I already emailed Hank about BOTH of my KR4s, they are awesome! The 2200 and the deep red tints are fantastic, perfect beams. This guy sets the bar high for timely communications and faster shipping than should be possible.
Thanks again, Hank!
Thanks again, Hank!
Nice to see more people getting flashlights with SST-20-DR deep red 660 nm LEDs. I had wanted to get a deep red flashlight for a long time, but there was no deep red flashlight with Anduril available anywhere. Perhaps SST-20-DR could be added as an option on the website. A significant number of people signed up for Sofirn C01R group buy, there might also be demand for more powerful deep red flashlights.
Solution for the “lanyard ring is not compatible with 18350 tube” problem: Noctigon KR4/KR1 Tactical Ring / Lanyard Ring (3D printed)
XHP35 HI options disappeared from Noctigon K1 page.
The XHP35 is discontinued
I am really looking forward to a light even larger than a K1 SBT90 but with a triple 21700 setup.
Personally i think it will perform even better due to an even larger reflector, good heatsinking, thermal mass and a higher energy supply
Or for even more of an energy supply, a triple 26800 battery set-up…
D18 sized (but slightly longer due to reflectors), triple 21700, quad SBT-90.2 could be amazing.
Like this one, but better:
Any update on a new KR4 clip?
The more I think about it the more I like the idea of the clip being built into the tail cap. Similar to this but deep carry.
This would make it a simple tail-cap replacement option. Similar to benchmade knife clips it could be screwed on or it could just be permanently fixed and you change the tail-cap to add/remove the clip…
I’ll worry about the clip once my KR4 gets to Canada, been having a blast with the KR1 no issues with the clip for me…… Though then again I’m pretty sure the ship that my package is on is lost at sea along with its crew maybe taken by pirates…… 128 days and counting hope is fleeting….
hope is fleeting….
Are you of the 2020-05-22 15:58 CAYVR / Despatched to overseas like me ? Got my kr4ti 2 days ago and it took under 2 weeks .
Some recent update regarding this situation,
All the orders stuck at this status before have all been delivered at the end of July.
“2020-05-10 16:05:00 CAYVR / Despatched to overseas”
But those packages below are still stuck there, I can’t tell when they will move,
but as far as I can tell they will move at any time of this month
“2020-05-22 16:08 CAYVR / Despatched to overseas”
And they are the only packages to Canada which are still stuck on the way, I’m sorry for the inconvenience.
For example, this is one of the package stuck at 2020-5-10, there is no movement from 2020-5-10 to 2020-7-24
2020-07-29 16:31:00
/ Item delivered
2020-07-29 11:17:00/ Send item out for physical delivery
2020-07-29 06:42:00/ Receive item at delivery office
2020-07-28 18:43:00/ Receive item at sorting centre
2020-07-27 01:00:00/ Receive item at sorting centre
2020-07-26 17:14:00/ Transit to Destination Processing Facility
2020-07-25 05:01:00/ Held by Customs at Destination
2020-07-25 05:01:00/ Arrival at Processing Center
2020-07-24 23:25:00/ Arrival at Destination
2020-05-10 16:05:00CAYVR / Despatched to overseas
2020-03-31 23:30:59HK / Hand over to airline.
2020-03-31 14:54:00/ Information Received
2020-03-31 14:18:37Domestic Air Cargo Termina,Shenzhen,China / Depart from facility to service provider.
2020-03-28 19:07:05Hongqiao,Shanghai,China / 4PX picked up shipment.
2020-03-28 19:07:05
Hongqiao,Shanghai,China / Shipment arrived at facility and measured.
YUP ! My light is probably chilling with yours =P
There’s several of us!
Even with the extended wait, I still look forward to getting my KR4 when it finally arrives. Been waiting since early April to get it.
It looks like E21A 2200K is no longer an option on the website. It had a good tint below BBL, I hope it will be back or (even better) be replaced with E21A 2000K.
Anyone with a KR4 experienced this problem?
I received a KR4 Ti today.
Everything appears to function as it should except thermal stepdown.
Once the light gets hot it does not step down, instead the light shuts off completely, including the AUX LEDs.
It feels like the outside of the light reaches around 65°C - 75°C.
When the light has cooled down a little after a minute or so it comes back to life, the AUX LEDs come back on and the light can be operated normally until it heats up again then it shuts off.
I have tried resetting the light and thermally calibrating but it is still the same problem.
It looks like the thermal stepdown is not working properly and so the driver is heating up then triggering a thermal protection in the driver, if it has such a safeguard?
My normal questions don’t apply, since you’re you and you know better. However, could you post the firmware version? My understanding is a 15-click from off should blink it out in YYYY-MM-DD format (though I don’t own anything with a new enough version to do this).
It sounds like the sensor may need to be calibrated. Have you tried doing a factory reset with the light at room temperature?
It also sounds like the battery might be getting overloaded and shutting down until it cools off. Something is causing it to disconnect power, wait, then reconnect power.
I don’t know for sure that’s what is happening, but the issues described could be caused by bad calibration and a cell which isn’t strong enough to sustain full power. Recalibrating it could probably fix one issue and avoid the other.
Oh no! It looks like I waited too long to place my order… patiently waiting to see if it comes back.
-Randy
