C8S is a sweet host and that deal that came up from the ThorFire rep on the forum was too good to pass up. Larger driver, tail standing and thumb compatible switch, nice machining.
Since I dislike low CRI CW and since the UV light of the K3 lite is too easily activated, it got a SST-20@4000K (main, for a little more throw) and a 219B sw45k D200 because everything else is red or rosy, too.
Not a nice mod. Fitorch lived up to the RoHS regulation and used leadfree solder. Melted at approx. 230 Ā°C Taking this apart is also not nice
Edit:
Armytek Zippy. The 5000K Nichia 219C is a little tilted. I never before reflow over a candle. May fail or not, LED swap is easy enough for a second try.
Good news for SP40 users: 219B with no beam artifacts
Donāt know if turbo is healthy for the LED, probably not, but color is still ok.
I found out the 17mm forward clicky from mountain electronics will fit a Lumintop Tool AA with some dremeling to reduce the diameter a little bit. I used an old surefire switch boot with no nub and itās worked great so far.
Also swapped Osram W2s into a FW3A, my first emitter swap. I love the W2 emitter. Love the torch labs clips too. Their 1ā clip just took a little sanding on the inner diameter to fit and the Convoy had to be drilled and tapped. The convoy next to the FW3A was modded by Skylumen with an sbt90.
Finally have a warm thrower. XPL HD 3000k in a Astrolux C8. Too lazy to slice it so itāll stay an HD. And itās not as warm as I thought it would be. Kinda disappointed but also happy about it.
