FastTech New Arrivals & Promotion
This is one flashlight high up on my list! I really like the tail switch and bezel on this light. :+1:
I have to say you have a very good taste! :+1:
Today I would like to recommend this ON THE ROAD MX5-HL LED Headlamp
Primary elements:
Cree XP-L2 HD
1200LM
7-mode
pure white
IPX6
smart temperature control
90’ adjustment
12400mAh battery pack
What do you think of this headlamp? Tell me how you feel.
I might be interested in this. I like the 4 x XHP70.2 headlamp at 2700lm. Do you have a discount code? Are the batteries in the pack replaceable?
Yes the battery is replaceable and we can list it as an individual SKU if you need. And sorry we don’t have a discount code for it now, but we do promotion/sale twice a week, I have planed to add this headlamp into the sale items list in case you would like to purchase. Feel free to ask if you have any question :wink:
Hello guys, today I would like to recommend an item that might be helpful for the current situation.
That is a garden lawn light, which can well work in the yard.
Details:
Polycrystalline silicon solar panel: 2V 100mA
Buzzer frequency: 400+/-50Hz
Effective area: 200-400 square meters
Charge for one day, works for more than 8 hours, pest repellent works for more than 24 hours
Solar energy, no wires required, energy saving and long service life
With 8 LED indicator lights, turns on automatically at night
Effectively repel cats, mice, foxes, raccoons, skunks, rodents, wild boars, minks, etc.
Check here to know more:2PCS Solar Powered Garden Lawn Light
Deer?
hahaha deer are welcome, the garden light may attract them :smiley: (joke
LUMINTOP FW21 X9L is the pro pro model among all the LUMINTOP FW21 series.
Let’s see the details:
Voltage: 3.7-4.2V
Head diameter: 40.2mm
Tube diameter: 25.2mm
Lumens (max): 6500 LM
Waterproof: IPX8
Battery form factor: 21700
Flashlight modes: 5-mode
Don’t forget to apply the MAP code to get 13% off for Authentic LUMINTOP FW21 X9L LED Flashlight
I like this IMALENT LD70 LED Flashlight , fluent design and have all the basic functions,
Details:
Voltage: 3.7-4.2V
Tube diameter: 25mm
Peak beam intensity: 10350cd
Built-in multi-function OLED display, can display various parameters
Built-in thermal control module will automatically adjust the brightness output to keep the unit from overheating
Impact resistance (1.5 meters)
With the code MAP you can get 28% off , click here to product page:Authentic IMALENT LD70 LED Flashlight
Do you have a code for the Lumintop Tool 2.0 in white :smiley:
Dont forget that there is always a 5% off coupon code BLF for Flashlights&Lasers category! :wink:
:+1: :smiley:
Can’t wait to introduce IMALENT MS06 LED Flashlight
Let’s have a look at the excellent spec:
Details:
Utilizes 6 pieces of XHP70 2nd LEDs, lifespan up to 50000 hours with maximum output of 25,000lumens
Powered by three rechargeable 4000mAh 21700 Li-ion batteries
Instant turbo output by double press the power switch button while triple press the power switch button, can get lowest output
High efficiency constant power supply circuits will maintain constant brightness
Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature
Combination of toughened ultra-clear mineral and anti-reflective coating glass
Aluminum SMD reflector
Aerospace-grade aluminum alloy body.wear-resistant Type II hard-anodized surface treatment
IPX-8 standard waterproof(2 meters submersible)
1.5m impact resistant
Tail stand capability
Head diameter: 56mm
Tube diameter: 51mm
Don’t forget to apply the MAP code to get the 33% off discount :wink: ,click here to enter:IMALENT MS06 LED Flashlight
25,000lms lol. Imalent flashlights are NOT worth there asking prices and they are nothing but problematic and there numbers are unrealistic. Good looking paper weight though.
The design is good looking, and functions are not bad, but if compare to the price, maybe what you say is true, it’s not exactly a high cost performance one, there are many alternative items at the same price. :slight_smile:
This time let me introduce a tiny friend SMILING SHARK Mini LED Flashlight
Lightweight and flexible, easy and enough to use in simple household.
The price is affordable:SMILING SHARK Mini LED Flashlight
anything using those tiny alkaline batteries will have very short run times
Plus, of course, they're not rechargeable.
I love me some rechargeable batteries.
Okay today let me introduce a portable and rechargable tiny flashlight TrustFire MINI2 Keychain LED Flashlight.
Lumens: 5~220 LM
Beam range: 57 m
Waterproof: IPX8
Ports:Micro-USB
Battery feature: Rechargeable
Estimated usage time: 23 Minutes (220LM)/7.5 Hours (5LM)
Is it not bad? :slight_smile: TrustFire MINI2 Keychain LED Flashlight
