I have already done precisely this but I will elaborate since the combined information will be helpful to others.
In addition to the above:
- The right wire length helps tremendously
- When you feed your wires through consider how they will be attached to the boards so you aren’t crossing them over each other above the PCB (it probably wont fit otherwise)
- If your wire will retain any shape at all consider bending it a little into position so you aren’t trying to juggle tweezers, a clean iron tip, steady hand, etc.
If you have one use a smaller tip for only the final 4 RBG wires. A big chisel tip or similar will work better for everything else.
I did my FW3C today, and did a few improvements, took some images.
For the resistors, I ended up using r=330 b=330 and g=680 or 1k. It definitely tooks much better, especially with 1k.
I only had 0804 at hand, so I had to improvise the fit. The green fits sideways, but the blue needs to stay flat to clear the optics. Note that the image below was before I figured this out.
I also twised the ends of the enameled wires differently this time, instead of marking with sharpie. Worked nicely.
Installed sliced dogfarts as I previously mentioned. Absolutely fabulous leds, massively underrated.
I installed my Lume1 driver earlier today, I love the idea of a buck/boost for the FW3A, but I have encountered a bit of a problem. I am experiencing visible PWM until level ~20, I am not particularly sensitive to it, but on the very low levels it has an almost candle like flicker.
I am assuming that I received a dud, but I am curious if anyone else is experiencing something similar.
I’ve recieved my driver 2 days ago and after some playing with it, I want to write something about it.
First issue I encountered was when I tried to solder rgb wires to driver. I ripped one of the solder pads from the board
They are so incredibly delicate, I have some expirience with soldering and never encountered pads so sensitive. Since i never really liked aux led boards, it isn’t that big of a deal for me.
Second issue is extremely strong flickering in lower end of the ramp. It flickers like it’s in candle mode up until I hit ramp level 35-40, which is too bright for a ramp floor. So after puting in this driver, I definetly won’t use my FW3A in “middle of the night toilet run”, unless i want flicker.
Other than that driver works well, especialy the thermal stepdown from top of ramp, which is much better than in factory driver. It doesn’t overshoot or step down too fast like it did with factory driver. There is also obvious improvement in battery life. Overall runtime is about the same, but it is fully stabilized now until deplating battery when cooled. I also feel like pwm of fet channel would be better than just on/off. Fet being just on/off causes turbo step down before flashlight body gets appropriately warm.
Overall it’s good driver but needs improvements, especially in low brightness flicker.
Sorry for all grammar mistakes that I unknowingly made.
I think i found the source of flickering issue. I decided to take out the driver and clean it with both acetone and IPA.
After cleaning, flickering is still there, but nowhere near as bad as it was. Now it completely stops flickering at 15+ ramp level (it was 35-40 previously). I wonder why it was dirty straight from the mail (I didn’t use flux for soldering) and which component is so sensitive to dirt.
Tailcap contacts seem to be fine. In my frustration to fix flickering, I already cleaned them and also checked if original driver would work and indeed it was working flawlessly.
I have 2 of these drivers installed in fw3x lights. Both have a very slight flicker at the lowest setting, but it’s unnoticeable unless I look very close at the light on my white table top.
