Yeah, I did think that, but wasn’t entirely sure. You see my little fatty BC15/P25 has a similar screw and it holds a contact wire on the other side of the shelf - I was a bit cautious this had a similar thing.
However if that screw is doing as you say, it would indeed be safe to remove it - but I’ll ask BG first in the dispute. I don’t want a single reason to arise for them to say I invalidated the warranty, just in case something happens in the future. If they say go for it, I will.
Sorted, screw removed and it’s ok. I know some might think it silly to cause the fuss, but it’s not so much now, as things that may occur in time to come…
Normally, the hole in the shelf is off centre, so a bit of movement can shear off the leads.
But in this case the hole in the shelf and the MCPCB is IN the centre, so no shearing.
But the leads might get twisted.
Twisting of the leads can be limited by pushing down the optics while screwing in the bezel.
It helps if there is an optic AND a glass lens, that will reduce the rotating force on the optic.
Yeah, agreed Henk, but it only needed a slight touch once the screw was out - the wires will be fine, i doubt it will ever be opened again. The sst20 nw is much more pleasant than the xpl hi v6 3d - which I thought were nice, and still do. Just no so nice.
You know thinking about it, it could just as easily be an issue with the led board itself - being cut slightly in the wrong place , I’ll never know.
Either way, it wasn’t ideal. Still, sorted now, smile back on chops
Just starting a photo set to show how it patinas, which I’ll put up at some point - all I need to do is remember to do it every day!
Just checked my FW3A and all three of the ones I have exhibit the same off-center issue between the LED emitter base and the inner diameter of the flashlight's tube as shown in the first post of this thread for the FW3C.I can even see the misalignments with the flashlights assembled as the three LEDs and the optic are slightly closer to one side.
But it does not create any issues with the beam quality on my particular FW3A lights because the three legs on the optic that fit into the three holes on the LED emitter base allow the optic to line up correctly with the LED emitter board because the optic is smaller in diameter and does not touch the flashlight's tube. When I screw the lens back on it seems to hold everything together firmly and keep the parts aligned correctly.
Yeah mate there are a few options, but to be honest it seems to be fine now, I suppose the only worry is the board not sitting flat on the shelf, but it wasn’t an issue in my original one which had no screw. I’ll see how it goes though.
Only been open a few hours and a patina is already starting!
Normally there is enough room in the bezel area for the optic to accommodate when the MCPCB is off center, but it wouldn’t be an issue in the first place if they machined these parts with tighter tolarences.
Well just to update, BG offered me a £12 refund, which I think is fair considering - I’d rather not return the whole light over it and not be able to get another, it would end up costing more.
It seems to ok without the screw, so I will accept.
