was like $39 from imalent. Imalent said that their 5,000 mah 21700 doesn’t fit on this light btw
Imalents flashlights are grossly over rated and there quality is so so at best yet they ask top dollar for there products. I really like some of there designs but would not buy from them again. This young company has lots to learn if they want return customers.
The included MS03 cell is a protected 40T. All non protected 21700 (including 40T) are too short to make contact in a stock MS03, you need an added button top or solder blob.
