I have a question for those who sand down TIR optics to fit in lights because I sanded mine down to fit into a D10 and it resulted in having a donut hole. How do you guys remedy that or is it now a lost cause?
Hmm, I’ve never heard of that happening. What optic was it, a narrow angle one? I tend to use wide angle ones for close up work. Those usually have a pebble texture finish. You might try raising or lowering the optic to see if that changes the focus.
It was a 60 degree pebbled lens. Similar to this one. . There isn’t a lot of clearance to raise/lower the optic. I wanted to leave the glass lens there since I made the mistake of shaving the diameter a bit too much and is not making a prefect seal in terms of waterproofing.
We have the same mods (I use the glass lens in my D10 also, but no centering ring), but I don’t have a donut hole pattern. You removed the white part, yes?
Maybe your particular optic is the issue. If your in the USA you might try buying this one. A little bit of filing is all it needs and the beam is perfect in my light.
If you’re outside the US and it costs too much to buy from Mountain Electronics, you might just try buying a different brand of optic from AliExpress and see if that fixes the problem.
Yeah I removed the white part, maybe it is the optic. I guess I’ll try to experiment on it since it’s good as broken anyways. Thanks for always answering my questions here JasonWW. Really appreciate it.
Are you both using the same emitter? If an optics behaves well with XM-L2 in particular, it’s often not great with other emitters (in my experience anyway).
I did not consider the emitter I was using. I’m using an SST20 in mine. Kinda already destroyed it last night sanding it all around making it a frosted optic so I can’t try on another emitter. An undesirable method but it works, no donut hole anymore.
If my fasttech optics ever show up, I’ll let everyone know how it goes. Currently have the stock XM-L2 (either crap bin or clone, don’t know or honestly care much) in the stock reflector. While it feels like about 50CRI of 7000K, the beam profile is actually pretty good for me. And the output level is honestly just right - I left it on turbo for a while longer last night, and a few parts of the light did get slightly warm, but it’s nothing compared to most of my lights on higher modes. I should grab my SC62 for output comparison to get a good idea of where it’s at, since that’s a cool white XM-L2…
Nothing easy. You can take out the battery, but then you have to store it somehow. That’s not very convenient. Another option is to use a piece of insulating plastic between the battery and tailcap spring to cut power. If the insulator is thin and flexible you can store it in the battery tube for convenience.
If the light is designed a certain way, it’s rather easy: unscrew about a quarter-turn.
The light must use a tail-switch board that insulates the negative end from the battery cap (my Emisar D4 does this). So, the negative path is: Battery ()> spring -> trace near edge of board -> end of battery tube when it screws down fully and contacts the trace. Uh, probably a good example of a non-anodized light that does this is the titanium D4 series.
