Thunite and Olight UIs both do this, as well an Anuduril/Narsil lights (they ramp down instead of starting the mode cycle). Wurkkos FC11 ramps down from turbo on hold as well, and I believe it’s how the Sofirn side-switch lights other than the SP10S operate as well.
It doesn’t return you to the previous brightness (if you go from on to turbo) but starts the mode cycle at the lowest non-moonlight mode and cycles up until you release.
For me personally not turning off from a single click in any setting is a downside for any light. Having to click, wait, then click again to turn off from turbo on my YLP Unicorn (because I forget to use the weird click+hold for off shortcut that only works in turbo) mars an otherwise fantastic UI.
I would not be upset with a 70 or 80 CRI Samsung emitter for the “spot” function. It cannot have worse tint/rainbow than XP-L2 and probably not SST-20 5000K either. SST-20 5K should be fine too, still much better beam and tint than the XP-G3 many other lights with the spot/flood combo are using.
……yes, that is the point about size and weight when we decide to use a 21700, for a input and output 21700 with more power and runtime…
Power and runtime depend on much more factors. For example from driver efficiency. So what kind of driver you will use?
As far as I was told, HD20's driver will use FET. The charging currents are 2A (recharging battery) and 1A (reverse charging from battery to external device). Please note that this is yet to be confirmed by Wurkkos/Sofirn.
I like the choice of LEDs and the UI, I also like the design of the flashlight, I would like to be made in dark gray.
I know that there are flashlights that are regulated, and others that are not. I would be very interested if this flashlight had a good regulation. To give a good example, the Nitecore HC35 is capable of keeping 800 lumens totally stable for almost 4 hours straight with a 5000mah 21700, I would love for this Wukkos to do something similar. If this have a good regulation and a good price, No doubt, i would buy it.
Not sure if the C8G driver is appropriate here. It is designed to drive a 12V XHP35 HI emitter. The first batch I tested had a rather mediocre ramping curve when increasing the brightness. The current applied to the XHP35 HI was about 1.7A only, leaving a lot of potential unused. Moreover, thermal regulation acted way too early on this light. Fortunately, both Wurkkos and Sofirn have agreed to raise the thermal threshold for HD20 to 55°C in return for better performance/longer runtimes on Turbo/High mode. As far as I was told HD20 will be using an FET driver, i.e. no boost driver with full stabilization.
I’ll take CC linear running on a FET + sense resistor or similar over PWM’ed linear chips any day as long as there is a sub-lumen mode.
Once a cells voltage under load drops below the Vf of your chosen output it will drop anyway. Only a sufficiently low Vf emitter and buck driver, or boost/buck-boost will achieve what I see so many in this community call “regulation”.
If a flashlight has any electronics that control the flow of electricity in at least one mode, it is “regulated”.
I don’t really understand the benefit of defined steps to lower modes when cell voltage drops vs this. Either has the same end result of higher modes losing max output as the cell drains, its why I choose lights with boost drivers whenever possible… because that or multi-cell + buck are the only ways to avoid it.
the drain down to 2.65V is excessive. Most of our firmware triggers LVP at around 3.2 - 3.0V. Looks like this light has no LVP
3.4V down to 3.0V is a significant drop, > 50%. If you look at a normal drain from 4.2V down to 3.4V, the lumens drops in half. That's about right, and matches what many lights use as "Turbo" to "High". 3.4V to 3.0V is a small percentage of the cell range and happens quickly - refer to discharge curves
lower modes are typically in the 1-500 range anyway, still quite relevant. Also lower modes could be using a low channel having better efficiency that the FET shown in the graph
This graph is typical of most of our FET based drivers running on only the full max FET.
This chart does not show that the light will do that before the battery is extremely low. You’d need a runtime chart of that lower mode to see if it drops proportionally over a discharge cycle. In Maukka’s test Vf for 100lm from a 90CRI LH351D is only 2.7V.
Again, the only lights that can sustain brightness like that are those with boost drivers, or multiple cells (with combined voltage exceeding emitter VF) + a buck driver. As soon as the voltage at the emitter drops below the Vf required for a given output, that output will start to decrease. This happens with lights that have an extra 7135 channel for low modes as well since they also cannot step-up voltage.
What are some of the “real lights” that don’t have a drop in output like the graph you posted? What type of alternative driver would you propose for this light?
