Interested! Thank you
Interested, thanks.
I really like this but the lumen output is just to low.
For which color?
All colors,
freeme - is the driver spec correct? Is it really a TA FET driver but limited to 4.5 4.8 amps? I'm confused. It's possible with firmware modifications but there are better solutions.
The output specs are clearly wrong - there are variances based on the color LED. I assume the specs are for white at 4.5 4.8 amps.
Regulated driver at 4.8A max. Doubt it is TA FET driver design. I will ask them to update accordingly.
I hope they could provide accurate output for individual color as well.
freeme - is the driver spec correct? Is it really a TA FET driver but limited to 4.5 amps? I'm confused. It's possible with firmware modifications but there are better solutions.
The output specs are clearly wrong - there are variances based on the color LED. I assume the specs are for white at 4.5 amps.
Corrected to 4.8 amps above. If they can't provide color specific output levels, then they should just say the ratings are for white only, and if they say all colors are using 4.8 amps regulated output, then that's good enough for me
When is the full sized version coming?
Interested, thanks.
interested
This one? https://budgetlightforum.com/t/-/60527
I believe they will only consider white nm.1.
Interested in white and green lightcolour.
Interested
Ordered three with green light.
Thanks for this GB, freeme !
I wonder if this will start shipping now? Says 22nd on BG
Let double check with them this week.
6th of October now.
Green/green is Oct 16th
