It depends on how you define “old”, but I’ll assume LED flashlights and the answer for me is yes.
A couple of my first flashlights were Sunwayman D40As (bought in 2014), one with a cool white XM-L2 LED and the other neutral white. A lot of lumens for AA flashlights and some good throw. I really liked the neutral white over the cool white - which was the rationale for my BLF name. They don’t get used as much as when I first got them, but they are still great flashlights and are safe for the family since they are AA flashlights.
Me too! I still use it quite frequently. I purchased it three years ago specifically to build a dual-switch pocket thrower.
I piggybacked a Texas Avenger driver onto the stock switch/charging board. It’s running Andúril with dual-switch support enabled.
The forward-clicky tail switch acts only as power on/off, and the light has mode memory. That means I can use the tail switch for momentary at whatever brightness was previously used. I really like a thrower with momentary mode while hiking with a floody headlamp.
Over 20 of my lights are from the 60`s and 70`s and I use them (in rotation) every night for reading, they`ve all been converted over to 18650 and 21700 protected cells (mainly because a lot of them take a No.8 battery that`s not made anymore), and most are still incan.
There`s just something about flashlights from your childhood that you don`t really get with new modern ones, though there are a few of todays lights that I`v really taken too as well.
I have never understood the “programmable UI” or the “moonlight mode” wants. The old stuff beats the new in many ways, not the least of which being step-downs, piss-poor ugly yellow de-domes, and a hundred other things.
I still have a Sunwayman D40A. I also don’t use it much these days, but once in a while I take it out & install fresh cells for a go. Still packs a good punch for this AA based flashlight. Having AA available is a good fall-back for emergencies. Size wise, I’m much more apt to go with my Sofirn SP33v3 throw for the same form factor. But if I didn’t have that, I’d be tempted to upgrade the emitter on the D40A.
FWIW, Sunwayman will provide replacement switch covers if you contact them. I did, a few years ago, and they sent me it free of charge.
Did you know the old Seeker has the largest beam distance of all family members? A really unique light. So, despite being quite old, it’s not obsolete. The wide spill and the spill/spot ratio is magic.
Over 5 years ago I bought a grey Convoy S2. I kinda abuse that light as my moving donor light. I own a few C2+ lights and when I need a new part in a hurry, I first open up my old C2 to look for something I can Use. Afterwards I put new parts in the old C2. After 5+ years there is not a single original part left in her old (baked) body. Yet it is the first light I grab when I need one around the house.
The light in my BOB is another story. February 2012 I bought a D25C Ti and it went almost straight into my BOB. Once a year I polish it and check if everything works as it should. And it always passes its physical.
Maybe it is the incandescent bulb they use. Even if you use high color rendering leds, for demanding lads & lasses they probably don't make the grade due to cut corners in their spectrum.
Certain stuff simply fit your frequency better than others. I edc my turbo :-D SK98 quite often, not only it fits well in my pocket, it exudes that special charm that (for me) DIY stuff has, especially when you have messed and improved nearly every non obvious aspect of it.
