Lumintop Tool AA 2.0 flashlight
40 posts / 0 new
tedh35
Last seen: 1 week 4 days ago
What is the best 14500 battery for this light? Thanks very much.
VK-GX
Last seen: 3 days 2 hours ago
I use olight 14500 750mAh myself. But I would like to try the keep power 1000mAh.
moderator007
moderator007's picture
Last seen: 2 hours 11 min ago
Vapcell ICR14500. http://budgetlightforum.com/node/64318
The Efest purple 650mah might produce a few more lumens with less run time.
But the Keeppower or Vapcell 1000mah will give you the longest run time with good out put.
gchart
gchart's picture
Last seen: 22 min 29 sec ago
Shockli also has a very nice 14500 available that would work well
moderator007
Shockli, Keeppower, and Vapcell 14500 1000mah in HKJ’s discharge graph, all look like they’re rolling out of the same factory. Their curves are so similar with small differences maybe being changes in production over time. Any of the 3 would be a good choice.
gchart
gchart's picture
007, shootin’ em straight!
Some of these are so similar, likely the same cells. Sometimes it just comes down to what you can acquire (and at the right price). Any of these three and you’re GTG
Sillen
Sillen's picture
Last seen: 2 days 19 hours ago
I use a variety:
Sofirn Black 900mAh
Vapcell Blue 650mAh
Panasonic Red 800mAh
Vapcell Gold 1000mAh (doh! got six of these but they are flat top so only work in 1 torch)
Keeppower Protected 1000mAh
Got Vapcell Blue for high drain in Lumintop Micro
Any of the above good for Tool AA
Schimtty
Last seen: 3 months 3 days ago
If memory serves, Shockli slightly edged out the 14500 1000mah competition. But as you say, any would be well suited for the task.
nobody
Last seen: 5 hours 16 min ago
Should they be protected battery?
Rat_Racer
Rat_Racer's picture
Last seen: 1 hour 28 min ago
Depends on use, but shouldn’t be necessary. Most new lights have LVP built in, and aren’t typically pulling high amps.
Bearbreeder
Last seen: 7 months 2 weeks ago
That light has no lvp
So if you leave the light on by accident (forget to lockout) yr bats will drain to 0v
Get a protected bat
tedh35
Thanks so much to VK-GX, moderator007, gchart, Sillen and everyone who responded to my question about recommended 14500’s for a Lumintop Tool AA 2.0 light.
I appreciate it very much.
Ted
moderator007
There so close its not even funny. Differences in time of manufactor or slight differences in the anode and cathode material or electrolyte could make for those slight differences. Even a few degrees in internal cell temp can make a change in the numbers but the curve should look close to the same.
The shockli looks like it holds a slightly higher voltage under the load but that could be from slight changes as described above after the Vapcell was tested (they were the first to use this cell).
nobody
tedh35 wrote:
Thanks so much to VK-GX, moderator007, gchart, Sillen and everyone who responded to my question about recommended 14500's for a Lumintop Tool AA 2.0 light. I appreciate it very much. Ted
Yes - thanks. I was wondering this myself. I will get protected though since there doesn’t appear to be LVP.
yooj
Last seen: 2 weeks 4 days ago
LVP: There is disagreement. Above says no LVP. But Zeroair reports that this light does have LVP
Observed 3.04 v cutoff
https://zeroair.org/2020/01/22/lumintop-tool-aa2-0-ti-flashlight-review/
I’d prefer to use a non-protected 14500, but would do so only if it has LVP. So, any help with resolution of the disagreement would be appreciated.
Yooj
California
Yokiamy
Yokiamy's picture
Last seen: 1 hour 15 min ago
It has lvp which was 3,05 V in my case
yooj
Thanks for the quick reply.
Yooj
California
Yokiamy
Yokiamy's picture
Another important thing to mention, the lighted tailcap (only works with 14500) has a high parasitic drain of 8,5 mA
It will eventually drain your cell (i removed the LED’s in the lighted tail)
moderator007
Mathematically speaking that’s only about 100 hours using a 850mah cell.
A little over 4 days and the battery is dead. Is that about what everyone experienced?
I changed my current limiting resisitors to a higher value right after I received, so I dont know how it was factory.
gchart
gchart's picture
I can’t remember how high mine have been, but yes, it was right along those lines. I was dumbfounded.
moderator007
The EE must have been out that day the resistor value was chosen. Facepalm
d_t_a
Last seen: 7 hours 24 min ago
I think the Tool AA 2.0 may not have LVP, so maybe a protected battery is suggested?
Yokiamy
Yokiamy's picture
It has LVP set at 3V
nobody
So what if you don’t want the battery drain from the LED tail but you still want to use 14500 batteries?  Is there a simple solution?
BOO5TED
BOO5TED's picture
Last seen: 6 hours 14 min ago
Turn the head 1/4 turn to break contact.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
nobody
LOL — don’t like doing that. Is there another simple option?
jon_slider
jon_slider's picture
Last seen: 1 hour 37 min ago
Yokiamy, can you please share the source of your information? because I dont know who to believe:
bilakos10 wrote:
Nev wrote:
Just be aware that it doesn’t have LVP , I always use protected cells in the tool AA , I once ran down a 14500 to under 2 volts.
Indeed there is no LVP. To my knowledge, it quite a common practice on flashlights that use a boost/fet driver and accept both NiMH and LiION cells.
BOO5TED
BOO5TED's picture
If you want to keep the tail light and use 14500, nope.
nobody
Don't really need the tail light.  Does that open up any other solutions?
BOO5TED
BOO5TED's picture
Yeah, just remove the leds so no lights at all on the tail.
nobody
I'll take a look at that and see if it is something I can do with my lack of skills.  Thanks
