Care to share a link where you bought it. 12 mode groups is usually a Biscotti driver. No NMM there that I can remember. Been a while since I bought a S2+ though. Lighted tail switch maybe?
Preventing NMM in reverse clicky lights would require a timer running when the light is switched off. Can be a capacitor discharging, or one keeping a timer alive. Open source firmware is available for this, just takes a µC with a free digital input pin and a capacitor if I understood Lexel correctly. Or a µC whose timer can be kept alive by a capacitor.
That is the linear FET driver (formerly 4 mode driver). I would be surprised if it was designed with next mode memory. Maybe there is something wrong with your light. Ask about it in this thread and post that same AliExpress link.
I have two lights with the Convoy 4-mode CC driver and neither has NMM.
How long are you waiting between turn-off and on? Like most tail-switch lights it takes a few seconds of “off” time before memory is activated vs simply cycling to the next mode.
If it turns out to be a buggy driver and you are in the US I don’t mind sending you another driver. Will save you some shipping time if you are. I don’t have any of the 4 mode only drivers but I do have some 3/5 mode and some Biscotti 4 and 8 chip drivers. All guaranteed to be NMM free.
Adding a lighted tailcap without a bleeder resistor will certainly make it NMM. I found that putting in a 470 ohm resistor makes Biscotti on a Convoy driver behave like its suppose to.
it can be - like other said - that you are not waiting long enough before turning back on
usually 2 seconds is long enough, if it is longer, you may have a malfunction
( these time periods are usually set with a capacitor/resistor pair, if one is the wrong value, this can happen like yours is doing )
try leaving it off for an hour, 2 hours, 4 hours etc, and see if there is a point where it is same-mode and not next-mode
as far as i know next mode is a thing of the past unless in really really cheap lights
convoys should not be doing it
also there may be a pencil lead hack to bleed the cap faster, but i don;t know what it would be for your light
Two examples of lights that had NMM, in a differnt release batch than original:
Thrunite Ti3
at first they had no memory and would always start on low (as long as you waited at least 10 seconds between off and back on)
if switched off and back on after less than 10 seconds, the light advanced a mode, which could be called NMM, sort of
then one day a friend bought a brand spanking new Titanium Ti3, on my recommendation, because I have one too.
He reported the light had NMM, and would not revert to starting on low, even after sitting overnight… total deal breaker… that light was upgraded to driver VN, to get rid of the NMM “feature”
Thrunite confirmed that was true for that batch of Ti3, they all NMM… these were on Amazon… now sold out.
that made me think the problem was a component that was not identical in value to previous drivers…
I did find a post about a pencil mod that may work for that light…
but Im not sure where it is at the moment
the Astrolux A01 followed a similar version change
first it had no NMM, when it used the Manker driver
but when Astrolux cloned their own A01 driver, they got one of the components wrong, and their version of A01 arrived with NMM
of course many people were unhappy with the “feature”
my impression is that the pencil mod makes up for the too long reset timing (hours instead of seconds) of the component that was used in the batch of lights with NMM
not on the two twisties I described, they have zero parasitic drain
I think the pencil mod just allows a capacitor that is holding a charge too long, to discharge faster
I dont think these NMM lights were intentionally built to have that “feature”
imo NMM occured unintentionally due to component changes.
I have never heard of any redeeming quality to the NMM “feature”, and I have never heard of anyone that actually wanted NMM.
My S2+ with Biscotti doesn’t have NMM. They only way I can replicate something similar is if I turn it off and on too quickly, like others have suggested.
I mean the 12 groups 5A/6A linear driver, they don’t run Biscotti unlike the 7135 version but rather a closed source clone of Biscotti, not a port for the new platform (at least that was what Simon told us when Toykeeper said that any Biscotti derivative work would need to be open source as well).
Hey, sorry about that. I thought the thread out a little away from me. But regarding a couple of questions from earlier, I think my Convoy S2+ is buggy. I’ve been trying to use it as a bike light and it would randomly turn off, then turn back on. I’ve actually started taking it apart and investigate replacing the driver. At least, I think it’s the driver that’s the issue.
