I would like to give a thumbs up to the new Sofirn SD05 Diving flashlight. It is very durable. I tried an Efest 3700 mAh 30A high discharge 21700 battery. The power running at medium got hot (Summertime, 81 Fahrenheit on land). The battery tripped but the Sofirn SD05 driver did not skip a beat. With Imalent my experience was quite the opposite. The battery was fine but the flashlight (driver) died. With SOFIRN SD05 the battery tripped but the flashlight is shining as brightly as ever using another 21700 battery! Reliable flashlight! Underwater it will be even better as heat will be less. Sofirn SD05 = excellent diving flashlight for crab spotting.
I also like the Sofirn SP31 v2 tactical flashlight kit very much. I have used it for awhile now and it’s still shining as brightly as ever!
Pleased to hear that you are enjoy your SD05 flashlight.
SP31V2 kit code
29th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: HL74-Z6PQNB-LJZHAP
Code 2: HLWW-MLYRD5-NQFMAM
Code 3: HLVN-YF58UJ-ZFDPAU
Code 4: HLXJ-XBUSSC-NYXJAJ
Code 5: HLMC-829GUD-S44SAG
SP31V2 kit code
30th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: HLME-MKEDPF-VWY6A3
Code 2: HLRH-DT7A3J-R5W9AP
Code 3: HLL4-7K3AL3-J78TAV
Code 4: HLTE-GLTTFA-UKWXA3
Code 5: HL2F-5R54AC-RCWGAC
SP31V2 kit code
31th July Code: [Please add the 10% coupon together with the discount code, and then you will get 40% off]
Code 1: HL66-4XMSL6-BAT2AQ
Code 2: HL6M-UN8QXV-VXJ5A5
Code 3: HLJP-D8QGMA-A2Y9AD
Code 4: HLF8-V4XRAX-8QCUAH
Code 5: HLKH-PR8BGL-AESWAT
3th August SP33V3 Code:
[This is the 30%discount code, please add the 6% coupon together with the discount code and then you will get 36% off, thanks]
Code 1: SSWC-MD5E7E-D77UAU
Code 2: SS2G-PQBPCH-VTWLA6
Code 3: SSBM-ZQGQL5-Z8JBAR
Code 4: SSX3-TALA5Z-AQZGAW
Code 5: SSC7-CX3NN2-JK9YAK
3th August SP40 Green color Code:
[This is the 24% discount code, please add the $2 coupon together with the discount code and then you it with $22.74, thanks]
Code 1: 4PKE-J928PK-CD3UA7
Code 2: 4PUM-6U5BGE-QWHGA3
Code 3: 4P74-U5YPRX-J3PSAM
Code 4: 4PLV-EPYXDN-EHAPAW
Code 5: 4PP3-MVCE97-USFKA2
4th August SP33V3 Code:
Code 1: MR47-2BQPUX-MXV9AJ
Code 2: MRNM-Z5MZPZ-44VWAM
Code 3: MR6D-M2H3AU-YH4LAL
Code 4: MRGD-UH2LS9-EETZAE
Code 5: MR2U-5FCCTB-73KRAC
SP40 Kit Amazon purchase link: SP40 Green color
3th August SP40 Code:
[This is the 25%discount code, please add the $2 coupon together with the discount code and then you it with $22.74, thanks]
Code 1: UGBX-PV84BK-KXLQAT
Code 2: UG58-NGJR3A-FJAAAK
Code 3: UGY8-8NHAK9-YABYAJ
Code 4: UG9H-NYY7BV-2RP8AX
Code 5: UGT6-774D8A-G9BHAA
5th August SP33V3 Code:
Code 1: MR4U-SM6S62-R3TQAM
Code 2: MRQ8-V9BT3V-J8YSA6
Code 3: MRPJ-ZLEA8C-GF3DAZ
Code 4: MR7Y-2MZSH5-68U3AY
Code 5: MRUS-AL5WQR-WF2NAA
5th August SP40 Code:
Code 1: UG6T-SHNWVR-DGAQAU
Code 2: UGZP-84LRVW-8WFRAF
Code 3: UGGN-L4FJKX-ECQ3AC
Code 4: UG6A-TWF9B3-CCPYAY
Code 5: UGDS-SP4PVP-B3ANA9
SP36 BLF Anduril 9th August SP33V3 Code:
[This is the 20%discount code, please add the 10% coupon together with the discount code and then you will get 30% off, thanks]
Code 1: NSSZ-9DN38Z-4TMPA2
Code 2: NS57-BZDXP8-PU4GA3
Code 3: NSCE-5MM87A-5JPTA7
Code 4: NS44-8N8G26-WD92AX
Code 5: NSG2-PNF6YK-7Z4WA9
24th August C8F Code:
[This is the 25%discount code, please add the 10% coupon together with the discount code and then you will get 35% off, thanks]
Code 1: BLKK-6USS5C-5DKVAT
Code 2: BLLY-EXFPRY-BKDJAX
Code 3: BLDE-E4PFKN-DXCPAM
Code 4: BL22-YJLJZQ-WWAVA3
Code 5: BLS7-UG2BHB-AXJWA7
25th August C8F Code:
Code 1: 6RNS-7BZWKV-PJS3A2
Code 2: 6RBM-2G24MR-4H6KAQ
Code 3: 6R9L-RC7TY5-J47BA7
Code 4: 6RJV-HKZ2YX-92GFAX
Code 5: 6RPD-JY3ZC6-CYXKAF
26th August C8F Code:
Code 1: 6RSR-HU3F24-64VQAF
Code 2: 6RHB-U5ZMB5-2HKKAH
Code 3: 6R23-XDNV5P-EPJEAS
Code 4: 6RBP-EEWPA3-6GNPAU
Code 5: 6R7T-AVAKMM-VAT8AR
28th August C8F Code:
Code 1: 6RAV-AW7RPK-4PN2A4
Code 2: 6RW9-36FE6T-QUWLAS
Code 3: 6R93-PQUANP-XNCCA3
Code 4: 6RT7-V9XHN6-74WAAY
Code 5: 6R7F-RYS5XG-CREBAD
31th August SP33V3 KIT Code:
Code 1: WUVU-RWFLQB-35N3AF
Code 2: WU2M-PFG886-M2J9AF
Code 3: WUNM-C9Y39A-T66VAL
Code 4: WUVL-UENV53-QW4QA2
Code 5: WUKY-GP9P9G-DVLJA3
1th September SP33V3 KIT Code:
Code 1: WUHM-LKJALM-PU6GAS
Code 2: WUYP-UCAW27-3ZGAAH
Code 3: WUF9-YWQAFV-MJVGAU
Code 4: WUD8-6VUPDQ-KKCBAL
Code 5: WUPX-75KPXS-864YA7
3th September SP33V3 KIT Code:
Code 1: WUKV-5BDGLP-HPL6AM
Code 2: WU24-4ZEBKN-BEPZAM
Code 3: WUCZ-42XK6P-YTFNAL
Code 4: WUCY-MF9VLX-PQ8ZAW
Code 5: WUDX-NDGX2H-X25BAY
Used code #1 for 9/3. Thanks.
7th September C8F KIT Code:
Code 1: 6RWN-9YVZ5G-QAGDAS
Code 2: 6RVY-DH699U-C2ZZAM
Code 3: 6RXY-GSYCNT-Y6KAAS
Code 4: 6RTD-GQHY3Z-DVMAAD
Code 5: 6RXC-S3RBAB-Z4HCAA
8th September C8F KIT Code:
Code 1: 6RLJ-2N8DGZ-NTWHAM
Code 2: 6RL5-BB79CC-RZBHAS
Code 3: 6R2W-3CE82M-SRRUAE
Code 4: 6RY6-3DRTAC-3987AE
Code 5: 6R4R-EHJFWD-DKP5AJ
