The BLF software breaks the link up like it does above.
It breaks the link at one of the â-â
When it should be:
âHyperText-Blah-Blah://WorldWideWeb/bhphotovideo.com/c/product/1428272-REG/yongnuo_yn560li_kit_yn560li_lithium_power_speedlite.htmlâ
Is there a way to get around this?
Thanks,
All the Best,
Jeff
I advice to switch to the Advanced Post Editor. The Advanced Post Editor can do everything the Simple does, and additionally it doesn't chokes with links using non-ASCII characters (which are common nowadays).
It is wise to know how to use, how to handle reality. Letting something do for you what you should (at least) know how to deal with honestly and truly isn't.
I've suggested sb56637 to leave only the Advanced Post Editor (and Plain Text) in the forum, that would be of benefit as quoting messages from people which uses the other editor obliges to edit the text (the emojis work anyway in the Advanced Editor). Would you vote favorably for this in a poll? I think he sort of fears this but there's no real reason, in a couple days everyone would be adapted to.
Getting rid of the simple post editor might make the screen harder to use for those who work from phones or other limited viewing area devices.
I say keep it.
The BBcode with easy markup language of the simple post editor is 2 decades old and pretty easy to use when you figured it up, there is nothing I wasnât able to do with the simple post editorâŚkeep it.
SPE and the icons for insert link, image, video, etc., work for most things and most non tech people. I like it the way it is; use advanced PE if you want or need, or not.
And I donât like url shorteners either. I always wonder what theyâre hiding.
