The more I’ve thought about this over the last few weeks, the more I’ve realised I would buy a couple.
I live the Tool AA 2.0, but I love my fw3a and Fw1a lights much more.
While I like a smaller single led light, the driver, both button, firmware and power just can’t be beaten from the FWxA lights.
I’ve collected so many of them now, all for different LEDs, tube sizes, I would love one that’s 4mm thinner.
My favourite size is 18500, so the height would be similar and amazing for a 219b mod for around the house.
There really wouldn’t be much point in making it a triple.
A single LED is almost always preferable unless there are specific reasons to use more. Like, if one LED can only make 1000 lumens and you want to make 3000 or 4000, and don’t mind sacrificing throw, and are using a battery powerful enough to power it, that would be a reason to use more than one. Or if it’s a lantern which needs light to come out at all angles, or if it uses tint ramping, those would be reasons to use more than one.
But for a 14500 light, the battery isn’t really strong enough to justify multiple LEDs. Also, if the whole point of the light is to make it small, multiple LEDs would work against that goal.
It can sometimes be useful to put four tiny LEDs under a single optic though… like four XQ-E or E17A LEDs. This allows tint mixing to make the tint more pink. Or in the case of 4 x XQ-E, it has been used with RGBA emitters and a diffuser to produce a rainbow.
Those are pretty specialized cases though. For a general-purpose 14500 light, a single LED is the obvious choice.
(FWIW, I’m counting the Cree XHP series as a “single LED”… there are good reasons to use XHP35 HI and a boost driver, for example)
Same. 14500 is already a compromise because I only really use that battery size for EDC or if I’m travelling. I’d want to be able to bung an easy to find AA in it if I took it on holiday or whatever.
But yes indeed, I’d be interested to see it, though the short tube 18350 option for the FW3 further weakens my need for a 14500 version. Still, needs are generally ignored in the world of the flashaholic, and desire is forefront.
I asked because there isn’t any triple 14500 on market.So will be the first. Small leds like E17A can handle not much current.
New 14500 batt.can give the necessary current but of course runtime and throw will be a bit sacrified.
That driver is designed specifically for the Boruit D10 (probably works with most of the varieties of that light too, like Sofirn/77Outdoors D25), which takes an 18650.
So far, Anduril works with several ATTiny MCUs, which we’ve made work with Li-Ion chemistries. Cell size doesn’t really matter at that point, just design a smaller driver to fit the host. There’s not a whole lot of reason Anduril can’t fit on a 10mm driver besides space, which would allow for 10440 and even 10180 lights to run Anduril.
This thread has some information about the quest for AA Anduril support. To my understanding, there’s a prototype driver design being tested currently.
Yes, but I’m still waiting on a good 14/15mm 12v boost driver.
All the triple optics I’m aware of have a much larger diameter than makes any sense for a 14500 light.
But triple is more efficient than single and with the Vapcell H10 or Shockli 1000mah cells, it will be able to make use of triple emitters no problem. But I’m hoping for a 14500 version of the Manker MC13
Triples and quads have been great these past few years, but I miss single-emitter lights designed to be as small as possible. They generally had the most practical beams and were the easiest to carry. Extra lumens are neat, but on something small I carry around all the time I don’t really need more than ~100 lm or so.
So for a 14500 light I’d be pretty happy with a really thin light with a single E21A and a 500 mA buck driver or linear driver. Even just a single 7135 chip and a MCU would suffice.
But I probably wouldn’t buy a 14500 triple. It’d be wide enough that I may as well just use an 18650 light instead… and floody enough that I’d need to use twice as much light to see what it’s pointing at.
This is why multiple emitters are used instead of one, to increase
efficiency at high currents.
Problem the head size of 14500 host for put a triple, Don’t know if there are lens/mcpcb smaller than 20mm
If you use this lens size and also need to increase head diameter,yes there is no reason for do that.
I just launch idea
Efficiency, as measured in lumens per Watt, is usually higher with more LEDs. Like, at a given power level it may produce 5% more lumens or 10% or even 50%… and the greatest gains happen at the highest power levels. At low power, there’s very little difference.
Efficiency, as measured in candelas per Watt, is usually higher with just one LED. That is, assuming the overall diameter of the host remains the same. Take the FW3A vs FW1A as an example. The single-emitter version is about 500% as efficient, illuminating its target about 5X as bright at the same power level.
So you’re both right… you’re just talking about different things.
In the case of a 14500 version of the FW3A or FW1A, the topic of efficiency boils down to this: At a given power level, would you rather have a ~10% increase in lumens or a ~500% increase in candelas?
Basically, do you want an extreme flooder at ~2 cd/lm or a balanced beam at ~10 cd/lm?
Great explain ToyKeeper thanks.
Anyway yes I’m interested on mini FW1A if will be relase with AA compatibily, High CRI very warm option,small size and price.
Also an Headlamp version with these specs and ramping ui would be great…
