These are new highly anticipated Manker MC13. I am still waiting for my order. There is also an option for 18650 tubes. If you look up on Aliexpress there may better prices for the MC13 and E14 III.
Different Led option.
- LED Option1: OSRAM KW CULNM1.TG LED (white light)
Max. 950 lumens output, Max. 760meters beam distance
- LED Option2: OSRAM KP CSLNM1.F1 LED (green light)
Max. 1200 lumens output, Max. 858meters beam distance
- LED Option3: OSRAM KR CSLNM1.23 LED (red light)
Max. 260 lumens output, Max. 450meters beam distance
- LED Option4: OSRAM KY CSLNM1.FY LED (Yellow light)
Max. 350 lumens output, Max. 506meters beam distance
LED Option5: OSRAM KB CSLNM1.14 LED (blue light)
Max. 115 lumens output, Max. 640meters beam distance
I’m not sure but it could be that the “This item has NOT included any battery” applies to the extra 18650 tube (which doesn’t have a 18650 cell), rather than the MC13, which the listing says has a 18350.
How do you like the mode spacing? Based on the specs, mode spacing looks horrible. Moonlight to low is a huge jump, and then low medium and high are very close to one another!
