MtnDon's Hand Made Class, 8th Annual BLF/OL contest entry
131 posts / 0 new
MtnDon
MtnDon's picture
Last seen: 1 hour 18 min ago
Here we go. My official start to my entry in this years hand made class.
I’ll save the space in this post to add the completed light to at the end, assuming I make it through to the end.
NOTE: Some of the parts I made first were remade for the final version. In the following posts if the images are small it is because I resized the image display on those parts I later re-made.
Here is the completed light, unless I tweak things or make changes.
The evolution from my imagined concept through the process to the end follows……
Edited by: MtnDon on 10/22/2020 - 23:25
MtnDon
MtnDon's picture
The first raw material to be worked. This will be a pill, of sorts.
That is a copper plumbing reducer, 3/4” down to 1/2”. It is meant to be inserted into a 3/4” copper pipe and then a 1/2” copper pipe inserted into the ineer, smaller, hole and the whole works soldered together. CORRECTION: The outer diameter is the same size as the OD of 3/4” copper plumbing pipe. The reducer is made to be inserted inside a 3/4” copper pipe fitting, not inside the pipe.
It has a 7/8” O.D. so I drilled a 7/8” in a plywood scrap and sliced it in half. It makes a nice pair of soft jaws to grip the copper metal firmly enough without marking the copper. This will be clamped in a machinist’s vice.
Using a dremel tool I opened one end. Not easy when hand holding the Dremel tool.
The enlarged opening came out a bit too large in diameter. The 17mm Nanjg driver fits. I have to drill some holes and do other things to this before I can solder the driver in place. Also need to decide on firmware and flash that. I have no idea what is on this driver (salvaged from something else I did).
Anyhow that is where I am right now.
MtnDon
MtnDon's picture
I tries cutting out the other end. I did a little better, the gap is slightly less. So, this will probably be the end that will mount the driver. The driver will receive a center spring as well.
Thanks for looking. Any comments welcome.
Scallywag
Scallywag's picture
Last seen: 3 days 22 hours ago
Hmm, that plumbing reducer looks useful… Innocent
I think I’m probably going to end up using brass washers to stick a shelf with a hole in my build, though. I may have to solder more than one washer together, which the hotplate should make easy work of.
Also, official rules state “Electric Drill/ Drill Press” are allowed (and I’m sure that includes the funny mounts for Dremels that turn them into an almost- drill press).
Anyway, I’m subscribed and looking forward to seeing more.
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
MtnDon
MtnDon's picture
Yes, that reducer is a handy one. That type is not available everywhere. There are other adapters that do the same basic job and use less copper and are cheaper. I got those at a small hardware store.
Don’t ya’ll just hate it when you blindside yourself to something just because you fixate on the first idea that came to mind? First there was Plan A, then Plan B. Now I have Plan C.
Rather than try to carve material away to make a ledge for the driver to sit on, how about building up a shelf? My thinking went awry when I fixated on using one of the many 17mm drivers I have on hand. As we were eating dinner I remembered that there should have been a 20mm 8*7135 driver in the driver box. I had used it in a temporary thing and forgot where it was.
A 20mm driver will slip inside a 3/4” copper pipe very nicely. I’m using 3/4” copper, so…..
So…. to start I cut off a 3/4” long piece of the 3/4 pipe, and secured it in the vice.
Next I had to remove a section of the pipe wall so it could be squeezed smaller and inserted into another length of 3/4 pipe.
I squeezed the section and inserted it, after about 3 attempts. My math calcs were about bang on for the section to remove. Smile
Pushed it far inside to provide a ledge of sorts…
I cut the outer pipe with the tube/pipe cutter at a position that would let me try both ends with different amounts of recess. Here are the two pieces with silver solder flux applied.
After heating with the butane torch and applying some silver solder…
Here, after cool down, is a trial fit of the 20mm driver…
The assembly has been cleaned up. Here it is with the driver. This driver even had the firmware I wanted, Crescendo. Saves the time to reflash it. For the purpose of this project I may remove a few 7135’s. This light is not intended to be a barn burner. I have not decided for certain yet.
I think Plan C is the winner. I guess we will see how that goes. Smile
Scallywag
Scallywag's picture
Hey now, our shelf ideas are starting to overlap! Big Smile
MtnDon
MtnDon's picture
It might have been your mention of a 20mm driver that caused the wheels in my head to mesh? Big Smile
I have 6 or 7 assorted 17mm 7135 drivers so it just seemed right to use one of them….
CNCman
CNCman's picture
Last seen: 7 hours 30 min ago
Yep, every time I go to the hardware store, just have to shop around for ideas, LOL. Wife always curious just what I’m looking for so I tell her just looking for things I may need for whatever. If you have parts available in your mind, you have options for putting together or fixing things, not always flashlight stuff either. Nice work around a problem. Thumbs Up
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
MRsDNF
MRsDNF's picture
Last seen: 10 hours 24 min ago
Nice to see a start MtnDon. Thumbs Up
MascaratumB
MascaratumB's picture
Last seen: 2 hours 49 min ago
Good luck and good work MtnDon Thumbs Up
Looking to learn in this Glasses
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior / OW Mini // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R / E61 // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review’s Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
MtnDon
MtnDon's picture
I ignored some things I could have, maybe should have, done today and used an hour or two working on this. Smile Facepalm Question
Okay, when I made the previous piece, a pill-like thing, I made 2 different depths to the shelf, one on each end. I decided which end was best suited to the task. I wanted to cut or grind the other end down to remove the ringed shelf inorder to have more contact area between that side and the copper disc it would be mounted on.
There was not sufficient material to be able to use the tubing cutter. Cutting off with a manual hacksaw never results in a 90 degree cut. Trying to use the chop saw was too dangerous on a small piece. So, I opted to grind and sand it down. The preliminary rough material removal was done on the belt sander (180 grit), hand held and eyeballed. I then squared up the disc sander table and miter gauge (cheap thing that it is) as best as I could using a metal square that has proven to be accurate. The picture below helps explain my process. The “pill” is slipped inside the copper coupler fitting closest to the sanding disc. The length of 3/4 copper inside that coupler is pressed against the “pill” to press it against the sanding disc. The second coupler is there to keep the pipe assembly parallel to the table and miter surfaces.
Rotating the copper tube while moving the assembly forward to lightly touch the rotating disc (220 grit) slowly removes material. Only allowing the copper to touch the disc whie the copper is being rotated allows a near perfect 90 degree end to be sanded to the copper pipe end. That is my theory anyhow. If anyone has a better idea I would love to hear about it. Short of chucking in a lathe, of course.
The end appears to be reasonably square…
There is a slight gap between the collar insert and the pipe, but the inserted part is well soldered as trying to pry with a small screwdriver blade resulted in no movement.
Next we see a 1-1/2” copper disc. Old Lumens used to buy copper from Bopper Metals and so do I. That is 14 gauge, about 0.085”. The yellow plastic thing is a center finder. I thought I would show it just in case some viewer is not familiar with one. The work piece that you need to find a center on, is held in the vee and a line scribed. Rotate the work 60 degrees or so and scribe again. Repeat. There should be 3 lines that intersect at a single point. If not, try again. Maybe the work is not a perfect circle or something went wrong holding the material in place.
If you look carefully the three intersecting lines can be seen.
I did pretty good marking the center point with a very pointy awl.
I then drilled a hole in the center. Sorry, but I missed taking a photo of that. You will see the hole later.
A marking gauge was used for the next step Here’s a photo of the tool…
The pin is steel and is ground to a chisel edge. The block slides on the shaft and is locked in place with a set screw. It is usually used to make a line parallel to a straight edge on a board. I used it in a circular fashion.
The “pill” is to be silver soldered to the center of the copper disc. One method to center it would have been to drill a large hole, just lage enough to fit the “pill” into, but I do not have a large bit the right size. I calculated how much rim there should be all around the “pill”, set the marking gauge to that and scribed a series of short lines around the circumference of the ciopper disc.
I forgot to photograph that at the moment I did it. When I realized my error I scribed the reverse side of the copleted assembly to illustrate the scribes. The drilled hole is also seen. It is needed to pass some wiring through.
Next a real challenge. The “pill” is to be soldered to the disc, centered as accurately as possible. When the parts are fluxed and heated the too parts can easily slide out of placement. Touching the loose part with solder wire can also shift the alignment. I decided to try clamping with a steel C-clamp. I thought my torch could put heat into the parts faster than it would dissipate. I hoped so at least. Here is the clamped setup with the clamp held in the vice. Flux has been applied.
The torch heated fast enough to melt the solder nicely. I cut small pieces of the solder wire (1/8” long maximum) and positioned several around the joint. I placed 6 such pieces of solder and neglected to take a photo before heat was applied. Here is the soldering taking place…
…waiting for the parts to cool off… the soldered joint appears to be solid.
Here it is after being washed of the flux residue. Note the solder that has wicked under the edge of the pill on the inside. That wis from molten solder being drawn into joint by capillary action. No solder was applied directly to the inside of the pill-disc joint.
I am happy with how that worked out.
MRsDNF
MRsDNF's picture
How hot did the copper get on the belt sander? I hate grinding small bits of copper when your hanging on to it with bare fingers.
Funny wooden mallet there Don. Think you need to reposition the nail to hold the head on. Silly
MtnDon
MtnDon's picture
Hot! I kept dipping it in a can of water. The belt is wet/dry, though very wet saneding it “out” because the the electric motor. Wink
The head is replacable so I can switch to a prettier wood, a plastic or even a lead head. Wink
Skylight
Skylight's picture
Last seen: 5 hours 17 min ago
Really nice work, MtnDon. Very precise and clean. Crown
Much better than a pre-made pill but also more challenging.
MtnDon
MtnDon's picture
This light may be a little unusual in some respects. I guess all my entries in this annual event have leaned towards the unusual.
This aluminum heatsink will be incorporated. It is made by Wakefield-Vette. 38mm in diameter, it is 20mm in height.
The copper disc was drilled to permit mounting the mcpcb to the copper disc and the copper disc to the heatsink.
I reflowed the LH351D’s to the mcpcb before I had filed the notches needed to mount the mcpcb to the heatsink. Facepalm Fortunately I was able to file the new notches without damaging anything. There are many combinations of mounting holes in the heatsink, but none match up to the mount holes in the KD mcpcb.
The led’s are 5000K, CRI90; I had them on-hand, left-overs from a previous project purchase. So far, everything I have used for this are left-overs from something else, or parts bought previously and never used due to a change of plans, except for the copper couplers
4-40 screws hold the peices together for a test fit.
That is a mcpcb from Kaidomain I bought some time ago. I had one of the KD optics that came with the triple red mcpcb I used in last years contest entry. When I bought the KD triple mcpcb’s I was not aware that the optic they use is slightly different from the Carclo ones. Anyhow we’ll use it here.
I did test fire it and it worked fine. The 20mm driver was from Convoy, bought a few years ago and used briefly in some other project before being swapped for a different one.
That may be all the work on this for this week.
Thanks for looking in.
MascaratumB
Great work Don Wink As always Wink
And now I realized that the idea I was having for an eventual entry is somehow going on the direction of yours, so I will probably refrain from entering (not only because of that though, time, skills and available resources too)! Wink
Keep it up Blushing Beer
pennzy
pennzy's picture
Last seen: 1 hour 36 min ago
Looking good Don.
MRsDNF
MRsDNF's picture
Thumbs Up
CNCman
CNCman's picture
You got us on the hook again Don Cool
Great photography too, Thumbs Up Are you using incandescent lights for pictures ? I tried led lighting and it comes out unusable.
I just purchased a Cannon camera and still playing / learning to use it.
MtnDon
MtnDon's picture
CNCman wrote:
Great photography too, Thumbs Up Are you using incandescent lights for pictures ? I tried led lighting and it comes out unusable. .
The lighting is mostly the LED workshop ceiling lighting. They are 5000K strips (50 cm long, 12 VDC run off of a few 12 VDC power supplies fed by the 120 VAC house power.) I bought from some seller on Aliexpress a few year ago. Some of the pictures were done with illumination from a cheap zoomie. That has a 5000 K LH351D I swapped in. The photos have all been taken the lazy way; using the camera in my Galaxy 9+. I’ve been using it for most photography for the past 2 years, except for landscape photos when the camera is simply not at its best. Then I use my venerable Nikon D200 or my Panasonic ZS100.
CNCman wrote:
You got us on the hook again Don Cool .
This project will end up looking more like a standard flashlight than any other contest entry I have done, but with some different touches. Wink
gchart
gchart's picture
Last seen: 16 min 1 sec ago
Looking great, Don!
MtnDon
MtnDon's picture
I have made some progress.
First though, I noticed a couple of problems. The optic legs stick through the mcpcb, so the optic did not seat fully. I thought this was a problem so I sanded the legs shorter so nothing protruded. I am currently not sure if I did the right thing. I has not used a KD triple mcpcb with one of their optics before.
The next issue was that the optic would still not seat fully. Close inspection revealed the portion of the optic that fits over the emmitter did not go as low as it would if the optic was used over a Cree XP-E triple. This project is using the LH351D Samsung. I pondered wheyher or not to slice the domes or to modify the optic, reaming out the “socket” a little. I elected to mod the optic. I used two different sizes of number bits and carefully turned them just using my fingers. I removed just enough material to allow the optic to seat fwith the three legs down against the mcpcb. I also considered drilling clearance holes in the copper disc.
I have not yet wired up the led to check the beam. Hopefully I did not ruin it.
So that was one issue. The other thing I oticed was that I had a slight concentricity problem between the mcpcb and the heat sink as well as with the copper disc that is mounted between the mcpcb and heatsink. The runout was not great but was enough to create possible problems with the next step.
I has a spare copper disc and a spare heatsink though. So I decided to redo this portion of the head assembly.
This time I used a different approach. I first found the center of the copper disc. Then drilled a center hole that matched the diamter of the center hole that the factory made in the mcpcb. I used that drilled disc to determine the point to drill through the heatsink center. The result was just about as perfect as could be when using the tools at hand.
The next issue to correct ws my chosen method of fastening the mcpcb to the copper disc. The previous method relied on using a pait of factory holes in the extrusion that were close to, but not perfectly matched to the notches in the mxpcb. Instead of doing that all over I decided to use the two smaller holes in the mcpcb. The pencil point in the next image indicates the hole pair I mean.
I used a machine screw to secure the mcpcb to the copper disc and heatsink.
I then drilled a clearance hole in the support wood block and proceeded to drill a dimple in the copper plate, using the holes in the mcpcb as a template.
I just barely marked the copper using the drill press. Then disassembled the three pieces and drilled a #50 hole through the copper for the 2 mounting screws.
The holes were hand tapped with a 2-56 thread.
The mcpcb is secured with two 2-56 pan head machine screws.
The heat sink does not have sufficient solid metal in the central area to tap into the aluminum body of the heat sink. The two screws penetrate the copper disc and protrude into a pair of the extruded voids.
Now I am happier with the mcpcb, copper disc and heatsink assembly and am ready for the next section. That’s coming up in the next post.
MtnDon
MtnDon's picture
This next section is a test. It indicates the dirrection this part of the light project is taking, or at least what I am thinking.
I cut a small piece of padauk of a scrap and drilled a 20mm hole in it using a metric forstner bit that arrived from an aliexpress seller yesterday. I bought a small set of the metric bits and they shipped from a US warehouse; only took a few days instead of many weeks, maybe 2 months. The 20mm hole is to fit over the optic and the mcpcb on the front end of the light.
I then used the table saw to trim it down close to the outline of the copper disc making a square shape.
So there is a square. I want an octogon. I elected to sand the corners down to make an octogon, using the disc sander and miter gauge.
There. Looks like a big wood nut.’
Here is the “nut” fitted over the mcpcb and optic. The optic is a snug fit which is great.
So far, so good. It appears to be feasible.
That is about it for now. Thanks for looking in.
gchart
gchart's picture
Looking good Don!
MtnDon
MtnDon's picture
Ooops. I almost forgot I had another short set of images for another test piece.
All flashlights need a body. I am wanting to make the body from some bloodwood I have on hand. Bloodwood is very dense; a sp. gr. of 0.95 with average moisture content. It almost won’t float. It can be difficult to work. I’ll see how it goes. I have only 3/4” thick stock so will glue up two small pieces.
While that glue dries up I thought I’d use a piece of walnut to make a body test. It is 1.5” thick. I marked the centerline with the marking gauge; onec from each side and use the spot in the middle of the two lines as center.
That is a 25mm forstner bit. The shank is just long enough to drill the length I want.
Okay, remember the second rendition of the driver holder/pill that I made, and the slip over sleeve? The O.D. of the sleeve is 24.3mm, a nice slip fit into the 25mm hole that was just bored.
The walnut block is still in the rough state. It will be cut down, but that is all for tonight. Toorrow the bloodwood block will be ready to try drilling. If that goes well the walnut will remain as the test piece and I’ll see how the bloodwood works.
MRsDNF
MRsDNF's picture
Nice work Don. I see your nearly finished. Beer
Agro
Agro's picture
Last seen: 8 hours 59 min ago
I’m very curious to see how does the optic work. You took the riskier path.
CNCman
CNCman's picture
Very nice work and photography too, I really like your hand made tools. Thumbs Up
MtnDon
MtnDon's picture
I don’t have a room without a window, even the shop has windows, so a good test will have to wait until night. However, I was curious about the potic myself so did the best I could. I made a temporary hookup between mcpcb with optic on the heatsink—- wires to the driver —- wires to a cell holder and some alligator clips. Most of the closets are too full of whatever to allow a person inside but one small coat closet had just enough space. Not enough space for a beamshot. The near white wall was only 30 inches from the mcpcb/optic. But there are no strange artifacts showing, no strange colors or unusual shadows or hotspots, so I think the optic still works satisfactorily.
I made some more progress on some parts today. I took pictures. I’ll post an update later this evening most likely.
I downsized the earlier photos of the parts I re-did if anyone looks back.
MtnDon
MtnDon's picture
What I did today on this project.
I soldered a spring to the driver board. There used to be one on there at one time but I removed it for some reason
I needed to make a bayonet mount “thingy”. I found a brass tube with a closed end in the junk box and cut off a short piece. Cleaned the side of the copper tube-pill I made earlier, applied flux. some heat and silver solder. I forgot to take a picture until I had begun cleaning up the flux and excess solder.
It cleaned up pretty good…
The copper coupler needs a slot cut to clear the brass bump.
I used one of my wood tube clamps to hold the piece wirhout crushing the shape. I used a hacksaw blade to make the first cuts, then files…
Small file…
Then when the slot was larger I switched to a bigger file
It works…
The hard to see pencil mark indicates where the slot needs to go next. The slot will be cut “down” not up where the more visible pencil marks are. Those are depth guide marks, niot for the slot. …
Rough, but getting there…
The completed bayonet locking mount…
As I filed off the protruding portion of the brass the solid part was removed and the hollow revealed. It does not look as nice but the solder puddled in the hollow indicates I did make a good silver solder joint as the solder was drawn in.
That is all for now. The washer end of this piece with be mounted to the rear end of the finned heatsink. The mcpcb with its washer is to be mounted on the front end of the heatsink.
More coming later, maybe tomorrow.
NeutralFan
NeutralFan's picture
Last seen: 4 days 2 hours ago
Glad to hear your optic mod worked out. Looking forward to how it all turns out!
I’d rather use my flashlight around the house than turn on the lights.
