I take this as a peace offering, fine with me. True it's not a BLF design, but it's ok for them to add some BLF labeling - it's a nice tribute. It's all good
I don’t think rights are relevant in this case. BLF is not a legal entity. The logo was created back when BLF was doing projects with Manker, if I recall correctly, for the purpose of being engraved onto lights Manker produced for BLF.
So it’s not that weird for it to show up here. It’s just typically only used on items which were designed by BLF or modified based on requests here. However, it wouldn’t be the first BLF-branded stock lights. It also wouldn’t be the first Manker product with a BLF-branded box created specifically for a BLF group buy. The X5+X6 had a special combo box.
If I understand correctly, this is a group buy created specifically for BLF, because a few people here asked M4D M4X if he could get a discount code… so he asked Manker, and the agreed-upon solution was to do a discounted group buy if there was enough interest. It’s not really any different than a bunch of other stock-item group buys which have been done here in the past, some of which were BLF-branded.
The weird part is that Manker has usually not approved stuff like this. So, the existence of this group buy may signal a change of heart, or a shift in company policy, or something. Or the branding may just be a loophole to get around Manker’s strict MAP policies.
Tom summed it up nicely as maybe a peace offering.
thanks TomE and ToyKeeper!
Manker does not want to run discounts on items that are sold by their partner shops.
so they made a "special edition" just for this groupbuy.
I guess a "M4D edition" would not be wanted by many :D :(
would you prefer it without the BLF logo?
Ahh, makes sense - more of a pure biz decision. Again, I see no problem.
21700/20700 Battery Storage Case Silicone Protective Cover for Battery
Original INR21700-50E 3.7v 5000mAh 21700
Original INR21700-50E 3.7v 5000mAh 21700 High-Performance Lithium Battery Specification: Battery name 21700 cylindrical lithium ion battery ...
INR21700-48G 4800mAh 21700 10A Discharge
INR21700-48G 4800mAh 21700 10A Discharge High-Performance Lithium Battery Specification: Battery model INR21700-48G Battery specifications ...
Original INR 21700-30T 3000mAh 3.6v 30A Discharge 21700
Original INR21700-30T 3000mAh 3.6v 30A Discharge 21700 High-Performance Lithium Battery Specification: Battery model INR21700-30T Battery ...
LG INR 21700 M50T 5000mAh 3.6v 21700 High Drain Rechargeable Power Lithium Battery
LG INR 21700 M50T 5000mAh 3.6v 21700 High Drain Rechargeable Power Lithium Battery Specification: Battery Brand LG Battery model M50T ...
Keeppower P1495U Micro USB 14500 3.6V 950mAh
Keeppower P1495U Micro USB 14500 3.6V 950mAh Specification: Brand KeepPower Part No. P1495U Maximum Size 14.3 x 50.4mm(±0.2mm) ...
Keeppower P1450U1 AA Micro USB 14500 1.5V 1950mAh
Keeppower P1450U1 AA Micro USB 14500 1.5V 1950mAh Specification: Brand KeepPower Part No. P1450U1 AA Maximum Size 14.2 x 50.2mm(±0.2mm) ...
Keeppower P1832U Micro USB 18650 3.6V 3200mAh
Keeppower P1832U Micro USB 18650 3.6V 3200mAh Specification: Brand KeepPower Part No. P1832U Max Size 18.5 x 70.3mm (±0.2mm) ...
Keeppower P2150TC TYPE C USB 21700 3.6V 5000mAh
Keeppower P2150TC TYPE C USB 21700 3.6V 5000mAh Rechargeable Battery Specification: Brand KeepPower Part No. P2150TC Max Size 21.4 x ...
Keeppower P1835U (Ver.2020)
Keeppower P1835U (Ver.2020) Micro USB 18650 3.6V 3500mAh Rechargeable Battery Specification: Brand KeepPower Part No. P1835U(Ver.2020) ...
Convoy Z1 SST40 2000lm Zoomable
Convoy Z1 SST40 2000lm 12-group Modes or Ramping driver Zoomable Temperature Control 18650/21700 Powerful LED Flashlight Features: -The body of this ...
please use "the password" ;)
WUBEN L50S 5-Modes 1200LM P9 LED
banggood.comWUBEN L50S 5-Modes 1200LM P9 LED Tactical Flashlight USB Charging Mini EDC Torch For Outdoor Camping Fishing
WUBEN E12R 6-Modes 1200LM
banggood.comWUBEN E12R 6-Modes 1200LM Rechargeable Brightness EDC Flashlight 3100mAh Power Bank Portable Mini LED Torch for Camping
WUBEN A9 12000LM XHP70.2
banggood.comWUBEN A9 6-Modes 12000LM XHP70.2 Type-C Rechargeable Flashlight 420M Beam Distance
NITECORE TIP SE 700LM OSRAM P8
banggood.comNITECORE TIP SE 700LM OSRAM P8 Dual Light LED Keychain Flashlight Type-C Rechargeable QC Every Day Carry Mini Torch
NITECORE TIKI GITD Glow-in-the-dark 300lm
banggood.comNITECORE TIKI GITD Glow-in-the-dark 300lm Mini LED Keychain Light High CRI UV EDC Flashlight Self-luminous Camping Light
Any codes or discounts available for Astrolux FT03 SST-40?
Thx
Convoy M21C-U XHP70.2 High Lumen Powerful 21700
Convoy M21C-U XHP70.2 High Lumen Powerful 21700 Flashlight Memory Function LED Tactical Torch Searching Light Specification: Material Aluminum ...
Convoy Grey XML2 1067lm 2 Group 3/5 Modes 18650 EDC
Convoy Grey XML2 1067lm 2 Group 3/5 Modes 18650 EDC Specification: Product name: Convoy S2+ Tactcal LED Flashlight Brand: Convoy Model: ...
NITECORE D4 Smart Battery Charger
NITECORE D4 LCD Display QC Quick Charge Smart Battery Charger For Lithium Ni-Mh Battery 18650 26650 21700 RCR123A AA AAA Note: We will send you a plug ...
TRUSTFIRE MC12 XP-L HI 1000lm
TRUSTFIRE MC12 XP-L HI 1000lm USB Rechargeable LED Headlight 105m IPX8 Megnetic EDC Flashlight Hunting Running Fishing Lamp Specification: Brand ...
you got PM ;)
Thx
Sofirn IF25A Potente Torcia Super Bright Anduril con 4x LED SST20 21700 Batteria
Sofirn IF25A Potente Torcia Super Bright Anduril UI USB C Lampada ricaricabile con 4x LED SST20 21700 Batteria per l'escursionismo all'aperto CONTACT ME ...
Sofirn IF25A 3800 Lumen KIT
Sofirn IF25A Max Output 3800 Lumen Anduril UI superhell USB C wiederaufladbare Lampe mit SST20 LED und 21700 Akku FÜR DEN CODE SCHREIB MIR EINE MAIL! ...
Sofirn BLF SP36 ANDURIL KIT
Sofirn BLF SP36 ANDURIL 5600 Lumen, Super Hell raufladbare USB C 5000K 90CRI mit 4x Sumsung LH351D und 18650 Button top Batterien FÜR DEN CODE SCHREIB MIR ...
Sofirn SP70 5500 Lumen mit 26650 Akkus
Sofirn SP70 LED Taschenlampe Extreme Hell 5500 Lumen CREE XHP70.2 LED mit 26650 Akkus Die SP70 ist mit einer CREE XHP70.2 LED ausgestattet die 5500 ...
XHP70 1500m Brightness LED Floodlight
XHP70 1500m Brightness LED Floodlight 8000mAh USB Phone Power Bank Rechareable Poweful Flashlight with Tripod
“size (US) S or M” is size of flashlight
Small one: 21x 11x 10.9cm
Bigger one: 30.5x 15.3x 15cm
(length x Head dia x body width)
looks good
Code for Mokume/Dama FW3 please!
Never got it like some guys and deposit was payed...
can you please PM me the email you used to pay the deposit?
Servus Martin,
That's a really interesting device. But shipping costs somehow spoil the great offer. Any chance that Banggood will offer cheaper shipping anytime soon again? (maybe a rhetorical question, though :-D )
Schöne Grüße nach Österreich,
Thomas
´rona and all the closing airlines did raise shipping costs
honestly i think the moves from the €U to prevent ordering from outside will raise costs much more in the future
(i might open a shop then....)
