I did not consider the emitter I was using. I’m using an SST20 in mine. Kinda already destroyed it last night sanding it all around making it a frosted optic so I can’t try on another emitter. An undesirable method but it works, no donut hole anymore.
If my fasttech optics ever show up, I’ll let everyone know how it goes. Currently have the stock XM-L2 (either crap bin or clone, don’t know or honestly care much) in the stock reflector. While it feels like about 50CRI of 7000K, the beam profile is actually pretty good for me. And the output level is honestly just right - I left it on turbo for a while longer last night, and a few parts of the light did get slightly warm, but it’s nothing compared to most of my lights on higher modes. I should grab my SC62 for output comparison to get a good idea of where it’s at, since that’s a cool white XM-L2…
Nothing easy. You can take out the battery, but then you have to store it somehow. That’s not very convenient. Another option is to use a piece of insulating plastic between the battery and tailcap spring to cut power. If the insulator is thin and flexible you can store it in the battery tube for convenience.
If the light is designed a certain way, it’s rather easy: unscrew about a quarter-turn.
The light must use a tail-switch board that insulates the negative end from the battery cap (my Emisar D4 does this). So, the negative path is: Battery ()> spring -> trace near edge of board -> end of battery tube when it screws down fully and contacts the trace. Uh, probably a good example of a non-anodized light that does this is the titanium D4 series.
Right, which I was specifically addressing. If the light is designed properly, the current path doesn’t use the tailcap, and all you have to do is lift the battery tube off of the contact board that sits in the bottom of the tailcap. The D4Ti should be an example of this - but I do not own one, and therefore cannot test it. There’s some discussion here but I didn’t find anyone confirming it by testing.
Umm, no. I think it’s safe to say (only he can confirm) he was asking something along the lines of:
“I have a light that doesn’t have anodised threads. Can it be made to physically lock out?”.
Eg, my ’502s don’t have ano threads, and can’t easily be made to lock out.
Short answer is no.
Longer answer is yes, if it doesn’t have a spring on the driver side, but only a small bump/nipple, and can take flattops.
In that case, a thick enough O-ring can be dropped in to physically try to push the cell away from the driver. Only tightening it up would squish it tight enough to make contact. So it basically becomes a twisty with tailswitch.
Dedoming is removing the entire dome off the led. You typically might soak it in a strong chemical or heat it up in order to carefully lift up and remove the dome. For LEDs where that won’t work, you can very carefully slice the top of the dome off.
In layman’s terms, the dome increases the apparent size of the LED die and you get extra brightness, but it also makes the hotspot a little larger reding throw distance. With the dome removed you get the effect of the actual die size, the brightness is a bit less and the hotspot becomes a little smaller which will increase throw distance.
Just adding on here, dedoming or slicing LEDs often also has a significant effect on the color temperature and/or tint. The expectation is that the color temperature can be reduced by as much as 500K and the tint can be brought from “green/yellow” to “pink/purple” side of the BBL (i.e., duv is reduced). For example, XP-G2 was dedomed primarily for throw purposes. The LH351D is currently frequently sliced for tint reasons just as much as throw reasons (it is both a very floody emitter, and frequently is found to have undesirable green tint, especially at low levels).
If you’re comparing the domed LED to the sliced/dedomed emitter in the same TIR, you would still get increased throw and decreased duv, as well as warmer tint. You would also get decreased lumen output.
TIRs are super useful for blending an emitter’s output (certain Cree emitters, like XP-G3, have an awful tint variation from hotspot to spill in a reflector, and a TIR evens that out quite a bit) or for getting certain specific beam shapes. On the whole, they’re not going to change an LED’s tint - this is best demonstrated by something that has consistent tint in a reflector already, and comparing it to a TIR. Luxeon V or XPL-Hi come to mind. What’s neat about a TIR, especially something like a 60 degree pebbled TIR, is you can throw in emitters that have much less desirable tint-rainbows in a reflector and have everything come out nice.
Can same be achived by swaping TIR with different degree one? For instance, I’d like more throw from my headlamp, instead od dedoming my emitter could I put a 20* TIR instead of 60*. Do they work like that?
Thank you for taking time to explain it in noob terms.
It depends on the driver. For instance, a FET based driver has battery power going directly to the LED and then the negative side of the LED goes to the driver and it is what controls the current.
You should be able to hook up power to a boost driver and measure the voltage output although it may not be super accurate since there’s no load.
I don’t know a whole lot about Boost, Buck and regulated drivers so I can’t really say for sure.
