Lumintop Tool AA 2.0 flashlight
LVP: There is disagreement. Above says no LVP. But Zeroair reports that this light does have LVP
Observed 3.04 v cutoff
I’d prefer to use a non-protected 14500, but would do so only if it has LVP. So, any help with resolution of the disagreement would be appreciated.
It has lvp which was 3,05 V in my case
Thanks for the quick reply.
Another important thing to mention, the lighted tailcap (only works with 14500) has a high parasitic drain of 8,5 mA
It will eventually drain your cell (i removed the LED’s in the lighted tail)
Mathematically speaking that’s only about 100 hours using a 850mah cell.
A little over 4 days and the battery is dead. Is that about what everyone experienced?
I changed my current limiting resisitors to a higher value right after I received, so I dont know how it was factory.
I can’t remember how high mine have been, but yes, it was right along those lines. I was dumbfounded.
The EE must have been out that day the resistor value was chosen. :person_facepalming:
I think the Tool AA 2.0 may not have LVP, so maybe a protected battery is suggested?
It has LVP set at 3V
So what if you don’t want the battery drain from the LED tail but you still want to use 14500 batteries? Is there a simple solution?
Turn the head 1/4 turn to break contact.
LOL — don’t like doing that. Is there another simple option?
Yokiamy, can you please share the source of your information? because I dont know who to believe:
If you want to keep the tail light and use 14500, nope.
Don’t really need the tail light. Does that open up any other solutions?
Yeah, just remove the leds so no lights at all on the tail.
I'll take a look at that and see if it is something I can do with my lack of skills. Thanks
If you can take the tail switch apart, you can remove the leds imo.
more AA Tool on 14500, LED tail discussion here:
When the light is turned on the driver is running with the firmware, checking for LVP. When you turn it off, the driver is off (switch breaks connection) and not checking a thing. The lighted tail switch is working in backwards polarity compared to the driver. No power to driver, lighted tailcap power is on and no LVP. The lighted tailcap will drain your battery dry while the driver is sleeping :smiley: .
