I noticed that Gearbest has some sand colored product but anything other than the two colors, I'd ask Simon about their authenticity.
For a XHP 50.2, It'll handle the heat for a little while at turbo but this having a throwy beam, you don't have to run it at turbo to light up the target really well. Go with a 3 volt emitter.
Simon please do a batch of all copper heatsinks for Z1. If performance is good users will buy so they can further tune the light. If in the future you put white flat or XHP50 in it you will want this as well.
This depends on market demand. Copper has good performance, but the surface is easy to oxidize and blacken.
The white flat LED is worth trying, but I don’t recommend XHP LEDs. The edges of the light spots are yellow-green and the color temperature in the middle is blue.
thank you for your feedback.
Some content is automatically added by the aliexpress system, especially the description of aliexpress on logistics will mislead some buyers, and some buyers will mistake the estimated logistics time as the actual logistics time. Especially with the recent unstable logistics, I became a “liar”.
I have the same. At first I thought I changed it by accident, but it happened all too often and not even after changing the modes but just turning it off and on.
Btw. 10 clicks to enter the configuration is not enough. 20 is the minimum.
Same here, just received this driver.
Haven’t used it too much but noticed this happening when on low voltage warning. Actually, changing modes during LV blinks managed to get it to reset to group one several times in a row. Didn’t happen yet at Voltages over 3.2V.
Annoying if your desired group is high on the list, like 10.
Also, how annoying are the LV blinks! Coming from 7135 12grp driver I was expecting LV dimming rather than blinks.
My understanding is that when another group is chosen (eg. change to Mode 3 or similar), after a certain amount of time, it will go back to Mode 1. I’ll let Funtastic chime in though given he’s one of the ones with the issue.
