I put in 3 SST-20’s 4000k from from the Sofirn store and a MTN Fet DD 20mm in a C8F. More of a parts assembly than a crazy mod, but it suits my needs so far. I like rear-clicky’s but maybe I’ll put in a sofirn driver with e-switch eventually. Removed the internal switch for now and re-installed the silicone boot too keep water/debris out. Used 18ga wire but left it long enough to not blow the sst-20’s and be able to swap drivers later if I decide to. LG MJ1’s get the light warm pretty fast but don’t seem to change the color or threaten blowing the LED’s. I probably won’t try a 25R, but will look for a high capacity 21700 with less extreme discharge in the future. Still haven’t gotten on the 21700 train yet.
I forgot what a pain teflon coated wire can be to work with, but the skinny slots under the reflector and solder pads made it a good choice and I made it work somehow without destroying any thing
I had to leave the leads long enough from the MCPCB to solder to the driver after the head and reflector was assembled. Kind of a pain for a novice modder like me, but it worked out.
Sorry, I forgot pics of how I coiled the teflon wired inside the body, but it’s not hard to imagine and worked pretty well. I’m pleased with the beam profile and want to build another one. Wish I had the confidence to slice an sst-20.
<img src=“https://imgur.com/Mer1XUz” alt=”
sst-20 with reflector assembled and light thermal paste, pre-fingerprint removal and lens/bezel install. Very easy light for a novice modder.
<img src=“https://imgur.com/6icBKqP” alt=”
After finger print removal and bezel install
<img src=“https://imgur.com/LblYnNu” alt=
Tail switch polished parts and De-oxit applied to all contacts. Is there an easy way to make a lighted tailswitch with the Mtn fet driver? Do I need a bleeder resistor if I put led’s on the 21mm board? Stock switch is very beefy already and has spots for leds it looks like.” />
<img src=“https://imgur.com/Ug7KLHm” alt=
Mtn fet DD 20mm fit nicely in 21mm slot. De-oxit applied to contacts, already came bypass (older version of driver, still works though) Guppydrive rev 2” />
<img src=“https://imgur.com/hAl9s0f” alt=“Beam shot on protected 6a battery just to make sure I didn’t blow anything. Nice beam, even on protected battery it’s bright enough to hurt your eyes on turbo reflecting off a wall about 8m away.
</p
