SP36 BLF Anduril kit
23th July Code:
Code 1: ML57-5NNHV6-J289AD
Code 2: MLCW-VAFQLM-T5EDAB
Code 3: MLBJ-8KJUBZ-NPSCAP
23th July Code:
7/23/2020 used ML57-5NNHV6-J289AD
Thanks!
Light ordered. Thanks Sofirn
24th July Code:
Code 1: MLNJ-TCBAJ6-T3XGAA
Code 2: ML6R-YUKD52-YF8HA9
Code 3: ML2R-K8V8H3-5S2NAA
SP31V2 kit code
26th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: XSU5-5JWBKU-RJWCAC
Code 2: XS6C-M39NBT-2ZPEAU
Code 3: XSZJ-5ZFAZ5-D8PVAY
Code 4: XSZ2-9MVZEH-XV5ZAY
Code 5: XS7P-YDE9N3-JMUZA3
SP31V2 kit code
27th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: HL6H-LQQFAF-Q32JAL
Code 2: HLVH-K8MPCD-B98YAE
Code 3: HLBU-VQ6P3X-8VX8AS
Code 4: HLQB-8Q85SQ-ZL29AJ
Code 5: HLT2-435PVR-TZ6HAD
I would like to give a thumbs up to the new Sofirn SD05 Diving flashlight. It is very durable. I tried an Efest 3700 mAh 30A high discharge 21700 battery. The power running at medium got hot (Summertime, 81 Fahrenheit on land). The battery tripped but the Sofirn SD05 driver did not skip a beat. With Imalent my experience was quite the opposite. The battery was fine but the flashlight (driver) died. With SOFIRN SD05 the battery tripped but the flashlight is shining as brightly as ever using another 21700 battery! Reliable flashlight! Underwater it will be even better as heat will be less. Sofirn SD05 = excellent diving flashlight for crab spotting.
I also like the Sofirn SP31 v2 tactical flashlight kit very much. I have used it for awhile now and it’s still shining as brightly as ever!
Pleased to hear that you are enjoy your SD05 flashlight.
SP31V2 kit code
29th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: HL74-Z6PQNB-LJZHAP
Code 2: HLWW-MLYRD5-NQFMAM
Code 3: HLVN-YF58UJ-ZFDPAU
Code 4: HLXJ-XBUSSC-NYXJAJ
Code 5: HLMC-829GUD-S44SAG
SP31V2 kit code
30th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: HLME-MKEDPF-VWY6A3
Code 2: HLRH-DT7A3J-R5W9AP
Code 3: HLL4-7K3AL3-J78TAV
Code 4: HLTE-GLTTFA-UKWXA3
Code 5: HL2F-5R54AC-RCWGAC
SP31V2 kit code
31th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: HL66-4XMSL6-BAT2AQ
Code 2: HL6M-UN8QXV-VXJ5A5
Code 3: HLJP-D8QGMA-A2Y9AD
Code 4: HLF8-V4XRAX-8QCUAH
Code 5: HLKH-PR8BGL-AESWAT
3th August SP33V3 Code:
[This is the 30%discount code, please add the 6% coupon together with the discount code and then you will get 36% off, thanks]
Code 1: SSWC-MD5E7E-D77UAU
Code 2: SS2G-PQBPCH-VTWLA6
Code 3: SSBM-ZQGQL5-Z8JBAR
Code 4: SSX3-TALA5Z-AQZGAW
Code 5: SSC7-CX3NN2-JK9YAK
3th August SP40 Green color Code:
[This is the 24% discount code, please add the $2 coupon together with the discount code and then you it with $22.74, thanks]
Code 1: 4PKE-J928PK-CD3UA7
Code 2: 4PUM-6U5BGE-QWHGA3
Code 3: 4P74-U5YPRX-J3PSAM
Code 4: 4PLV-EPYXDN-EHAPAW
Code 5: 4PP3-MVCE97-USFKA2
4th August SP33V3 Code:
Code 1: MR47-2BQPUX-MXV9AJ
Code 2: MRNM-Z5MZPZ-44VWAM
Code 3: MR6D-M2H3AU-YH4LAL
Code 4: MRGD-UH2LS9-EETZAE
Code 5: MR2U-5FCCTB-73KRAC
SP40 Kit Amazon purchase link: SP40 Green color
3th August SP40 Code:
[This is the 25%discount code, please add the $2 coupon together with the discount code and then you it with $22.74, thanks]
Code 1: UGBX-PV84BK-KXLQAT
Code 2: UG58-NGJR3A-FJAAAK
Code 3: UGY8-8NHAK9-YABYAJ
Code 4: UG9H-NYY7BV-2RP8AX
Code 5: UGT6-774D8A-G9BHAA
5th August SP33V3 Code:
Code 1: MR4U-SM6S62-R3TQAM
Code 2: MRQ8-V9BT3V-J8YSA6
Code 3: MRPJ-ZLEA8C-GF3DAZ
Code 4: MR7Y-2MZSH5-68U3AY
Code 5: MRUS-AL5WQR-WF2NAA
5th August SP40 Code:
Code 1: UG6T-SHNWVR-DGAQAU
Code 2: UGZP-84LRVW-8WFRAF
Code 3: UGGN-L4FJKX-ECQ3AC
Code 4: UG6A-TWF9B3-CCPYAY
Code 5: UGDS-SP4PVP-B3ANA9
SP36 BLF Anduril 9th August SP33V3 Code:
[This is the 20%discount code, please add the 10% coupon together with the discount code and then you will get 30% off, thanks]
Code 1: NSSZ-9DN38Z-4TMPA2
Code 2: NS57-BZDXP8-PU4GA3
Code 3: NSCE-5MM87A-5JPTA7
Code 4: NS44-8N8G26-WD92AX
Code 5: NSG2-PNF6YK-7Z4WA9
24th August C8F Code:
[This is the 25%discount code, please add the 10% coupon together with the discount code and then you will get 35% off, thanks]
Code 1: BLKK-6USS5C-5DKVAT
Code 2: BLLY-EXFPRY-BKDJAX
Code 3: BLDE-E4PFKN-DXCPAM
Code 4: BL22-YJLJZQ-WWAVA3
Code 5: BLS7-UG2BHB-AXJWA7
25th August C8F Code:
Code 1: 6RNS-7BZWKV-PJS3A2
Code 2: 6RBM-2G24MR-4H6KAQ
Code 3: 6R9L-RC7TY5-J47BA7
Code 4: 6RJV-HKZ2YX-92GFAX
Code 5: 6RPD-JY3ZC6-CYXKAF
26th August C8F Code:
Code 1: 6RSR-HU3F24-64VQAF
Code 2: 6RHB-U5ZMB5-2HKKAH
Code 3: 6R23-XDNV5P-EPJEAS
Code 4: 6RBP-EEWPA3-6GNPAU
Code 5: 6R7T-AVAKMM-VAT8AR
28th August C8F Code:
Code 1: 6RAV-AW7RPK-4PN2A4
Code 2: 6RW9-36FE6T-QUWLAS
Code 3: 6R93-PQUANP-XNCCA3
Code 4: 6RT7-V9XHN6-74WAAY
Code 5: 6R7F-RYS5XG-CREBAD
