✌ FREEME - ASTROLUX FT03 Mini OSRAM NM.1 510lm WRGB LED options USB-C 18650/ 18350 Flashlight - ALIVE
ASTROLUX FT03 Mini NM.1
OSRAM Colored NEW USB-C 18650/ 18350 Flashlight
For reference, this is my order timeline for our Group Buy(1st batch).
Note: speed of delivery varies from country to country.
Group Buy Price: from $29.99!!!
Emitter: OSRAM NM.1
Brightness: 510 lumens
Beam Color: White/ Red/ Orange/ Green(brightest)/ Blue
Body color: Black / Blue / Green
Battery Type: 1* 18650 / 18350
Can't wait for our reply??
FLASH SALE Price: $32.99
Valid till: BGFMSS
WE NEED More SUBSCRIBERS!
www.youtube.com/embed/yn0VdISzIA0
Specification:
Brand & Model: Astrolux FT03 MINI
Material: Aluminum alloy
Emitter Type: NM1
Light temperature:
White
Red
Orange
Blue
Green
Output: 510 Lumens
Distance: 860 Meters
Beam intensity: 185,000 CD
Driver: Texas Avenger FET Driver with charging
Battery:
1x 18650 (not included)
or 1x 18350 (not included)
unprotected 18650 recommended, and
must use unprotected 18350 battery.
USB Rechargeable: Yes, Type-C (USB-C) Quick Charge
Reflector: High quality smooth reflector
Lens: Glass with anti-reflective coating
Body: Aerospace grade aluminium alloy
Button: Silicone rubber
Impact Resistant: 1.5 Meters
Waterproof: Equivalent to IPX7, do not immerse in liquids
Body Color: Blue / Green / Black
Weight: Approximately 136g without cells
Size: with 18650 tube:
144.8mm* 43.5mm* 25.5 mm
(length* head diameter* body diameter)
with 18350 tube:
113.7mm* 43.5mm* 25.5 mm
Package included:
1x Flashlight Head
1x 18650 body tube
1x 18350 body tube
2 x Spare Waterproof O-rings
1 x Lanyard
1 x User Manual
Operation UI:
Operate Current Status
OFF ON
Single click Low 1. Not at Turbo now: gear cycle
(Low - medium1 - medium2 - high, then return to low and continue the cycle to high)
2. At Turbo now, it will: return to the gear before the turbo
Long press Moon Off
Double click Turbo 1. Not strobe now, will go to: Turbo
2. If strobe now, will go to: Quick flash-SOS - Candle flash (and cycle)
Triple click to Strobe to Strobe
Four click Report voltage No reaction
Five click 1.If locked state now, will go to: Unlocked 1.If locked state now, will go to: Unlocked
2. If standby state now, will go to: Lock 2. If standby state now, will go to: Lock
Six click Tactical lighting mode
(this will be cancelled after power off)
No reaction
#forevercopycat
Reserved.
Reserved.
Reserved.
Interested! Thank you
Interested, thanks.
I really like this but the lumen output is just to low. :frowning:
For which color?
All colors,
freeme - is the driver spec correct? Is it really a TA FET driver but limited to 4.5 4.8 amps? I'm confused. It's possible with firmware modifications but there are better solutions.
The output specs are clearly wrong - there are variances based on the color LED. I assume the specs are for white at 4.5 4.8 amps.
Regulated driver at 4.8A max. Doubt it is TA FET driver design. I will ask them to update accordingly.
I hope they could provide accurate output for individual color as well.
Corrected to 4.8 amps above. If they can't provide color specific output levels, then they should just say the ratings are for white only, and if they say all colors are using 4.8 amps regulated output, then that's good enough for me
When is the full sized version coming?
Interested, thanks.
interested
This one? https://budgetlightforum.com/t/-/60527
I believe they will only consider white nm.1.
Interested in white and green lightcolour.
https://streamja.com/embed/OnlZo
:smiling_imp: good light
Interested
Ordered three with green light.
Thanks for this GB, freeme !
