【convoy】H4 and B35AM options are updated
4040 gasket and 4040 copper DTP board are all in production
2 kinds of 4040 gasket are all in production now
try code MWYZ965PO6R0
20mm / 16mm copper DTP board and 9mm / 7mm 3030 gasket are all in production
oh ,i will take some photos
Okay, updated. Happy to be corrected on U vs S.
Awesome oweban!
oweban, your above table is probably mistaken. djozz tested the CSLNM1.F1,
and according to djozz's spectrum graph I'd say the above frequencies match those of the 13 or True Green (513-545nm) in oweban's diagram.
Maybe the frequency ranges are changed, i.e. 13 / True Green is 554-566nm, while F1 / Pure Green is 513-545nm?
Is there a chance the L21A single cell flashlight will fit in the Holster / Cover / Case for M3 M21C M26C
few more questions about L21A :person_facepalming:
Is it difficult to get XHP 35 HI with 5000K?
Any chances for a L21A version with a side switch (like L6) and maybe even ramping?
Any chances for M21C-U, M21A and L21A version with Osram emitter?
XHP35 (both HD and HI AFAIK) have been discontinued. There are already many popular lights that used them out of stock within the last few months.
Barkuti - interesting; I just wrote that up based on the numbers that Osram gave in their product selector:
Well, there is an error somewhere, probably a small slip-up from Osram but can't say for sure. Will ask djozz to see if he really got an F1.
All good! If he has an F1 and 13 and tests them, and they’re flipped around, I’ll go and change the chart. Otherwise I might leave it because that’s all I’ve got to go off :slight_smile:
Yup. And the new Olight Odin is using something but Olight won’t say what. (I even tried e-mailing customer support.) There was some discussion on reddit that it might be XHP35.2 Hi, but I’m unconvinced.
If its 2000 lumens and the light “vibrates” (shit boost driver probably) xhp35 seems a good bet. Who cares though olight = :confounded:
not difficult,
it’s the sale of XHP35 HI is not good ,
There is not much demand for 5000K, so I did not order 5000K color temperature LED
The L21A can be slightly modified to match the M21C-U driver
The centering of the osram spot is not very good. I am producing a small accessory to improve the effect.
The main reason is that the sales volume of L21A is not much, so I have not made the matching holster for the time being.
Probably a (chem?) dedomed XHP35.2 HD. They dedomed the 35 HD for the M2R Pro and Warrior X Pro. The yellow borders of the pad are a dead giveaway IMO. Could be a stock 35.2 HI too, nobody actually has pictures of that yet AFAIK.
Pretty sure the only reason for not picking the 35/ HI (with a FAR superior tint :person_facepalming: ) on those previous lights was getting some slightly higher max output numbers to put on the packaging and give reason to “upgrade” for consumers that don’t know how perception of brightness works. Clear case of a marketing team leading engineering decisions, and I bet it got them a ton of sales to boot…
But isn’t that how the whole brand is run? :stuck_out_tongue:
