Windows 8.1 & AMD Graphics
12 posts / 0 new
old4570
Last seen: 3 days 21 hours ago
Apparently AMD stopped supporting Windows 8.1 some time ago .. ( Years )
And if you run Win 8.1 and are silly enough to buy a Radeon card , you kind of shafted yourself ( Or so I thought )
After some research : I tried the Windows 7 drivers people recommend and = FAIL .. No the card runs , but try doing benchmarks ( 3D Mark ) So next I had to try the Windows 10 drivers and VIOLA !
Download Win 10 drivers , then install . ( Software is unpacked to C: drive in the AMD folder )
The install will fail but the unpacked files are there .
I have run 3D Mark 11 and Fire Strike , so I guess the drivers are doing whats needed .
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: old4570 on 07/31/2020 - 20:36
Th558
Th558's picture
Last seen: 2 hours 55 min ago
I have an M4A88TD-M EVO motherboard with on-board graphics running Windows 10 and the resolution won’t go above a certain point. The original drivers don’t work. I can fix it temporarily but it reverts back after updating or something.
Souichirou
Souichirou's picture
Last seen: 12 hours 57 min ago
Heads up you can install windows 10 for free still.
old4570
Better check that , cos I did .. No longer free !
I did get Win 10 free , but I dont think it’s legit any more as I reverted to 8.1 .. A long time ago .. Cut of date was ( The Windows 10 free upgrade through the Get Windows 10 (GWX) app ended on July 29, 2016. ) I dont know if my copy of 10 is still valid and functioning ? All upgrades must have completed and reached the “Welcome” screen by 11:59 PM UTC-10 (Hawaii) on July 29, 2016; this is one worldwide point in time
SIGShooter
SIGShooter's picture
Last seen: 1 hour 34 min ago
old4570 wrote:
Better check that , cos I did .. No longer free ! I did get Win 10 free , but I dont think it’s legit any more as I reverted to 8.1 .. A long time ago .. Cut of date was ( The Windows 10 free upgrade through the Get Windows 10 (GWX) app ended on July 29, 2016. ) I dont know if my copy of 10 is still valid and functioning ? All upgrades must have completed and reached the “Welcome” screen by 11:59 PM UTC-10 (Hawaii) on July 29, 2016; this is one worldwide point in time
I was able to migrate a Win7 instance to Win10 this January so I suspect it’s still doable. This link indicates it’s still possible to do so.
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
ChiggerPepi
ChiggerPepi's picture
Last seen: 17 hours 48 min ago
Win 10 is still free. It’s not advertised as such, but it is. Use your Win 8.1 key to “register” your Win 10 install. It will work.
ChiggerPepi
Also, you should get off any old versions of Windows, they are unsupported and any discovered exploits are no longer patched. Your computer is substantially more vulnerable to nefarious individuals.
bushmaster
bushmaster's picture
Last seen: 44 min 46 sec ago
I’ve upgraded several Windows 7 and one Windows 8.1 machines to Windows 10 in the past year. Go to the “media creation tool” and just follow the yellow brick road. Now of course somebody is going to come aboard this forum and tell you that its an illegitimate download and not a legal copy. Maybe so but I can’t help but wonder why Microsoft left this door wide open and thousands of people have taken advantage. It upgrades just fine every month…….or at least as well as any Windows 10 machine updates. Ya know…with Windows Update, you have to cross your fingers.
Keep your nose in the wind and your eyes along the skyline.
Del Gue
Souichirou
Wrong on both counts sorry, the “FREE” windows 10 campaign that ended in 2016 was originally for “ALL” versions of windows regardless of its legitimacy so people even with “Pirated” copies could upgrade to full windows for free just to get everyone on the ecosystem and give them a legitimate windows key.
Currently as long as you HAVE a legitimate activated copy of windows you can either use that “KEY” to do a fresh install OR upgrade to windows 10 on the current system for FREE as the key is still registered as activated.
Thanks for playing.
old4570
Interesting … Thanks , but I like Win 8.1 , and when it’s done and dusted I will most likely migrate to Linux .
I try different flavours from time to time VIA Virtual Box .
My favourite flavour at the moment is Mint .
And then I might VB Windows .
I Virtual Box 95 – 98 – ME and XP at the moment just for some retro fun
jeff51
jeff51's picture
Last seen: 5 hours 42 min ago
I’ve done several Win7 and one Win8 to Win10 upgrades this year.
As long as the Win7 is a legit install, it works.
I like to do the upgrade. That is run the install from inside the current OS.
After that is finished, and I check to see that W10 is activated.
This saves having to mess with entering the PID number, which may not be available depending on how the original OS was installed.
From then on the MS servers will recognize that hardware, and will allow activation each time W10 is installed on that machine. You don’t need to re-enter the PID number again. Just skip that part during the install.
I then wipe the drive and do a fresh W10 install to get rid of years worth all the junk.
I’m a fan of Mint also.
All the Best,
Jeff
puglife2
puglife2's picture
Last seen: 3 hours 23 min ago
Kubuntu > Mint
