【convoy】H4 and B35AM options are updated
6 amps is not a problem. Check this out:
Except for:
:laughing:
Can we hear more about the Z1?
Yeah WF1 5A max. Got one in a C8+ with the 5A convoy driver and it’s punchy as hell.
For a good combination of flood and throw, I think the S12 with the stock 6A driver should be good. Will ask Simon if it is plausible.
Have throw numbers been revealed for the new Z1?
Angry blue?
Nope, it’s happy at 5A. I think anything above that gets a bit iffy though.
I had the same host, with bypassed springs, and LH351D with a Mtn FET. I went on walks and otherwise used it for a few months with high drain cells. No angry blue.
But, I did switch the LED out of the C8+ for a 6500K SST40. From what's being highlighted here, I'll be fine with running the LH351D at a safer amperage.
Is the M21A only available in Black color? Are other colors not available or not genuine?
like this
and only SST40?
Is it not suitable for a XHP emiter?
I noticed that Gearbest has some sand colored product but anything other than the two colors, I'd ask Simon about their authenticity.
For a XHP 50.2, It'll handle the heat for a little while at turbo but this having a throwy beam, you don't have to run it at turbo to light up the target really well. Go with a 3 volt emitter.
Simon please do a batch of all copper heatsinks for Z1. If performance is good users will buy so they can further tune the light. If in the future you put white flat or XHP50 in it you will want this as well.
I got my package in 12 days !!, Thank you Simon, better service than Amazon :slight_smile:
On another note, I started learning about SEO and noticed some misspelling on your Aliexpress store like this one:
title>Convoy flashlight Store - Amazing prodcuts with exclusive discounts on AliExpress </title
Hope this helps and brings you lots of business :+1:
Just ordered S12 with 5k 351D, hope to get them fast!
Does anyone know if the lighted tailcap works with 17mm SST40 5000mA driver?
I have also ordered the same. I have asked him for the beamshots of any models using LH351D, but he’s been a bit busy.
Yes it does :+1:
Thanks for testing!
This depends on market demand. Copper has good performance, but the surface is easy to oxidize and blacken.
The white flat LED is worth trying, but I don’t recommend XHP LEDs. The edges of the light spots are yellow-green and the color temperature in the middle is blue.
thank you for your feedback.
Some content is automatically added by the aliexpress system, especially the description of aliexpress on logistics will mislead some buyers, and some buyers will mistake the estimated logistics time as the actual logistics time. Especially with the recent unstable logistics, I became a “liar”.
