Wowtac is too weak toy for me.
I haven’t heard about this Acebeam to be honest, probably because of its recent release, but performance seems to be really nice.
LEP flashlight like the Acebeam W10 have the best throw to size ratio.
I know, but price…
I found info that LED used in this flashlight is W1, but dunno If this site can be trusted.
Maybe consider the KR1 in another emitter type such as the XHP35.
The Lumintop FW1A may be interesting as well.
From what I know of… this would be my list
Convoy M2 w/ WF1 and 5A driver - 90Kcd and ~$30. Truly pocketable. Not the most straightforward to get focused/assembled tbh, but worth it in the end.
KR1 with WF2 —- thicker than the M2 and about the same range but more lumens. E-switch and off the shelf easy. Desperately needs a new clip design though…
L17 —- Don’t own one nor even seen a review but I have an ET G25C2 I’ve modded with a LEDIL IRIS and WF1 and it’s a slick 130kcd thrower with a beam wider than you’d expect for a 1mm emitter. Should be equivalent.
C8+ with WF1—- Hard to find love for C8s anymore. But some see close to 200kcd and it’s one of the best reflector to bezel diameter ratios out there, still.
Haven’t handled any of the 50mm class of reflectored lights other than my old Jacob A60 running a WF1 and making ~240kcd. I’ll tell you though it’s a very serious light. Compact yes. Pocketable? Not for me.
I personally find most everything between ~35mm and ~50mm awkward and they rarely get used. Not comfortable/practical to pocket and then not big enough to get the performance you expect from a shelf queen (throw-wise). If you wear a holster or tool/duty belt then this goes out the window, but I never do. YMMV.
I did lots of research a few months ago to find the best pocketable thrower here: In search of the best pocket thrower flashlight – Dave's Tech Reviews
You can see the full spreadsheet with more details here: Flashlight Throwyness copy - Google Sheets
I went with the Manker MC12, partly due to price.
What is the best size / range ratio? Isnt it typically the larger the size the greater the range?
I don't know how far it throws, but my compact thrower of choice is the BLF-D80v2.
Thanks for Your interest in this topic and all served propositions, I really appreciate that.
First of all- I don’t aim in all those finger-sized toddlers nor modified ones, even if they offer best size-range coefficent, because I need flashlight with tight beam and defined spot (dont really care about considerable spill) which makes at least above 100 kcd (ofcourse more is better), so things like FW1A, S2 etc. are not my cup of tea.
My personal definition of pocketability might differ from generally accepted one. It doesn’t have to be super tiny. It should just fit my rather not very huge hand, and when put in a holster or a pocket won’t feel like pear or child’s head under my coat, and same as before- more compact size is better here. I’d prefer slim head (that’s why at first I mentioned KR1, and I’d choose it over MC12), but if torch would be particularly efficent- I’m willing to loosen this feature (that’s why I added U22 II and this whole my embarrasment exists )
I’d really want to consider LEPs, but my pocket is not so fat :D. Could’t find specific info about range/candela number of BLF D80V2.
For now I’m adding L17 to my list of choise next to the KR1 and it will actually take manker’s place though.
What about The Noctigon K1 with white flat?
It’s a fair amount larger as the KR1, but it comes with an awful lot of throw.
Astrolux FT03 SST40
Man, You can’t even imagine battle of thoughts in my head when I saw first reviews and beamshots of this gem. I’d like to have one, ofcourse, but I know that it will become toy on my shelf at the moment. Maybe someday, but not for now.
@up: same situation, just too big.
The Acebeam K30-GT would be my choice for a compact thrower.
GTmicro. You ain’t gonna get any “compacter” than that.
If you ask ‘BEST SIZE TO RANGE RATIO’,that no doubt the thrower will be LEP.State your budget so that members can definitely help you.
If you ask me,I like c8 size thrower.Cheap host,cheap parts and cheap everthing.
I agree , the C8 is very popular and affordable. :+1:
Have a look at the Manker MC13
Again, kindly thanks for Your response.
Ok, so If talking about budget - I’d say no more than 80 bucks. Also if I had to be more precise about size- my palm says that 140-145mm of lenght is max. I realized that even my smartphone has similar dimensions (142mm), it’s not too much for today’s standards but I didn’t want bigger one. Manker 30-GT appears to be one step up in terms of price and size here. I’d still prefer KR1 over Lumintop GT micro because it’s only 5mm longer with even smaller head, but has way more throw and bigger battery. Same situation (range) is with convoy c8.
Manker MC 13 looks very interesting. I’m curious if it would be shorter than L17 when I’d choose 18650 tube, because I don’t want 18350.
To be honest, it would be great If some competent person could also say a few more words (just some pros and cons and is it even worth it :D) about this TIR flashlights technology. I read about it, but still I’m not familiar with that topic at all.
Pocketable yet really far thrower:
The Nightwatch NI10L Iralite Osram:
Interesting light. It’s a bit long, but I really love 26650 battery (miss 5000mAh in all those compact flashlights) composed with acceptable head diameter. It has “even” profile which I prefer, instead of slim body and bulgy head. Price seems oddly low though. Do you know exact throwing parameters like candela/range and UI funcionality? Cant find them anywhere.
