Anduril ... 2?
It will be the first combination that kid press))
Yeah :+1:
It was an example. How about 7? ;)
I’m liking the music examples. How about you have to tap the rhythm to the trumpet solo from Stevie Wonder’s “Sir Duke” to get to config.
Tap some 7/4 John Bonham for rock lock-out.
I like this idea)
Another opinion to enter in config by hold during twisting tailcap.
Sorry, I can’t do that in firmware. The brightness is determined by hardware, not firmware. So there are only three brightness settings:
  • High: Power on, internal resistor off.
  • Low: Power on, internal resistor on.
  • Off: Power off.
It can control whether the power is on or off… and whether the control chip’s internal resistor is added into the circuit to reduce brightness. But it can’t control how much.
Instead of a few short menus attached to the mode they configure, at 1 to 3 items each… you would prefer one long menu with about 10 to 20 items?
At last count, there were 21 config values… of which about half are set from a menu and half are set using some other action. The number changes over time though, as things are added and removed.
How would people configure lights which are physically incapable of this?
It uses “hold while connecting power” for factory reset, on most lights… so it would need another way to do that. And it would need to be really easy to do, since it’s a safety net for new users.
So it is not user friendly UI I see. Easy config for lite mode is big issue for ordinary user.
The idea for the simple UI is that most people won’t have to configure it… just take it out of the box and turn it on. It has no config options unless the user goes to the advanced UI.
After going to the advanced UI, they’ll be able to configure some settings for the simple UI. However, after going back to the simple UI, it will again not allow changes.
:+1:
One way to do a power-on/hold the button config and reset, is to do it in 2 timeouts:
  • 3 second hold to enter config mode
  • 5 second hold to reset to factory
At 3 seconds, you could blink, say twice, then the user releases to get into config. If they continue to hold for 5 secs, it does the reset.
Now once you get into config, defining how it works to control 21+ settings (add all those being requested), and it gets insane not sure how this could be accomplished with an intuitive UI, accept maybe use the standard UI with the current config settings. A normal power-up sequence would have no config settings.
This might actually work out well, usability wise, and be relatively easy to implement since it uses the current UI for config settings. This is kind-of/sort-of what TK is saying above with the "simple" and "advanced" UI.
TK - I'm not so clear on this. The new voltage reading code, I assume will still be in Vers 2, do you believe it to be good enough to not need individual calibration?
I still have my older Anduril variant with added voltage calib (internal ref only for 1S battery, not voltage divider use for 2S+) and wondering if it's still useful, or are you considering adding it.
It still needs individual calibration. It’s very stable and consistent now, but if the sensor isn’t calibrated right, it’ll be very consistently the wrong value.
So I have a voltage calibration function on the todo list. It’ll probably be a numeric entry menu attached to the battcheck mode.
My apologies if this has been suggested - I haven’t read through the entire thread. I’d like to see an option for the lighted switch to have a battery check option. So rather than a simple, steady blink, the switch will periodically broadcast the battery voltage.
To clarify, this would be under the current aux/switch options.
I’d like a timer mode like candle mode but with just regular brightness, maybe swap it for one of the annoying strobe modes nobody uses or likes, oh and a working muggle mode.
I’d like an Anduril feature that materializes $100 bills in the battery compartment, please. :partying_face:
That isn’t too surprising. The way the button-press handling works now is definitely more efficient in terms of code space.
Thought it was worth suggesting, but it is not worth splitting the UI between lights with older and newer chips.
Thanks!
I’m adding a sunset / auto shutoff timer which works in both the ramp mode and in candle mode.
Trying to decide what the button press should be to activate it. In the old version, it was 3C to add 30 minutes… but 3C is already used in ramp mode, to change the ramp style. However, there is nothing on 4C yet, because I moved the config modes.
So this gives me a few options…
  • Use 4C to activate sunset timer. Also adds 30 minutes. (or maybe just 10 minutes?)
  • Use 4H to activate sunset timer. Adds 10 minutes per second until the user lets go of the button. Blinks each time to make it easier to keep track of.
  • Move “change ramp style” from 3C to 4C, and use 3C to activate sunset timer.
Can’t use 2H because that’s used for ramping down. Can’t use 3H because that does tint ramping. So 4H is the shortest hold action available.
For testing, I have it set to 4H… but I’m not sure if it’s the right choice.
There should be an easy way to adjust beacon brightness. I imagine this is a useful function e.g. when having a car breakdown or worser, an accident. But then is should be easily adjustable by press & hold and double press & hold. Right now I not even have an idea how to adjust it. I’m using manual memory. And the pulses should be shorter. While at it, it should go to the other blinkies-set with memory.
4C / 4H sounds good to me. How will the config modes be activated now?
