samgalax
(samgalax)
July 9, 2020, 2:27pm
783
I have it.
It is totally smart.
But with old batteries (high internal resistance) it has a bit of problem.
When using as charger… It reports them as “batteries should be replaced”.(but it charges them… Other chargers simply refuse to charge them)
When using as powerbank… The output current is not 1Amp… More likely 500-700mA.
If you want full 1Amp output, you must use young/new batteries with low internal resistance.
With my old eneloop XX( with a few cycles) it shows that behaviour.
With my white eneloop (with many cycles) it works like a charm. No yellow led indicating batteries should be replaced and full 1Amp output
hodor
(hodor)
July 9, 2020, 2:37pm
784
Ah good to hear! Shame to hear about the output but I guess I could just keep some new cells with me if I need to use it as a powerbank.
Did you look into the little flashlight attachment?
Pete7874
(Pete7874)
July 9, 2020, 2:41pm
785
Based on the charging time table, it looks like those current values apply if you charge all 4 cells simultaneously. If you only charge 1-2 cells, charging times are cut in half, which would indicate that current is doubled, so a single AAA cell would be charged using 0.5A current.
Pete7874
(Pete7874)
July 9, 2020, 2:48pm
786
What flashlight attachment? I am not seeing anything on that page, unless I missed it or my ad blocker got it.
Are you referring to something like this?
https://www.aliexpress.com/item/32954157366.html
https://www.banggood.com/Portable-LED-USB-Light-For-Computer-Notebook-PC-Laptop-Power-Bank-p-970496.html
hodor
(hodor)
July 9, 2020, 3:04pm
787
Hmm ok, makes sense. I’ll take another look through the manual.
Here’s the attachment which I mentioned and also ChibiM posted a few pages back.
There’s probably nothing special about it and a 3rd party USB light would probably be just as good or even better.
samgalax
(samgalax)
July 9, 2020, 3:11pm
788
hodor:
Any way to get that led light attachment? Can be purchased separately?
EDIT: the led usb light attachment is included only in japan version. Eu version dont include
ChibiM
(ChibiM)
July 9, 2020, 3:25pm
789
Correct, only available in Japan as far as I know. Still a fun attachment. I have one personally.
XTAR sell a little USB light as well, if it’s any use:
XTAR UL1-120 EDC Light-ShenZhen XTAR Electronics Co., Ltd-· One LED for a four-color light
· One button for seven modes
· Wide application
· Strobe mode for self-protection
· USB port, plug and use
· USB metal hose for 720° light control
I don’t have one myself, though, so that’s all I know.
Patu
(Patu)
August 30, 2020, 5:37am
791
All aneloop and nihm type batteries are overrated and overhyped if you need run device with minumum 1.5 voltage battery. I’m really disappointed.
nibble
(nibble)
August 30, 2020, 9:20am
792
NiMH are nominal 1.2 V and they excel for their purpose.
Pete7874
(Pete7874)
August 30, 2020, 11:58am
793
How many devices out there require 1.5V minimum?
Most standard or alkaline batteries do not stay at 1.5V very long. For those applications, something like Tenavolts (1.5V Li-Ion) may be best.
thefreeman
(thefreeman)
August 30, 2020, 3:37pm
794
Pete7874:
Not many that I have personally, but my current clamp ( uni-t 210E) starts reporting wrong numbers when the cells are under ~1.45V, it’s really bad. My meteo station modules seems to have a high cut off, although not as bad.
I’m wary of the potential self discharge rate of a li-ion cell coupled with a voltage converter, but more importantly they are extremely expensive.
Pete7874
(Pete7874)
August 30, 2020, 3:45pm
795
Yes. Luckily I bought some on sale for under $12 for 4 AA Tenavolts and a charger. That’s about the same price as 4 eneloops.
I am using them in one of my universal Harmony remotes.
Patu
(Patu)
August 30, 2020, 5:58pm
796
Pete7874:
This:
I need to try the luck with 10440.
Pete7874
(Pete7874)
August 30, 2020, 6:57pm
797
If that sensor is going to sit outside, exposed to significant temperature extremes, your best bet would be lithium primary.
Rexlion
(Rexlion)
August 30, 2020, 9:32pm
798
One of my old Canon digicams would show low battery almost immediately (maybe take a half dozen photos first, that’s about all) with any NiMH. I put some lithium primaries in and they were good for a couple hundred pics.
ChibiM
(ChibiM)
September 16, 2020, 7:23pm
799
Some devices don't really like NiMH batteries because of their voltage, but that doesn't mean they still are one of the best rechargeable NiMH batteries on the planet..
ChibiM
(ChibiM)
September 16, 2020, 7:25pm
800
New fake Eneloops spotted in India this time. Thanks to a reader named Shashi, who tipped me.
What do you think looks weird on this packaging?
and
Sirstinky
(Sirstinky)
September 16, 2020, 8:36pm
801
“Japan technology” would not be on the packaging. Plus some other details like the graphics don’t look right. Shame on people for copying Eneloops. Plus, correct me if I’m wrong, but the LSD Eneloops are made by FDK I believe. No one else makes them to my knowledge since it’s a trade secret.
d_t_a
(d_t_a)
September 17, 2020, 3:32am
802
Maybe try comparing with a couple of AAA Eneloop (both are genuine Eneloops, left side is "Made in China" ; right side is "Made in Japan")
