I communicated with the driver manufacturer and there is no problem with the code. In order to avoid difficulty in entering the mode selection, the response time for 10 clicks of the button is not very short. The user is constantly clicking the button, and originally just want to switch the mode, it may accidentally enter the mode selection. When clicking the 11th time, it will automatically Back to group 1.
There are two ways to solve this problem. The first is to shorten the response time, and the second is to increase the number of button clicks. At present, I don’t want to use the first method, because some users’ finger flexibility is not so high. I want to increase the number of clicks to 15,
I’m not only one that think 20 is ok. It’s a safe solution, and entering the settings, even for someone unfamiliar with flashlights, takes 3 seconds, maybe less.
There are 8 modes in the first group. It is enough to do two cycles to enter the settings. For example, when you start from the first mode and want to check the battery level and accidentally jump back to the first mode because you did it too quickly. And again you make 7 clicks, but then instead of checking the battery status you enter the settings.
This is an extreme example, but it shows what’s going on.
And as I mentioned before. In normal use, you don’t change the group every hour to make it annoying.
Here is the problem: the response time or click/tap delay time for config mode is too long. This is obvious. I can tap a flashlight button 4 times per second without difficulty, and I am pretty sure any minimally trained or blessed human being can do it a minimum of 3 times per second.
As a first solution, click/tap delay time for config mode should not be set any slower than for any other click/tap sequence. This alone can be enough to fix the whole problem. However, if an increase in the lenght of the sequence of clicks/taps is considered, why does the number of clicks or taps needs to be a rounded figure or sort of? It doesn't needs to. Just increase it slightly. Set it at 12, 13, 16, whatever! This is no ramdom stuff! All is precisely pre-defined and once the user knows how to and is dexterous carrying out a procedure, he will just do it.
I agree, I feel like the config mode should be simple enough for anyone to use. Whether they have fast fingers of a piano player or their fingers are slow and half frozen. Not everyone can click with a rythm and timing.
Is the config menu absolutely necessary?
Maybe we could make a lot of people happy with a simple step ramping or smooth ramping.
1 Click to Turn flashlight off, Click to turn on
2 To turn ‘memory on’ , just simple full click+hold. Ramp up and down to a level you want.Then let go to memorize the level.
3 To turn memory off using tailcap just Click and Hold +Unscrew and screw back tail cap while holding the switch.
Would this solve any issues people accidentally getting into config ?
The CSLNM1.TG is rated for max 3000mA and djozz found that 6000mA is actually in the decreasing region, unlike the CSLPM1.TG, so I think the S21A with KW CSLNM1.TG and 6000mA max current doesn’t make too much sense unless there is a typo (maybe with 5000mA it would be ok).
