I’m pretty sure it throws farther than 92.5 millimeters.
(that’s the length of the light)
Anyway, the FW3A XP-L HI gets about 4.4 cd/lm, and the FW1A XP-L HI gets about 23 cd/lm. Roughly 5X as many candelas at the same power level.
However, the FW3A can make about 2.3 or 2.5 times as many lumens. So on turbo, the difference in candelas is a factor of 2 (ish) instead of a factor of 5. But it uses like three times as much power to get half as many candelas.
There’s no question that throwy lights are more efficient at producing a bright hotspot. That’s the whole point of a thrower.
For me though, it’s not about efficiency… it’s about having the right balance. And I think the optimal balance for a small EDC-style light is roughly 5 to 15 cd/lm. This provides a useful mix of flood and throw for common daily tasks.
A 14500 compact triple would end up with like… 2 cd/lm. And a single-emitter version would be closer to 10 or 12 cd/lm. So I’ll take the single-emitter version.
If it were the other way around though, like if we were using a really tiny LED which produced a ridiculous amount of throw, and the numbers were 10 cd/lm for a triple or 50 cd/lm for a single, I’d choose the triple. Because it hits the balance I’m looking for.
Seems to me it should get closer to 25mm shorter. The depth of the reflector would be shorter. Although the ability to take a button top might be better. And the inner sleeve should not be carried over so,?
I just realized FW1A is by lumintop and they already have the GT Micro for those who like single emitters with high throw efficiency. I guess this one would make sense for a triple. It would be the first 14500 triple on the market.
It is no longer sold, but this is/was a 14500 on the market!
And made by a BLF member: vestureofblood (also know as Matt Smith from AdventureSportFlashlights )
I disagree that there’s no point in making a triple. Some people use their lights in doors and prefer floody lights. Also there are SO MANY single emitter 14500 out there including Lumintop’s own GT Micro, Tool AA, E05C, ED15, L1A, EDC05, Duke, Prince Mini, D10; I don’t see much reason to make another single emitter 14500 to compete with their already huge selection. A triple on the other hand would be unique. For me, I would be more interested to see a 4x or 9x E21A mule. I love the 16x E21A mule in the KR4 so much.
Yes the question was fw1a. A 3/4 size (in all dimensions) with 200m of throw. Warm and high Cri for indoor use. But still able to reach out and touch something way out outside. The GT micro is larger in all dimensions. I don’t want to go over 27 mm head for horizontal pouch belt carry. Or pocket.
Yes, there are several 14500 throwers, like the GT Micro. But this isn’t about making throwers. The point is to make something small.
If anything, I’d argue that lights like the GT Micro and BLF X5 don’t really make sense. The head is so big, it’s a bit silly to use such a small cell. The X5 really should have used 18650, 18500, and 18350 cells instead of 14500. But it didn’t, so it basically got obsoleted as soon as the Emisar D1 came out. The X5 was cute to look at, but the D1 was far more practical.
That’s really cool… a work of art, even.
On the other hand, it’s not small. As emarkd put it, “Its a handful, not really a small light and definitely not lightweight”.
If his picture shows the dimensions accurately, it appears to be about 105 mm long and 24.5 mm in diameter… but I have an 18650 triple which is smaller than that. My brass 18650 triple is 102.5 mm x 21.9 mm.
My favorite AA-sized lights, however, are about 17 mm wide and 80 mm long. So I’d ideally keep 14500 lights around that size.
“A reasonable EDC light, not minmaxing for some attribute” is… not the BLF default, I think.
It’s my default though. I have more impressive lights, but it’s the Zebralight SC64c LE that makes it into my pocket most days. A 14500-powered, tail-e-switch light running Anduril and taking a similar approach to performance tradeoffs as the Zebralight would also get a lot of pocket time from me.
Yeah. It’s not exciting, but it’s incredibly useful.
If I understand correctly, it’s also basically the reason why Hank has two brands. Emisar is for minmaxed lights which produce as much light as possible even if it might not entirely make sense. Noctigon is for more reasonable designs which are meant for steady, sustained output. Direct drive vs regulated.
So I think Noctigon would be a good option for a small EDC-oriented light.
Personally, I’d love to see a few designs…
14500 tail e-switch with one LED, designed to be as small as possible. Would ideally have a version with a high-CRI neutral LED, and a driver regulated to … maybe 2A? Deep-carry one-way clip at the tail.
18650/18350 light with side e-switch and one LED, designed to be as small as possible… similar to the Olight S-Mini. Regulated driver limited to ~3A or ~5A, with a lower channel added for good moon/low modes. Beam profile of about 10 cd/lm. Deep-carry one-way clip at the head, styled like the older Olight clips. Mild texture; no aggressive knurling.
A D4 or KR4 with tint mixing from 2700K to 6500K, or maybe 3000K to 5700K. Two regulated power channels limited to 3A each. LED choices of E21A, XP-L HI, or SST-20.
So, basically two small EDC lights (14500 tail switch and 18*50 side switch) and a quad with tint mixing.
Not sure what they’d be called, but maybe something like… Noctigon E41, E31/E61, and TM4? (E = EDC, TM = Tint Mixing, 3/4/6 = 18350, 14500, 18650, 1/4 = number of LEDs)
