Interested
Interested
Interested in 3x 2000K
Interested.
Interested in 5000 or 5700k
Interested in E21A 2000K
as a supplement to my range of Optisolis and E21A in my jetusolis and jetuE21A from clemence in 3000K to 6500K
Here is my attempt a capturing a C01R moonlight beam on a white wall. There is a distinct irregular spot in the center. It may be hard to see on your computer or cell phone. I believe in the C01R thread someone was asking about a defect in the TIR. I think it is just a characteristic of the TIR optic used. I donāt mind too much for the C01R considering the cost and because you typically canāt see it in normal use. However if the same TIR is used for white light I am guessing some of the CRI babies around here will complain about it. Worth considering an upgrade for the E21a model?
Interested in one of each (2000K, 3500K and 4500K) would also prefer 10440 support and sub lumen mode.
Would be great if will include spare lens on the packet of C01S/R ,also with different angle beam
Interested, especially with R9080. Firefly-moonlight-medium-high would be sweet.
Very interested!
Would buy 3-4 or more.
Very interested - have SST-20 on the way, but Iād easily buy another in 4500k (4000-4500k is my sweet spot). A really low firefly/moonlight mode would be nice but is weāre going with a true ābudgetā theme then it should be centered around the emitter without changing too much else up (L to H is a must).
Put me down for 1x 4500k!
Interested. 3500K + 4500K with floody optic.
JĆ¼rgen is right, 2000K is clearly missing!
Edit: SST-20, 2700K; SST-20, 3500K; 219C, 4000K; 219B, 4500K
Fantastic input/feedback, guys!
Your suggestions are in line with the observations of Djozz and Unheard posted on the C01R thread. A microlensed or frosted lens will probably be mandatory for the Nichia E21A emitter to eradicate the tintshift. I will talk to Barry about the proper characteristics and point Sofirn to Clemence's thread to find a suitable optic. If all works out this optic may also become available as a spare part or accessory for using with C01R or C01S with SST-20. Let's keep our fingers crossed. :-)
Pictures below taken from https://budgetlightforum.com/t/-/56117
Interested in 4500K.
Interested in 2000K and 4500K.
Important update:
I have now started with the interest list. Please check the OP and let me know if you see anything to change i.a.w. your requested quantity and tint favor. I will regularly update the list.
Unfortunately, I began too late to ask explicitely for the desired quantity and tint versions. :FACEPALM: So, please excuse if I have put you down for the wrong quantity or tint but I tried to catch the information as best as possible according to your answers. If no quantity or exact tint was expressed I have counted your vote with only one piece and no tint preference. It is very likely that some of you may be interested in more than only one tint. If I have forgotten anybody to include on the list, please let me know so I can update the list. Thanks a lot!
Agro, ch1ir:
I have put you down on list even though you clearly expressed this light is only interesting to you if it works with 10440 cells. For the moment, I cannot tell you if that is going to happen. Please let me know if you want me to change your entries on the list.
Interested in 1 4500k.
