Simon_Mao
(Simon Mao)
July 11, 2020, 10:05am
2703
2020/7/11
osram KW CSLNM1.1TG bin 6N-ebxD46-15 (6000-6500K)
3030 DTP copper board
samsung LH351D 90CRI SPHWHTL3DA0TV4QTS6 bin V2Q2S1 5700K
samsung LH351D 90CRI SPHWHTL3DA0GF4RTS6 bin F2R2S2 5000K
LD351D 90CRI 4000K will be available after half month
i will add these in my store at next week
oweban
(oweban)
July 11, 2020, 10:12am
2704
Finally, another place to get these
ZozzV6
(ZozzV6)
July 11, 2020, 10:54am
2706
That is really good news Simon. Now I don’t need to solder osram leds on 3535 MCPCB’s aní more. I think I will buy 10-20 of those MCPCB’s
id30209
(id30209)
July 11, 2020, 10:57am
2707
At last. Convoy is beating KD. Slowly though...
Blggg
(Blggg)
July 11, 2020, 2:33pm
2709
Which models can use the LH351D?
ZozzV6
(ZozzV6)
July 11, 2020, 2:39pm
2710
All 3V led models so you can replace XP-L, XP- L HI, SST20, SST40, XM-L2, XP-G2…… leds with them.
Blggg
(Blggg)
July 11, 2020, 2:47pm
2711
Thank you, ZozzV6. I think I might get either S12 or S21A with 5k LH351Ds. Hope both are good hosts for the emittter and the tint bin is good.
Yokiamy
(Yokiamy)
July 11, 2020, 2:53pm
2712
Simon, any updates about the 4x18 with SBT90?
I have a 4000K & 5000K LH351D in my S21A hosts and they are great! You'll want a driver that senses temperature for step down.
Blggg
(Blggg)
July 11, 2020, 9:44pm
2714
I see. Do you think the current 6A driver would be fine with the emitter? Will it overdrive a single LH351D? I see that in Sofirn lights, the max current drawn by this Led is about 3-4A, which is about 1,300 lumens. Wonder if Simon has to make some new drivers just for this.
6 amps is not a problem. Check this out:
kiriba-ru sent me these LED’s to test. I had never even heard of them before so I didn’t hold out a lot of hope for them but they really surprised me! They have one of the lowest apparent thermal resistance I have seen so far. This can be seen in how the output hardly jumps from a cold start, that says it is moving the heat away very efficiently.
The output is also very impressive at over 2200 lumens! This is more then any other 3V LED I have hot tested. The XP-L2 will make a bit more from a co…
contactcr
(contactcr)
July 11, 2020, 11:05pm
2717
Can we hear more about the Z1?
oweban
(oweban)
July 11, 2020, 11:26pm
2718
Yeah WF1 5A max. Got one in a C8+ with the 5A convoy driver and it’s punchy as hell.
Blggg
(Blggg)
July 12, 2020, 1:51am
2719
For a good combination of flood and throw, I think the S12 with the stock 6A driver should be good. Will ask Simon if it is plausible.
Nooner
(Nooner)
July 14, 2020, 1:28pm
2720
Have throw numbers been revealed for the new Z1?
oweban
(oweban)
July 14, 2020, 1:41pm
2722
Nope, it’s happy at 5A. I think anything above that gets a bit iffy though.
