Another important thing to mention, the lighted tailcap (only works with 14500) has a high parasitic drain of 8,5 mA
It will eventually drain your cell (i removed the LED’s in the lighted tail)
Mathematically speaking that’s only about 100 hours using a 850mah cell.
A little over 4 days and the battery is dead. Is that about what everyone experienced?
I changed my current limiting resisitors to a higher value right after I received, so I dont know how it was factory.
When the light is turned on the driver is running with the firmware, checking for LVP. When you turn it off, the driver is off (switch breaks connection) and not checking a thing. The lighted tail switch is working in backwards polarity compared to the driver. No power to driver, lighted tailcap power is on and no LVP. The lighted tailcap will drain your battery dry while the driver is sleeping .
