Convoy M21C and M26C Feedback
17 posts / 0 new
zoulas
Last seen: 23 min 32 sec ago
Just got them from BG. I love the lights but some QC issues. Both arrived with a loose bezel, the glass was rattling a bit. I had to use excessive twisting force of the bezel to get it tight enough for the rattle to stop.
Both lights have this annoying ring at the outer limit of the spill part. Its more noticeable on shorter distances.
Other than that, still worth the $30 I paid for each one.
Rusty Joe
Rusty Joe's picture
Last seen: 6 hours 27 min ago
Where to buy them the fastest in the USA?
Geuzzz
Geuzzz's picture
Last seen: 2 hours 11 min ago
I had to do the same. The ring is “normal” wit xhp70.2
How is the ramping on yours? I don’t like it and will set it to modes. It’s not comparable to Anduril.
Also I don’t like that when you long press for low, you can’t go to the next mode. You have to turn of the light and turn it on with a normal press.
Great light otherwise.
caramba
caramba's picture
Last seen: 1 day 1 hour ago
Swabs posted Before and After swapping the original OP reflector for SMO,
The beamshot with OP looks really nice, I don’t see the rings.
caramba
caramba's picture
Michaeltmohr has a US based Convoy store.
zoulas
You dont want to buy a chinese light from a US store. All they do is get it from china themselves and mark it up. Better get it from BG. Much better selection, and the lowest prices. Just plan to wait 30-90 days for it.
MoreLumens
MoreLumens's picture
Last seen: 5 min 47 sec ago
Can you tell more about that ramping? What makes it different?
Geuzzz
Geuzzz's picture
Does not respond immediately, but then goes to fast and overshoots the desired level.
zoulas
I will tell you this, the flashlight puts out enormous amount of light and it last on high real long without getting hot.
MoreLumens
That’s a good info.
What about side by side size of those two? Is battery tube the only difference and both got same size of head?
zoulas
Ironically, the head is bigger in the M21, and the body is longer.
MoreLumens
I cant see that picture. Try hosting it at somewhere like imgur etc.
zoulas
Link
Here you go
<a href="https://imgur.com/shxtXgS"><img src="https://i.imgur.com/shxtXgS.jpg" title="source: imgur.com" /></a>
MoreLumens
Hmm I wonder if the M21C’s heat dissipation is better because it obviously has bigger head.
zoulas
M26 gets barely warm after 3 min on high. M21 does not feel warm at all after 3 min. Both excellent lights. As for the UI, its simple. If you need the manual for the UI, that’s not a good thing. The Narsil UI is like that.
MoreLumens
What about weight difference without cell?
I’m just thinking about what Convoy I should get.
zoulas
Not a big difference, if anything the 26 feels a bit better and of course the longer run time is always a good thing.
