[UPDATED M4D deal] Manker “EDC Muscle Combo – BLF Limited”
MC13 pictures:
Product Description
Features
- LED Option1: OSRAM KW CULNM1.TG LED (white light)
Max. 950 lumens output, Max. 760meters beam distance
- LED Option2: OSRAM KP CSLNM1.F1 LED (green light)
Max. 1200 lumens output, Max. 858meters beam distance
- LED Option3: OSRAM KR CSLNM1.23 LED (red light)
Max. 260 lumens output, Max. 450meters beam distance
- LED Option4: OSRAM KY CSLNM1.FY LED (Yellow light)
Max. 350 lumens output, Max. 506meters beam distance
- LED Option5: OSRAM KB CSLNM1.14 LED (blue light)
Max. 115 lumens output, Max. 640meters beam distance
- Powered by 1x 3.7V 1100mAh high drain protected 18350 li-ion battery with Type-C USB port (Included)
- Working Voltage: 2.8-4.3V
- Driver: Most efficiency constant current circuit (Non-PWM)
- With advanced intelligent temperature regulation module,MC13 regulates its output and adapts to the ambient environment,maintaining optimal performance
- Anti-reverse battery protection & overdischarge protection
- Pocket Size, Compact, lightweight
- One-handed, one-button for easy and fast operation
- Lockout mode prevents accidental activation
- Moonlight Mode: Multiple user selectable levels
- Low battery voltage indicated & battery charging indicated
- Material: aircraft-grade aluminum body
stainless steel button cap
- Surface Treatment: Premium type-III hard-anodized anti-abrasive finish
- Clip: Stainless steel deep carry clip
- Lens: Toughened ultra-clear glass lens with anti-reflective coating + high temperature resistant optics TIR Lens
- Tail stand capability
- IPX-8 waterproof standard (2 meters under water)
- Impact resistance: 1 meters
- Size: 90.75mm(3.57") length x 41.7mm(1.64") head dia. x 25.8mm(1.01") body dia.
- Weight: 108.6g(3.83 oz) w/o battery, 136.7g(4.82 oz) w/ battery
- Accessory: 18350 li-ion battery x1, type-C USB charging cable x1, lanyard x1, spare o-ring x1, Manual x1
Output/runtime (White light)
Moonlight: 0.5 lumens 82 hours
Low 120 lumens 4 hours 05 minutes
Middle 240 lumens 1 hours 47 minutes
High 450 lumens 45 minutes
Turbo 950 lumens 35 minutes
Strobe 950 lumens -
Peak beam intensity: 144,000 cd
Maximum beam distance: 760 meters
Waterproof standard: IPX-8,2M
Output/runtime (Green light)
Low 45 lumens 11 hours
Middle 190 lumens 3 hours 11 minutes
High 520 lumens 53 minutes
Turbo 1200 lumens 47 minutes
Strobe 1200 lumens -
Peak beam intensity: 184,041 cd
Maximum beam distance: 868 meters
Output/runtime (Red light)
Low 60 lumens 25 hours
Middle 90 lumens 2 hours 03 minutes
High 152 lumens 57 minutes
Turbo 260 lumens 53 minutes
Strobe 260 lumens -
Peak beam intensity: 50,625 cd
Maximum beam distance: 450 meters
Output/runtime (Yellow light)
Low 50 lumens 14 hours
Middle 120 lumens 3 hours
High 240 lumens 57 minutes
Turbo 350 lumens 54 minutes
Strobe 350 lumens -
Peak beam intensity: 6,000 cd
Maximum beam distance: 155 meters
Output/runtime (Blue light)
Low 10 lumens 11 hours 30 minutes
Middle 23 lumens 2 hours 35 minutes
High 50 lumens 57 minutes
Turbo 115 lumens 50 minutes
Strobe 115 lumens -
Peak beam intensity: 102,400 cd
Maximum beam distance: 640 meters
E14 III
Product Description
Features
- Emitter: 4x Samsung LH351D (Cool White: 6500K, Neutral White: 4000K CRI>90)
- Maximum output: 4,000 lumens
- Maximum beam intensity: 6,000cd
- Maximum beam distance: 155meters
- With advanced intelligent temperature regulation module, E14 III regulates its output and adapts to the ambient environment, maintaining optimal performance
copper heat sink
- Lens: Toughened ultra-clear glass lens with anti-reflective coating + high temperature resistant Carclo® optics TIR lens
- Install one removable silica gel light filter plastic sheet (green glow gadget)
- Size: 71.2mm(2.8") length x 28mm(1.1") head dia. x 25.8mm(1.01") body dia.
- Weight: 82.8g(2.92oz) w/o battery,109g(3.84oz) w/ battery
- Accessory: 18350 li-ion battery x1, type-C USB charging cable x1,spare o-ring x1, lanyard x1, Manual x1
Output/runtime
Moonlight: 0.5 lumens 82hours
Low: 180 lumens 4hours 39minutes
Middle: 400 lumens 1hour 34minutes
High: 1000 lumens 1hour 15minutes
Turbo: 4000 lumens 55minutes
Strobe: 4000 lumens -
Done. Thank you Max & Manker. This deal finally happened. :+1:
Thanks, signed up
Awesome. Been waiting for this! Both look like fantastic lights!
Edit: I just realized the MC13 uses the CULNM1.TG Oslon Boost HL!!! It’s the first stock flashlight to use this emitter!
At last! Signed and ready for payment
i signed up as well!
Just curious, what’s the difference of the CULNM1.TG with other Osram/Oslon LEDs (eg. compared to the Osram NM1 or PM1)?
Signed up, but for the batteries would it be possible to buy just the 18350?
Seems like a good deal, congrats
Nice … signed up … :slight_smile:
Wow, interesting. I didn’t expect to ever see another Manker group buy on BLF. Maybe it means the issues of the past are finally healing? That would be cool.
I’m a little confused about something though. Why is there a BLF logo on the lights if BLF wasn’t involved in designing them? Is there something different about these?
Will Manker sell this BLF combo also at their Aliexpress store?
Precisely my question!!
What is the BLF on this sale?
Is it a way for Manker to be more BLF friendly?
Or was someone from BLF involved in the design of these lights?
It looks like BLF is only on the versions in this “combo” deal and not on the individual lights for sale. So maybe it’s intended to be just a special “BLF group buy” edition and that’s why? It doesn’t appear they are tying to claim the lights themselves are BLF designs since it’s just on the group buy images. I could be wrong, of course. It certainly would not be ok with me if they just threw BLF on there as a sales tactic on all the lights.
This is NO BLF Special Edition flashlight ...
I really want an E14iii but also want to see a review first.
That clears things up, however being the CULPM1 I suppose it could be driven harder than 950lm?
Another bump...
Need this package!
