Authentic OLIGHT Warrior X Pro Tactical LED Flashlight: OLIGHT Warrior X Pro
Voltage: 3.7-4.2V
Head diameter: 39mm
3m impact resistant
Built-in temperature control module, low battery vibration prompt
High mode brightness and endurance: After 2050LM is turned on for 2 minutes, overheating will automatically be maintained to 1000LM for 100 minutes, and then to 300LM for 23 minutes.
Don’t forget to get the special coupon code in the product page
Sorry that knives still unavailable.
We’re updating shipping note for knives product in our site, feel free to follow the update once the shipping get right you’ll know that. Notice about knives shipping
Today I would like to recommend this ON THE ROAD MX5-HL LED Headlamp
Primary elements:
Cree XP-L2 HD
1200LM
7-mode
pure white
IPX6
smart temperature control
90’ adjustment
12400mAh battery pack
What do you think of this headlamp? Tell me how you feel.
Yes the battery is replaceable and we can list it as an individual SKU if you need. And sorry we don’t have a discount code for it now, but we do promotion/sale twice a week, I have planed to add this headlamp into the sale items list in case you would like to purchase. Feel free to ask if you have any question
Hello guys, today I would like to recommend an item that might be helpful for the current situation.
That is a garden lawn light, which can well work in the yard.
Details:
Polycrystalline silicon solar panel: 2V 100mA
Buzzer frequency: 400+/-50Hz
Effective area: 200-400 square meters
Charge for one day, works for more than 8 hours, pest repellent works for more than 24 hours
Solar energy, no wires required, energy saving and long service life
With 8 LED indicator lights, turns on automatically at night
Effectively repel cats, mice, foxes, raccoons, skunks, rodents, wild boars, minks, etc.
Check here to know more:2PCS Solar Powered Garden Lawn Light
LUMINTOP FW21 X9L is the pro pro model among all the LUMINTOP FW21 series.
Let’s see the details:
Voltage: 3.7-4.2V
Head diameter: 40.2mm
Tube diameter: 25.2mm
Lumens (max): 6500 LM
Waterproof: IPX8
Battery form factor: 21700
Flashlight modes: 5-mode
Details:
Voltage: 3.7-4.2V
Tube diameter: 25mm
Peak beam intensity: 10350cd
Built-in multi-function OLED display, can display various parameters
Built-in thermal control module will automatically adjust the brightness output to keep the unit from overheating
Impact resistance (1.5 meters)
Can’t wait to introduce IMALENT MS06 LED Flashlight
Let’s have a look at the excellent spec:
Details:
Utilizes 6 pieces of XHP70 2nd LEDs, lifespan up to 50000 hours with maximum output of 25,000lumens
Powered by three rechargeable 4000mAh 21700 Li-ion batteries
Instant turbo output by double press the power switch button while triple press the power switch button, can get lowest output
High efficiency constant power supply circuits will maintain constant brightness
Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature
Combination of toughened ultra-clear mineral and anti-reflective coating glass
Aluminum SMD reflector
Aerospace-grade aluminum alloy body.wear-resistant Type II hard-anodized surface treatment
IPX-8 standard waterproof(2 meters submersible)
1.5m impact resistant
Tail stand capability
Head diameter: 56mm
Tube diameter: 51mm
Don’t forget to apply the MAP code to get the 33% off discount ,click here to enter:IMALENT MS06 LED Flashlight
