Yeah, I have updated it to “rosy(ish)” because of all these comments and because my initial impression of “The “corona” portion is yellowish, so it averages out to about a neutral beam tint.” is probably the most accurate description in my original post.
I can’t measure the duv myself since I don’t have the capability, but based on my comparisons with other lights I have, I am thinking mine drops below the BBL on the highest modes, so, I’m gonna stick with “ish”. I certainly appreciate people with real measurements to show I’m not TOTALLY off, and mine being below the BBL on higher modes isn’t unrealistic.
Thank you for all the real measurements and feedback!
So without any confirmation from Manker we don’t know for sure, but would it be safe to assume these are probably FA3 bin? Considering there hasn’t been much reports of anyone getting a green tinted one?
It’s not about averaging out. The light is right on or under the BBL in most modes (minus 10440 turbo, it drops a bit more there). However, right on or under the BBL is not what some people want when they say ‘rosy’ they want significantly under BBL. There’s no doubt this is one of the best bins of SST-20 we have seen and anyone who isn’t 219b sw45k religion would probably appreciate it.
If you want to split hairs I could probably leave mine running on high for a few minutes and measure all modes “under” BBL.
Yeah, when I say “averaging out” I’m just describing what it looks like to me visually, so probably not the best way to word it. Either way it’s a great tint and I’m very happy with it. I’m glad others are having the same experience.
A Manker E02 II arrived in the mail today. It’s a nice little headlamp!
Pro’s:
Moonlight modes with a AAA!
Slightly rosy tint.
UI is easy to use.
Soft beam with the honeycomb optic.
Capable of running on a 10440 cell.
Con’s:
The magnet in the tailcap could be a bit stronger.
The emitter appears to have been rotated by about 15 degrees when looking at it in Moonlight mode with a AAA.
The pocket clip is a little rough around the edges.
The lanyard hole on the tail cap is off center.
I’m impressed. I’m looking forward the the BLF Muscle Combo even more!
I`v had my E02II for some time now and my E03II arrived a week or so ago and they are absolutely superb lights! the E03 is pretty much like a the big sister of the E02II the UI is the same as far as I can tell, the 03 is just brighter but still goes really low into sub lumen levels.
I`v got the original E02 as well and with the SP40 they look like a happy little family
